Help Center/ ServiceStage/ User Guide/ Component Management/ Configuring the Component Access Mode
Updated on 2024-12-16 GMT+08:00
This section describes how to configure the access mode for a component. After the configuration, you can access the services provided by the component in the configured mode.
You can only set the component access mode for components that are deployed based on a container and are in the Running state. For details about how to check the component status, see Viewing Component Details.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the Access Mode page.
    • On the Application Management page, click the application to which the component belongs, click the target component in Component List, and choose Access Mode in the left navigation pane.
    • On the Component Management page, click the target component and choose Access Mode in the left navigation pane.
    If the component is created by Creating a Component by Importing a CCE Workload and is not enabled:
    1. In the displayed dialog box, click OK.
    2. On the Enable Component page, click Enable and wait until the component is restarted.
  3. Click Add Service and set the following parameters. Parameters marked with an asterisk (*) are mandatory.
    *Service Name
    The service name can be the same as the component name.
    The name contains 1 to 63 characters starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
    Access Mode
    The options are as follows:
    • Intra-cluster access: allows access from other services in the same cluster over TCP/UDP.
    • Intra-VPC access: allows access from other services in the same VPC over TCP/UDP.
    • Public network access: allows access from the Internet over TCP/UDP, including public EIP.
    Intra-VPC Load Balancing
    This parameter is available when Access Mode is set to Intra-VPC access.
    *Access Type
    • This parameter is available when Access Mode is set to Intra-VPC access and Intra-VPC load balancing is enabled.
    • This parameter is available when Access Mode is set to Public network access.
    Service Affinity
    This parameter is available when Access Mode is set to Intra-VPC access or Public network access.
    *Port Mapping
    Sets Protocol, Container Port, and Access Port for accessing the service.
    • Protocol: The value can be TCP, UDP, or TCP/UDP.
    • Container Port: The value range is 1 to 65535.
    • Access Port: The value range is 1 to 65535.
    Figure 1 Setting the component access mode
  4. Click OK.
