Help Center/
ServiceStage/
User Guide/
Component Management/
Synchronizing Component Configurations in Batches
Updated on 2025-09-26 GMT+08:00
You can synchronize latest configurations after container-based component workload changes (such as workloads upgraded using CCE).
- Only the components created and deployed using the following methods support batch component version synchronization:
- The component status is Running, Not ready, Processing, or Abnormal. For details about how to check the component status, see Viewing Component Details.
- Log in to ServiceStage.
- Choose Application Management.
- Click the application where the target components are located. The Overview page of the application is displayed.
- Select the components whose configurations are to be synchronized in batches in Component List and click More > Sync.
Parent topic: Component Management
