Functions
The syntax of a complete analysis statement is as follows:
1 2 3 4 |
SELECT [DISTINCT] (* | expression) [AS alias] [, ...] [GROUP BY expression [, ...] [HAVING predicates]] [ORDER BY expression [ASC | DESC] [, ...]] [LIMIT size OFFSET offset] |
This section describes functions.
Mathematics Functions
Function |
Purpose |
Description |
Example Value |
abs |
Absolute value |
abs(number T) -> T |
SELECT abs(0.5) LIMIT 1 |
add |
Addition |
add(number T, number) -> T |
SELECT add(1, 5) LIMIT 1 |
cbrt |
Cubic root |
cbrt(number T) -> T |
SELECT cbrt(0.5) LIMIT 1 |
ceil |
Rounded up |
ceil(number T) -> T |
SELECT ceil(0.5) LIMIT 1 |
divide |
Division |
divide(number T, number) -> T |
SELECT divide(1, 0.5) LIMIT 1 |
e |
Natural base number e |
e() -> double |
SELECT e() LIMIT 1 |
exp |
Power of the natural base number e |
exp(number T) -> T |
SELECT exp(0.5) LIMIT 1 |
expm1 |
Subtract one from the power of the natural base number e. |
expm1(number T) -> T |
SELECT expm1(0.5) LIMIT 1 |
floor |
Rounded down |
floor(number T) -> T |
SELECT floor(0.5) AS Rounded_Down LIMIT 1 |
ln |
Returns the natural logarithm. |
ln(number T) -> double |
SELECT ln(10) LIMIT 1 |
log |
Logarithm with T as the base |
log(number T, number) -> double |
SELECT log(10) LIMIT 1 |
log2 |
Logarithm with 2 as the base |
log2(number T) -> double |
SELECT log2(10) LIMIT 1 |
log10 |
Logarithm to base 10 |
log10(number T) -> double |
SELECT log10(10) LIMIT 1 |
modulus |
Remainder |
modulus(number T, number) -> T |
SELECT modulus(2, 3) LIMIT 1 |
multiply |
Multiplication |
multiply(number T, number) -> number |
SELECT multiply(2, 3) LIMIT 1 |
pi |
π |
pi() -> double |
SELECT pi() LIMIT 1 |
pow |
T power of |
pow(number T, number) -> T |
SELECT pow(2, 3) LIMIT 1 |
power |
T power of |
power(number T) -> T, power(number T, number) -> T |
SELECT power(2, 3) LIMIT 1 |
rand |
Random number. |
rand() -> number, rand(number T) -> T |
SELECT rand(5) LIMIT 1 |
rint |
Discard decimals. |
rint(number T) -> T |
SELECT rint(1.5) LIMIT 1 |
round |
Round off |
round(number T) -> T |
SELECT round(1.5) LIMIT 1 |
sign |
Symbol |
sign(number T) -> T |
SELECT sign(1.5) LIMIT 1 |
signum |
Symbol |
signum(number T) -> T |
SELECT signum(0.5) LIMIT 1 |
sqrt |
Square root |
sqrt(number T) -> T |
SELECT sqrt(0.5) LIMIT 1 |
subtract |
Subtraction |
subtract(number T, number) -> T |
SELECT subtract(3, 2) LIMIT 1 |
Division |
number / number -> number |
SELECT 1 / 100 LIMIT 1 |
Remainder |
number % number -> number |
SELECT 1 % 100 LIMIT 1 |
Trigonometric Functions
Functions |
Purpose |
Description |
Example Value |
acos |
Arc cosine |
acos(number T) -> double |
SELECT acos(0.5) LIMIT 1 |
asin |
Arc sine |
asin(number T) -> double |
SELECT asin(0.5) LIMIT 1 |
atan |
Inverse tangent |
atan(number T) -> double |
SELECT atan(0.5) LIMIT 1 |
atan2 |
T Arc tangent of the result of dividing U |
atan2(number T, number U) -> double |
SELECT atan2(1, 0.5) LIMIT 1 |
cos |
Cosine |
SELECT cos(0.5) LIMIT 1 |
cosh |
hyperbolic cosine |
cosh(number T) -> double |
SELECT cosh(0.5) LIMIT 1 |
cot |
Cotangent |
cot(number T) -> double |
SELECT cot(0.5) LIMIT 1 |
degrees |
Converting radians into degrees |
degrees(number T) -> double |
SELECT degrees(0.5) LIMIT 1 |
radians |
Converting degrees into radians |
radians(number T) -> double |
SELECT radians(0.5) LIMIT 1 |
sin |
Sine |
SELECT sin(0.5) LIMIT 1 |
sinh |
hyperbolic sine |
sinh(number T) -> double |
SELECT sinh(0.5) LIMIT 1 |
tan |
Tangent |
SELECT tan(0.5) LIMIT 1 |
Temporal Functions
Function |
Purpose |
Description |
Example Value |
curdate |
Specifies the current date. |
curdate() -> date |
SELECT curdate() LIMIT 1 |
date |
Date |
date(date) -> date |
SELECT date() LIMIT 1 |
date_format |
Obtains the date value based on the format. |
date_format(date, string) -> string |
SELECT date_format(date, 'Y') LIMIT 1 |
day_of_month |
Month |
day_of_month(date) -> integer |
SELECT day_of_month(date) LIMIT 1 |
day_of_week |
Day of week |
day_of_week(date) -> integer |
SELECT day_of_week(date) LIMIT 1 |
day_of_year |
Number of days in the current year |
day_of_year(date) -> integer |
SELECT day_of_year(date) LIMIT 1 |
hour_of_day |
Number of hours on the current day |
hour_of_day(date) -> integer |
SELECT hour_of_day(date) LIMIT 1 |
maketime |
Date of Generation |
maketime(integer, integer, integer) -> time |
SELECT maketime(11, 30, 00) LIMIT 1 |
minute_of_hour |
Number of minutes in the current hour |
minute_of_hour(date) -> integer |
SELECT minute_of_hour(date) LIMIT 1 |
minute_of_day |
Number of minutes on the current day |
minute_of_day(date) -> integer |
SELECT minute_of_day(date) LIMIT 1 |
monthname |
Month Name |
monthname(date) -> string |
SELECT monthname(date) LIMIT 1 |
now |
Current time. |
now() -> time |
SELECT now() LIMIT 1 |
second_of_minute |
Number of seconds |
second_of_minute(date) -> integer |
SELECT second_of_minute(date) LIMIT 1 |
timestamp |
Date |
timestamp(date) -> date |
SELECT timestamp(date) LIMIT 1 |
year |
Year |
SELECT year(date) LIMIT 1 |
Text Functions
Function |
Purpose |
Description |
Example Value |
ascii |
ASCII value of the first character |
ascii(string T) -> integer |
SELECT ascii('t') LIMIT 1 |
concat_ws |
Connection String |
concat_ws(separator, string, string) -> string |
SELECT concat_ws('-', 'Tutorial', 'is', 'fun!') LIMIT 1 |
left |
Obtain a character string from left to right. |
left(string T, integer) -> T |
SELECT left('hello', 2) LIMIT 1 |
length |
length |
length(string) -> integer |
SELECT length('hello') LIMIT 1 |
locate |
Search for a string |
locate(string, string) -> integer |
SELECT locate('o', 'hello') LIMIT 1 |
replace |
Replace strings |
replace(string T, string, string) -> T |
SELECT replace('hello', 'l', 'x') LIMIT 1 |
right |
Obtain a character string from right to left. |
right(string T, integer) -> T |
SELECT right('hello', 1) LIMIT 1 |
rtrim |
Remove the empty characters on the right. |
rtrim(string T) -> T |
SELECT rtrim('hello ') LIMIT 1 |
substring |
Obtaining a Substring |
substring(string T, integer, integer) -> T |
SELECT substring('hello', 2,5) LIMIT 1 |
trim |
Remove empty character strings on both sides. |
SELECT trim(' hello ') LIMIT 1 |
upper |
Convert all letters into uppercase letters. |
upper(string T) -> T |
SELECT upper('helloworld') LIMIT 1 |
Other
Function |
Purpose |
Description |
Example Value |
if |
if condition |
if(boolean, object, object) -> object |
SELECT if(false, 0, 1) LIMIT 1 , SELECT if(true, 0, 1) LIMIT 1 |
ifnull |
If the field is null, the default value is used. |
ifnull(object, object) -> object |
SELECT ifnull('hello', 1) LIMIT 1 , SELECT ifnull(null, 1) LIMIT 1 |
isnull |
Indicates whether a field is null. If yes, 1 is returned. If no, 0 is returned. |
isnull(object) -> integer |
SELECT isnull(null) LIMIT 1 , SELECT isnull(1) LIMIT 1 |
