Help Center/ TaurusDB/ User Guide/ Data Backups/ Billed Space for Full Backups
Updated on 2026-01-13 GMT+08:00
There are seven backups in a backup chain by default. The first automated backup is a full backup, and subsequent automated backups are differential backups.
Concepts
  • Full backup: All data is backed up even if no data has changed since the last backup.
  • Differential backup: The system backs up deduplicated data from the last full backup or differential backup to physical files. The physical files cannot be used for log replay.
  • Incremental backup: The system backs up data that has changed since the last automated backup or incremental backup to logs every 5 minutes. The logs can be used to restore data to a point in time.
  • Billed space: backup space that you are billed for
  • Logical space: initial volume of data in shared storage at the time of full or differential backups
  • Physical space: volume of data that is backed up to OBS
During full backups, the physical space is equal to the logical space. During differential backups, the physical space is smaller than the logical space after deduplication. Backup records display the logical space.
Backup Principles
As shown in the figure, a backup chain contains seven backups by default. Starting with a full backup on Monday, the system performs daily differential backups from Tuesday to Sunday. Between these, the system automatically backs up the data updated since the last automated or incremental backup every 5 minutes or when a certain amount of data is generated.
Figure 1 Backup diagram
Backup Clearing
Automated backups are deleted once they exceed their retention period. However, the OBS space may not be released immediately because unexpired backups in the same backup chain may depend on the expired ones. The backup space is only released after all full and differential backups in that chain are deleted.
By default, a backup chain includes seven backups, with automated backups retained for seven days. The chain starts with a full backup, followed by differential backups.
In the figure below, the 11th backup is today's. The 1st to 3rd backups have expired, but the 4th to 7th backups still depend on them. So, deleting the 1st to 3rd backups will not immediately release space. The backup space is only released after the 1st to 7th backups are all deleted.
Backup Space Calculation Methods
Billed space is calculated as follows:
Billed space = Min(Logical space, Physical space) – Free space = Min(Logical space, Physical space) – Storage space x 100%
  • Logical space: Total size of the logical space – Logical size of the expired backup
  • Physical space: Size of the first full backup + Total size of subsequent differential backups
  • Free space: There is free backup storage up to 100% of your purchased storage space.
Example
A backup chain contains seven backups by default. There are 11 backups shown in the following figure. The 1st backup to the 7th belong to one backup chain and the 8th to the 11th belong to another.
Figure 2 Backup example
If there is 1,000 MB of backup space and the logical space is 1,000 MB each time, the physical space for the 1st backup is 1,000 MB. If the incremental data size is 100 MB each time, the physical space for the 2nd backup to 7th is 100 MB.
The physical space for the 8th backup is 1,000 MB because it represents a new backup chain.
Billed space includes the space of the two chains in the example.
Suppose that after the 11th backup was created, and the 1st, 2nd and 3rd backups expired and were automatically deleted. The size of each space is calculated as follows:
  • Total size of the logical space for the 11th backup = Total logical space size – Logical size of the expired backup (1,000 MB x 11 – 3,000 MB = 8,000 MB in this example)
  • Physical space: size of data backed up to OBS. In this example, physical space includes the sum of physical space on the two backup chains: 1,000 MB + (100 MB x 6) + 1,000 MB + (100 MB x 3) = 2,900 MB
  • Total billed space = Min(Total size of logical space, Total size of physical space) – Free space, so the total billed space in this example = Min(8,000 MB, 2,900 MB) – 1,000 MB = 1,900 MB
