Continuous Delivery Overview
Continuous delivery provides functions such as project build and release.
Build Job Overview
Based on the existing service code, you can create a build job, start the build job, package the service code, and archive the package to the deployment source. Then, you can use the package when deploying an application component.
There are two types of build jobs:
- System build jobs are created by the system when Creating a Component Based on a Container Using Manual Configurations and Creating a Component Based on a Container Using YAML Configurations.
- User build jobs are created when Creating a Source Code Job and Creating a Package Job.
Pipeline Overview
Based on the existing service code, you can create a pipeline and then start the pipeline to complete service code building and deployment. Application O&M can also be completed on ServiceStage.
