Rolling Back a Configuration File
This section describes how to roll back a configuration file to a historical version.
Editing a Configuration File has been performed on the configuration file to be rolled back.
- Log in to ServiceStage.
- Choose Configuration Management > List.
- Use either of the following methods to open the Historical Version dialog box:
- Click View History in the Operation column of the target configuration file.
- Click the target configuration file and click View History.
- Move the cursor to a historical version.
- Use either of the following methods to roll back the configuration file:
- Roll back after version comparison: Click Compare to compare the current and historical versions, and click Roll Back to Current Version.
- Roll back after viewing the historical version configuration: Click View to view the configuration details of the historical version, and click Roll Back to Current Version.
- Click OK.
Compare the historical version selected in 4 with the latest version by referring to Comparing Configuration Files. If the configurations are the same, the rollback is successful.
