Help Center/ SecMaster/ User Guide/ Settings/ Log Data Collection/ Logstash Configuration Description
Updated on 2024-12-30 GMT+08:00
The data collector Logstash for tenant-side collection is customized by SecMaster. In different transmission scenarios, you can adjust parameter settings to obtain an optimal performance. This topic mainly covers how to tune log4j2.properties and jvm.options.
JVM Running Memory Configuration
Figure 1 jvm.options
Table 1 JVM running memory configuration
Configuration Type
Default Value
-Djava.awt.headless
boolean
true
Server side configuration. If it is set to "true", you can run an application in headless mode (without a keyboard or display). This parameter is used for data related services.
-XX:+UseConcMarkSweepGC
boolean
false
Concurrent Mark Sweep (CMS) garbage collector for the old generation.
-Xmn
String
1024M
The size of the heap for the young generation. If the collection pressure is high, adjust this value. The larger the heap size for the young generation, the smaller the number of garbage collection times, and the higher the collection efficiency. Xmn must be smaller than Xmx.
-Xmx
String
2048M
The total (maximum) heap size. A proper Xmx can prevent JVM from using excessive system resources to keep the application available and stable. If this parameter is set to a very small value, the collector will start garbage collection over and over again. This will affect collector performance.
-Djruby.jit.threshold
number
0
The specified method invocation count. When this threshold is reached, the JIT compiler of JRuby attempts to compile the local code of the method. You can adjust this value to obtain an optimal balance between startup time (compilation cost) and execution time performance
-XX:CMSInitiatingOccupancyFraction
number
75
CMS garbage collector. When the old generation usage reaches 75%, CMS garbage collection is triggered.
-Xms
String
20248M
The initial Java heap size. When JVM starts, it attempts to allocate the specified amount of memory to the heap. A proper initial heap size will free you from frequent heap size adjustments while the application is running.
log4j2 log configuration
Figure 2 log4j2.properties
Table 2 log4j2 log configuration
Configuration Type
Default Value
appender.json_console_slowlog.layout.compact
boolean
true
JSON slow query log output.
appender.json_console_slowlog.layout.type
String
JSONLayout
Layout type of JSON slow query logs. Retain the default value.
appender.json_console_slowlog.type
String
Console
Type of JSON slow query logs. Default value: Console, which means that logs are directly displayed on the console.
appender.json_console_slowlog.layout.eventEol
boolean
true
appender.json_console_slowlog.name
String
Name of the JSON slow query log. Retain the default value.
