Help Center/ ServiceStage/ User Guide/ Environment Management/ Managing Environment Variables of an Environment
Updated on 2025-07-10 GMT+08:00
Environment variables of an environment describe environment information and environment resource information, such as middleware credentials, connection information, and environment functions. Customers can use these variables to shield environment or resource differences, and switch components to different environments or run them using different cloud service resources without modification.
If the resources (DCS, RDS, ServiceComb, Nacos, and CSS) listed in Table 1 exist in the environment, ServiceStage writes the corresponding built-in and custom environment variables in the environment.
Table 1 Built-in and custom environment variables of an environment
Resource Type
Name
Variable Source
Variable/Variable Reference Example
DCS
DISTRIBUTED_CACHE_TYPE
Distributed cache type.
Built-in
Redis
DISTRIBUTED_CACHE_NAME
Name of a DCS instance.
Built-in
dcs-test
DISTRIBUTED_CACHE_VERSION
Distributed cache version.
Built-in
5.0
DISTRIBUTED_CACHE_CLUSTER
Distributed cache cluster type.
Built-in
false
DISTRIBUTED_CACHE_HOST
Distributed cache address.
Built-in
192.168.0.136
DISTRIBUTED_CACHE_PORT
Distributed cache port.
Built-in
6379
DISTRIBUTED_SESSION_CLUSTER
Distributed session cluster type.
Built-in
false
DISTRIBUTED_SESSION_HOST
Distributed session address.
Built-in
192.168.0.136
DISTRIBUTED_SESSION_VERSION
Distributed session version.
Built-in
5.0
DISTRIBUTED_SESSION_TYPE
Distributed session type.
Built-in
Redis
DISTRIBUTED_CACHE_PASSWORD
Distributed cache password.
Custom
RDS
RELATIONAL_DATABASE_DB_TYPE
Cloud database type.
Built-in
MySQL
RELATIONAL_DATABASE_HOST
Cloud database address.
Built-in
172.16.0.185
RELATIONAL_DATABASE_CONNECTION_TYPE
Cloud database connection type.
Built-in
JNDI
RELATIONAL_DATABASE_PORT
Cloud database port.
Built-in
3306
RELATIONAL_DATABASE_NAME
Cloud database name.
Built-in
rds-pro
RELATIONAL_DATABASE_VERSION
Cloud database version.
Built-in
8.0
RELATIONAL_DATABASE_JNDI_NAME
Cloud database JNDI name.
Custom
jndi-u1
RELATIONAL_DATABASE_DB_USER
Cloud database account.
Custom
rds-u1
RELATIONAL_DATABASE_PASSWORD
Cloud database password.
Custom
ServiceComb
PAAS_CSE_CC_ENDPOINT
Address of the ServiceComb engine configuration center.
Built-in
https://192.168.0.31:30110,https://192.168.0.36:30110
PAAS_CSE_SC_ENDPOINT
Service center address of the ServiceComb engine.
Built-in
https://192.168.0.31:30100,https://192.168.0.36:30100
SERVICECOMB_SERVICE_PARAMETERS
ServiceComb engine service configuration.
Built-in
cas-instance-id:c3bee2c1-5174-4ed4-b4e0-2cfdd5b47357
PAAS_CSE_ENGINE_MGR_ENDPOINT
Address of the ServiceComb engine management node.
Built-in
Endpoint of the ServiceComb engine.
Obtain the value from Regions and Endpoints.
SERVICECOMB_SERVICE_PROPS
Built-in
SERVICECOMB_ENGINE_NAME
ServiceComb engine name.
Built-in
cse-izq6rg
SERVICECOMB_INSTANCE_PROPS
ServiceComb engine instance configuration.
Built-in
affinity-tag:base,cas-instance-id:c3bee2c1-5174-4ed4-b4e0-2cfdd5b47357,cas_lane_tag:base
PAAS_CSE_DS_ENDPOINT
Dashboard center address of the ServiceComb engine.
Built-in
https://192.168.0.31:30109,https://192.168.0.36:30109
DYNAMIC_CONFIG_DYNAMICCONFIGTYPE
Type of the ServiceComb engine configuration center.
Built-in
KIE
DYNAMIC_CONFIG_SERVERADDRESS
Configuration center address of the ServiceComb engine.
Built-in
Nacos
REGISTER_SERVICE_REGISTERTYPE
Nacos engine service registry and discovery type.
Built-in
NACOS
REGISTER_SERVICE_ADDRESS
Service center address of the Nacos engine.
Built-in
SPRING_CLOUD_NACOS_CONFIG_SERVERADDR
Built-in
SPRING_CLOUD_NACOS_DISCOVERY_SERVERADDR
Built-in
EUREKA_CLIENT_SERVICEURL_DEFAULTZONE
Eureka server registry address.
Built-in
https://192.168.1.30:8761/eureka/
Type of the Nacos engine configuration center.
Built-in
NACOS
Configuration center address of the Nacos engine.
Built-in
PAAS_GAUSSDB_VERSION
Version.
Built-in
8.200.0
PAAS_GAUSSDB_NAME
Name.
Built-in
gauss-ss
PAAS_GAUSSDB_ADDRESS
Connection address.
Built-in
192.168.0.178:8000,192.168.0.47:8000,192.168.0.166:8000
PAAS_GAUSSDB_DB_NAME
Database name.
Custom
cas
PAAS_GAUSSDB_DB_USER
Username.
Custom
root
PAAS_GAUSSDB_PASSWORD
Password.
Custom
RocketMQ
DISTRIBUTED_MESSAGE_ROCKETMQ_VERSION
Version.
Built-in
5.x
DISTRIBUTED_MESSAGE_ROCKETMQ_NAME
Name.
Built-in
rocketmq-ss
DISTRIBUTED_MESSAGE_ROCKETMQ_ADDRESS
Connection address.
Built-in
192.168.0.84:9093,192.168.0.212:9093,192.168.0.174:9093
DISTRIBUTED_MESSAGE_ROCKETMQ_USER
Username.
Custom
root
DISTRIBUTED_MESSAGE_ROCKETMQ_PASSWORD
Password.
Custom
CSS
PAAS_ELASTIC_SEARCH_VERSION
Version.
Built-in
7.10.2
PAAS_ELASTIC_SEARCH_NAME
Name.
Built-in
css_es
PAAS_ELASTIC_SEARCH_ADDRESS
Connection address.
Built-in
21.108.0.218:9200,21.108.0.88:9200,21.108.0.231:9200
PAAS_ELASTIC_SEARCH_HTTPS_ENABLE
Whether to enable HTTPS.
Built-in
true
PAAS_ELASTIC_SEARCH_USER
Username.
Custom
admin
PAAS_ELASTIC_SEARCH_PASSWORD
Password.
Custom
You can also add, edit, and delete custom environment variables of an environment.
Priority of environment variables of the component, application, and environment levels: component > application > environment.
Adding an Environment Variable
  1. Log in to ServiceStage.
  2. Choose Environment Management. The Environment Management page is displayed.
  3. Click the target environment. The Overview page is displayed.
  4. Choose Environment Variables > Add Environmental Variable and set variable parameters by referring to the following table.
    Exercise caution when inputting sensitive information in configuring environment variables, or encrypt sensitive information to avoid information leakage.
    Name
    Name of an environment variable.
    Enter 1 to 64 characters. Start with a letter, underscore (_), or hyphen (-). Only use letters, digits, underscores (_), hyphens (-), and periods (.).
    Value of a variable name.
  5. Click Confirm in the Operation column of the new environment variable.
    Type of the new environment variable is Custom, and Associated Object is the current environment. After environment variables of an environment are changed, you can:
Editing an Environment Variable
  4. Click Environment Variables.
  5. Click Edit in the Operation column of the custom environment variable to be edited and set parameters by referring to the following table.
    Name
  6. Click Confirm in the Operation column of the environment variable.
Deleting an Environment Variable
  1. Click Environment Variables to delete a custom environment variable.
    • Single deletion: Click Delete in the Operation column of the target custom environment variable.
    • Batch deletion: Select the target custom environment variables and click Bulk Delete.
  2. Click OK.
    Delete environment variables as required to prevent component startup failures caused by missing environment variables when Upgrading a Single Component or Upgrading Components in Batches.
