Overview of Backups
What Are Database Backups?
Automated backups are created during the backup window of your TaurusDB instances. The system retains the backups based on your specified retention period (1 to 732 days).
A backup is generated each time a backup is complete. If the instance fails or data is damaged, you can use the backup to restore the instance, ensuring data availability.
Backup Types
TaurusDB supports multiple backup types. For details, see Backup Types.
Backup Principles
TaurusDB uses Huawei's DFV storage, which decouples storage from compute.
- Compute layer: provides services for external systems and manages logs.
- Storage layer: consists of Common Log nodes and Slice Store nodes. Common Log nodes store logs. Slice Store nodes store data.
As shown in the following figure, the creation of backups involves both the compute and storage layers.
- The primary node at the compute layer reads the logs of the Common Log nodes at the storage layer and backs them up to OBS.
- The primary node at the compute layer delivers a command for backing up data to the Slice Store nodes at the storage layer. The Slice Store nodes back up data to OBS.
During the creation of a backup, the CPU usage and memory usage of the primary node of your instance increase slightly, but you will not notice anything at the storage layer. The final backup is stored in OBS as multiple data files, so it does not use any storage on the instance.
How Data Is Backed Up
TaurusDB automated backups are enabled by default and cannot be disabled. TaurusDB performs automated full backups based on the time window and cycle specified in the backup policy. It also backs up data changes made after the most recent automated full backup or incremental backup every 5 minutes or when a certain amount of incremental data is generated.
- Restoration from backups: The system restores instance data to the state at the end of the full backup you choose. This action restores the data for the entire instance.
- Point-in-time recovery (PITR): When you restore an instance to a point in time, the system downloads the most recent full backup from OBS and uses it for restoration. After the restoration is complete, the system replays incremental backups to the specified point in time.
Backup Storage and Billing
TaurusDB backups are stored on OBS. They do not occupy the storage of your instance. TaurusDB provides free backup space of the same size as your purchased storage.
If your instance is frozen, no free backup space is available. As a result, the original automated backups of the instance will be billed.
- If you unfreeze the instance, the free backup space will be restored.
- If you directly delete the frozen instance, its automated backups will also be deleted and the backup space will not be billed any longer.
Example:
If you purchase a DB instance with 200 GB of storage, you can get an additional 200 GB of backup space and will only be billed for backups in excess of 200 GB. The first 200 GB of backup data is free. After the free backup space is used up, the additional space used will be billed on a pay-per-use basis. For pricing details, see Product Pricing Details.
Backup Cleanup
- Manual backups can only be manually deleted.
- Automated backups cannot be manually deleted. To delete them, you can adjust the retention period specified in your automated backup policy. Retained backups will be automatically deleted at the end of the retention period. To ensure data integrity, the system keeps the most recent backup that has exceeded the retention period during automatic deletions. This ensures that data within the retention period can still be restored.
Example:
If Backup Cycle was set to Monday and Tuesday and Retention Period was set to 2, the deletion behavior is as follows:
- The full backup generated on Monday will be automatically deleted on Thursday.
The backup generated on Monday expires on Wednesday, but it was the last backup, so it will be retained until a new backup expires. The next backup will be generated on Tuesday and will expire on Thursday. So the full backup generated on Monday will not be automatically deleted until Thursday.
- The full backup generated on Tuesday will be automatically deleted on Wednesday of the following week.
The backup generated on Tuesday will expire on Thursday, but as it is the last backup, so it will be retained until a new backup expires. The next backup will be generated on the next Monday and will expire on the next Wednesday. So the full backup generated on Tuesday will not be automatically deleted until the next Wednesday.
