Help Center/
SoftWare Repository for Container/
User Guide (Basic Edition)/
Image Management/
Uploading an Image
Updated on 2025-09-19 GMT+08:00
Uploading an Image
This section describes how to upload an image on the SWR console.
- Up to 10 files can be uploaded at a time. The size of a single file (including each decompressed file) cannot exceed 2 GB.
- If the image package to be uploaded is created using a Docker container engine client, the Docker version must be 18.06 or later.
- You have created an organization in SWR. For details, see Creating an Organization.
- The image has been saved as a .tar or .tar.gz file. For details, see Creating an Image Package.
- Log in to the SWR console.
- In the navigation pane, choose My Images. Then click Upload Through SWR.
- In the displayed dialog box, select an organization. Then, click Select File to upload an image file.
If you select multiple images, they will be uploaded one by one. Concurrent upload is not supported.
Figure 1 Uploading an image on the SWR console
- Click Upload.
If Completed is displayed, the image is uploaded successfully.
