Viewing Build Jobs
You can view the build records and logs of a specified build job in the build job list to locate and rectify faults that occur during component deployment.
You have created a build job of the Java, Tomcat, Node.js, Python, or PHP technology stack.
- For system-created build jobs, see Creating a Component Based on a Container Using Manual Configurations and Creating a Component Based on a Container Using YAML Configurations.
- For user-created build jobs, see Creating a Source Code Job and Creating a Package Job.
Viewing Build Jobs
- Log in to ServiceStage.
- Choose Continuous Delivery > Build.
- On the Build page, use either of the following methods to search for a build job:
- Select the CCE cluster where the component is deployed and the build job status, and select the specified build job in the build list.
- Search for the build job in the search box.
- Click the build task name. The build task details page is displayed.
- View Basic Information and Build Record of the build job.
- Click View Log next to a build record to view Build Details, CodeCheck, and Log.
Only the Maven build project supports code check. Currently, the following code check plug-ins are supported: Checkstyle, FindBugs, and PMD.
