Configuration Overview
Updated on 2024-12-16 GMT+08:00
If multiple components of different applications need to be deployed in different environments, each component must be configured based on the environment and application when you create or upgrade them. This is complex and error-prone. If the component configuration is incorrect, the deployment or upgrade will fail, which severely affects services.
To solve the preceding problems, ServiceStage provides configuration management. By creating a unified configuration, you can fill the system variables (such as the IP address, port number, database address, and application name associated with the environment) of the component environment and application in the configuration to generate a configuration file. When a component is associated with a configuration file for deployment, the system variables are automatically replaced with the actual value. This implements multi-environment use with one-time configuration through file mounting.
System Variables of a Configuration File
For details about the system variables that can be written into a configuration file, see Table 1.
Table 1 System variables
Variable Name
PAAS_PROJECT_ID
Project ID.
CAS_ENVIRONMENT_ID
Environment ID.
CAS_ENVIRONMENT_NAME
Environment name.
CAS_APPLICATION_ID
Application ID.
CAS_APPLICATION_NAME
Application name.
CAS_COMPONENT_ID
Component ID.
CAS_INSTANCE_ID
Component instance ID.
CAS_INSTANCE_NAME
Component instance name.
CAS_INSTANCE_VERSION
Component instance version.
PAAS_PROJECT_NAME
Project name.
AOM_DISCOVERY_RULE_VERSION
AOM discovery rule name.
PAAS_REGION_NAME
Region name.
PAAS_CSE_CC_ENDPOINT
CSE configuration center address.
PAAS_CSE_SC_ENDPOINT
CSE registry center address.
DISTRIBUTED_CACHE_PASSWORD
Distributed cache password.
DISTRIBUTED_CACHE_TYPE
Distributed cache type.
DISTRIBUTED_CACHE_PORT
Distributed cache port.
DISTRIBUTED_CACHE_HOST
Distributed cache address.
DISTRIBUTED_CACHE_VERSION
Distributed cache version.
DISTRIBUTED_CACHE_CLUSTER
Distributed cache cluster type.
RELATIONAL_DATABASE_PASSWORD
Cloud database password.
RELATIONAL_DATABASE_DB_TYPE
Cloud database type.
RELATIONAL_DATABASE_JNDI_NAME
Cloud database JNDI name.
RELATIONAL_DATABASE_HOST
Cloud database address.
RELATIONAL_DATABASE_CONNECTION_TYPE
Cloud database connection type.
RELATIONAL_DATABASE_DB_NAME
Cloud database name.
RELATIONAL_DATABASE_DB_USER
Cloud database account.
RELATIONAL_DATABASE_PORT
Cloud database port.
RELATIONAL_DATABASE_NAME
RELATIONAL_DATABASE_VERSION
Cloud database version.
