Updated on 2025-09-26 GMT+08:00
Deleting a Microservice Engine
You can delete a microservice engine if it is no longer used. You can delete microservice engines in the following states:
  • Available
  • Unavailable
  • Creation failed
  • Resizing failed
  • Upgrade failed
  • Unknown
Restrictions
  • Deleted engines cannot be restored. Exercise caution when performing this operation.
  • For engine 1.x, if the cse_admin_trust agency is missing, deleting the engine will cause residual DNS, VPC, and security group resources on the tenant side. You need to delete them by yourself.
  1. Log in to ServiceStage.
  2. Choose Cloud Service Engine > Engines.
  1. Select the target microservice engine from the Microservice Engine drop-down list in the upper part of the page.
  2. In the Microservice Engine Information area, click Delete. In the displayed dialog box, enter DELETE and click OK.
    If the deletion fails, click Force Delete.
