Deleting a Build Job
Delete a user-created build job that is no longer used. After a build job is deleted, Creating and Deploying a Component, Upgrading a Single Component, or Upgrading Components in Batches may fail.
To delete a system-created build job, see Deleting a Component.
The user-created build job to be deleted is available. For details, see Creating a Source Code Job and Creating a Package Job.
- Log in to ServiceStage.
- Choose Continuous Delivery > Build.
- On the Build page, use either of the following methods to search for a build job:
- Select User created and select the CCE cluster and build job status. Then, select the target build job in the build list.
- Search for the build job created by the specified user in the search box.
- Click More > Delete.
- Click OK.
