Help Center/ TaurusDB/ User Guide/ Instance Management/ Configuration Changes/ Customizing Displayed Items of the Instance List
Updated on 2026-04-16 GMT+08:00
You can customize instance information items displayed on the Instances page based on your requirements.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click
and select items displayed in the instance list. - The following items are displayed by default: Name/ID, Description, DB Instance Type, DB Engine, Status, Billing Mode, Private IP Address, Storage Type, and Operation.
The default items cannot be deselected.
- You can also select the following items: Proxy Address, Private Domain Name, Enterprise Project, Created, and Database Port.
