Help Center/ SecMaster/ User Guide/ Threats/ Indicator Management/ Importing and Exporting Indicators
Updated on 2025-01-22 GMT+08:00
This section describes how to import and export indicators.
  • Only files in .xlsx can be imported. Each time you can import a file no larger than 5 MB with a maximum of 100 records.
  • A maximum of 9,999 indicator records can be exported.
Importing an Indicator
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Threats > Indicators.
    Figure 2 Indicators
  6. On the Indicator page, click Import in the upper left corner above the indicator list.
  7. In the displayed Import dialog box, click Download Template to download a template, and fill in the downloaded template according to the requirements.
  8. After the indicator file is ready, click Select File in the Import dialog box, and select the Excel file you want to import.
  9. Click OK.
    Figure 3 Workspace management page
    Figure 4 Indicators
  6. On the Indicators page, select the indicators you want to export and click in the upper right corner of the list. The Export dialog box is displayed.
  7. In the Export dialog box, set parameters.
    Table 1 Exporting indicators
    Format
    By default, the indicator list is exported into an Excel.
    Columns
    Select the indicator parameters to be exported.
  8. Click OK.
    The system automatically downloads the Excel to your local PC.
