Viewing Purchased Resources
You can view resources purchased by the current account on the Purchased Resources page and manage them centrally.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Purchased Resources.
- View details on the purchased resource page.
Table 1 Parameters for purchased resources Parameter
Buy Value-added Pack
To get a value-added package, click Buy Value-added Pack and complete the purchase as prompted.
Buy SecMaster
To buy SecMaster, click Buy SecMaster and complete the purchase as prompted.
Total/Subscribed Regions
Regions where SecMaster has been enabled for the current account and the total number of regions where SecMaster is rolled out.
Upgradeable
The number of purchased resources that can be upgraded in all regions under the current account.
Versions About to Expire
The number of purchased SecMaster editions and value-added packages that are about to expire in all regions under the current account.
Total Quota
The total quota purchased by the current account in all regions.
Purchased Resources
Details about SecMaster resources you purchased in each region.
- If there are many editions or regions, you can use filters to search for specific resources by region, edition, or order number, making it easier to identify the resources you have purchased.
- You can upgrade and renew SecMaster in a specific region. You can also increase quotas.
- On the Purchased Resources page, click the name of the SecMaster resource you have provisioned. The purchased resource details page is displayed on the right. Figure 1 Purchased Resource Details
Table 2 Parameters on the Purchased Resource Details page Parameter
Resources About to Expire
The number of purchased SecMaster editions and value-added packages that are about to expire in the current region.
Usage Alerts
Usage of all purchased resources in the current region.
Quota
Total number of quotas purchased in the current region.
Basic Information
View the current region, billing mode, and creation time of the resource.
Resources
The purchased resources in the current region are displayed in a list. You can view the resource type, billing mode, order No., specifications, creation time, and expiration time.
The purchased resources in the current region are displayed in a list. You can view the resource type, billing mode, order No., payment method, specifications, creation time, and expiration time.
Resettable: Yes | Daily indicates that the resources in Security Data Collection, Security Data Retention, and Security Modeling And Analysis resource packages in the can be reset by day. Take SecMaster professional edition as an example: If you have purchased a 5-GB Security Data Collection resource package, you have a 5-GB traffic quota for daily security data collection within the validity period of the package.
You can buy a value-added package, change the specifications, change the billing mode to yearly/monthly, batch renew resources, and renew a resource.
- Click Buy Value-added Pack to go to the Buy Value-added Package page. For details, see Buying a Value-Added Package.
- Click Change Specifications to go to the Upgrade SecMaster page. For details, see Upgrading an Edition.
- Click Change to Yearly/Monthly to go to the Change Subscription page. Only pay-per-use resources can be changed to yearly/monthly subscription. For details, see Changing the Billing Mode from Pay-per-Use to Yearly/Monthly.
- Select resources and click Renew above the resource list. The renewal page is displayed. For details, see Renewal Overview.
- Click Renew in the Operation column of a resource. The renewal page is displayed. For details, see Renewal Overview.
Usage analysis
The usage of purchased resources in the current region is displayed in a list. You can view the resource type, billing mode, total quota, usage, available quota, and threshold.
- The prerequisites for using threshold alarm notifications are as follows:
- You have created and subscribed to a topic so that you can receive notifications from SecMaster. For details, see Creating and Subscribing to a Topic.
- You have obtained the SMN ReadOnlyAccess permission for read-only permission of SMN. For details, see SMN ReadOnlyAccess Permission.
- You can set a usage threshold for purchased resources. In the Operation column of the target resource type, click Configure Alert.
- The Threshold column of the target resource type can be edited. Move the cursor to the text box to view the value range of the threshold, enter a value that meets the value range, and click Save in the Operation column.
- Enable Alarm Notification below the usage analysis table and select SMN topic for Alert Method.
- Click Apply. The usage alarm setting is complete. Figure 2 Usage analysis
| Permission | Description | Principal | Usage |
| SMN ReadOnlyAccess | Read-only permissions for SMN. Users with this permission can only view SMN data. | SecMaster_Agency | Used for message notification. |
Perform the following steps to check whether SecMaster has obtained the SMN ReadOnlyAccess permission: If the permission is not allocated, allocate it to SecMaster by referring to Authorizing SecMaster.
- Log in to the SecMaster console as an administrator.
- Click
in the upper left corner of the page and choose Management & Governance > Identity and Access Management. - In the navigation pane on the left, choose Agencies. On the Agencies page, click SecMaster_Agency and then click the Permissions tab to view all authorization records of SecMaster_Agency.
- In the upper left corner of the page, click
and choose . - Create a topic.
- In the navigation pane on the left, choose . In the upper right corner of the displayed page, click Create Topic. Figure 3 Create Topic
- In the Create Topic dialog box displayed, configure topic information and click OK.
- Topic Name: Set it to SecMaster-Notification.
- Display Name: SecMaster notification topic is recommended.
- Retain default values for other parameters.
Topic Name must be set to SecMaster-Notification, or playbooks may fail to be executed.
- Add a subscription.
- On the Topics page, locate the row that contains the SecMaster-Notification topic and click Add Subscription in the Operation column.
- On the displayed Add Subscription slide-out panel, configure subscription information and click OK.
- Protocol: Select a notification method based on your needs. Email is used as an example.
- Endpoint: Enter the email address of the subscription endpoint, for example, username@example.com.
- Confirm the subscription.
After a subscription is added, a confirmation email will be sent to the email address set in 4. Click the subscription confirmation link in the email. A page for a successful subscription will be displayed.
