Configuring and Changing the Private IP Address
You can change private IP addresses after migrating data from on-premises databases or other cloud databases to TaurusDB.
- If there is an HTAP instance, the private IP address of the DB instance cannot be changed.
- Changing the private IP address will interrupt database connections, so change it during off-peak hours.
Configuring the Private IP Address of a DB Instance
When you buy an instance, select a VPC and subnet on the Buy DB Instance page. Then, a private IP address will be automatically assigned to your instance. You can also enter a private IP address.
You can change the private IP address of an existing TaurusDB instance.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name to go to the Basic Information page.
- In the Network Information area, click Modify under Private IP Address.
- In the displayed dialog box, select an unused private IP address and click OK.
An in-use IP address cannot be used as the new private IP address.
Figure 1 Changing the private IP address
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
