Restoration Schemes
If your instance is damaged or mistakenly deleted, you can restore it using the following methods.
Restoring or Migrating Data to TaurusDB
- You can restore data using backups. For details, see Restoring a DB Instance from Backups.
- You can migrate data using DRS, mysqldump, or DAS. For details, see Data Migration Schemes.
Restoring Deleted or Modified Data
| Scenario | Restoration Scheme | Restoration Scope | Restore To | Operation Guide |
| Restoring a deleted instance | If the deleted instance is in the recycle bin, rebuild it from the recycle bin. | All databases and tables | The original instance | |
| If a manual backup has been created before the instance was deleted, restore the instance on the Backups page. | All databases and tables |
| Restoring a deleted table | Use the database table restoration method to restore the table. |
| Restoring a deleted database | Use the database table restoration method to restore the database. |
| Restoring deleted or modified columns, rows, and data in tables, and overwritten tables | If more than 100,000 data records are deleted or modified, use the database table restoration method to restore data in the table. |
