Help Center/
ServiceStage/
User Guide/
Component Management/
Managing Component Details/
Changing the Component Access Domain Name
Updated on 2025-07-10 GMT+08:00
For components with enabled public network access and set access domain names, you can change the domain names after the components are deployed.
- An automatically generated domain name is valid only for seven days. After the validity period expires, the domain name must be changed to a custom domain name.
- You can set the component access mode only for the components deployed using the following methods with public network access enabled:
- The component status is Running. For details about how to check the component status, see Viewing Component Details.
- You have obtained the domain name from the domain name provider.
- You have obtained the elastic IP address of the ELB bound to the component.
- Log in to ServiceStage.
- Use either of the following methods to go to the Access Mode page.
- On the Application Management page, click the application to which the component belongs, click the target component in Component List, and choose Access Mode in the left navigation pane.
- On the Component Management page, click the target component and choose Access Mode in the left navigation pane.
- Click Set domain.
- Enter the obtained Domain Name.
- Enter Listening Port.
- (Optional) Enable HTTPS.
- Click Use existing to select an existing certificate.
- Click Create new to create a server certificate. For details, see Adding a Certificate.
Parent topic: Managing Component Details
