Rebooting a DB Instance or Node
You may need to reboot a DB instance or node for maintenance purposes. For example, after modifying some parameters, you may need to reboot your instance to apply the modifications. You may need to reboot a node to resolve database connection issues.
When you reboot a node, the system checks the database process, number of large transactions, and LSN latency between the primary node and read replicas. If certain conditions are met, the node can be forcibly rebooted to restore workloads. Forcibly rebooting the primary node will trigger a primary/standby switchover. Exercise caution when performing this operation.
Scenario |
Description |
Rebooting a DB instance |
Rebooting a node |
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, locate the instance you want to reboot and choose in the Operation column.
Alternatively, click the instance name to go to the Basic Information page. In the upper right corner of the page, click Reboot.
The read replicas (if any) are also rebooted.
- In the displayed dialog box, set Scheduled Time and click OK.
Figure 1 Rebooting a DB instance
Table 2 Rebooting a DB instance Parameter
Scheduled Time
You can reboot a DB instance immediately or during the maintenance window.
- Immediate: The DB instance will be rebooted immediately.
- During maintenance window: The DB instance will be rebooted during a maintenance window.
The maintenance window is 02:00–06:00 by default and you can change it as required. Changing the maintenance window will not affect the timing that has already been scheduled.
A reboot task configured during a current maintenance window will not be executed until the next maintenance window.
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
- View the reboot progress on the Task Center page. If the task status becomes Completed and the instance status becomes Available, the DB instance has been rebooted successfully.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name to go to the Basic Information page.
- In the Node List area, select the target node and click Reboot in the Operation column.
Table 3 Rebooting a node Parameter
Scheduled Time
You can reboot a node immediately or during the maintenance window.
- Immediate: The node will be rebooted immediately.
- During maintenance window: The node will be rebooted during a maintenance window.
Confirm forcible reboot
Whether to forcibly reboot an instance node. This option is deselected by default.
If this option is selected, the primary node will be forcibly rebooted. In this case, an available read replica will be promoted to primary, and the scheduled maintenance window for node reboots will not take effect.
When you reboot a node, the system checks the database process, number of large transactions, and LSN latency between the primary node and a read replica. If one or more of the following conditions are met, the node can be forcibly rebooted:- The mysqld service is abnormal.
- The LSN latency between the primary node and a read replica is greater than 1,024 MB.
- There are more than 100 million large transactions.
- View the reboot progress on the Task Center page. If the task status becomes Completed and the node status becomes Available, the node has been rebooted successfully.
