Updated on 2025-11-13 GMT+08:00
Configuring a Component
This topic describes how to configure Logstash. Logstash works as the log collection component in SecMaster.
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Log Audit > Components. Then, select the Components tab.
    Figure 2 Accessing the Components tab
  6. On the Components tab page, click Edit Settings in the upper right corner of the component to be viewed. The configuration management page of the component is displayed on the right.
  7. In the Node Configuration area, click Add in the upper left corner of the node list. In the Add Node dialog box displayed, select a node and click OK.
  8. Click Save and Apply in the lower right corner of the page.
    Wait for a period of time. When the component status changes to Applied completed, the Logstash collector has been installed on the current node.
    Figure 3 Configuration completed
Related Operations
You can view component details. For details, see Viewing Component Details.
