Creating a Workspace
Workspaces are top-level workbenches in SecMaster. A workspace can be associated with common projects and regions to support workspace operations in different application scenarios.
Before using baseline checks, alert management, log audit, and security orchestration in SecMaster, you need to create at least one workspace first. You can use workspaces to group your resources by application scenario. This will make security operations more efficient.
This section describes how to create a workspace.
Notes and Constraints
- Paid SecMaster: A maximum of five workspaces can be created for an account in a region.
- Free SecMaster: Only one workspace can be created for an account in a region.
- The newly created workspace needs to be initialized. After the workspace is created, wait for about 10 minutes and refresh the page to view the workspace. You can check workspaces by referring to Viewing a Workspace.
- Your authorization is required the first time you try to use SecMaster. For details, see Authorizing SecMaster.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. Figure 1 Workspaces > Management
- (Optional) Complete authorization. Authorization is required only the first time you access the workspace management page.
- In the upper part of the workspace management page, choose Entrusted Service Authorization - Current Tenant.
- On the page for assigning permissions, select all required permissions (which are selected by default), select Agree to authorize, and click Confirm.
- On the Management page, click Create. The Create Workspace slide-out panel is displayed.
- Configure workspace parameters by referring to the following table.
Table 1 Parameters for creating a workspace Parameter
Region
Select the region where you want to create the workspace.
Project Type
Select the type of project that the workspace you want to create belongs to.
Workspace Name
Specify the workspace name. The name must meet the following requirements:
- Only letters (A to Z and a to z), numbers (0 to 9), and the following special characters are allowed: -_()
- A maximum of 64 characters are allowed.
Tag (Optional)
(Optional) Tag of the workspace, which is used to identify the workspace and help you classify and track your workspaces.
TMS's predefined tag function is recommended for adding the same tag to different cloud resources. You can also create tags when purchasing SecMaster.
Description (Optional)
(Optional) You provide a description of the workspace.
- Click OK.
- Choose in the navigation pane on the left. On the displayed page, check the new workspace.
New Workspace Initialization
After a workspace is created, the system initializes layouts, operations objects, playbook orchestration, cloud service access, and models. The details are as follows:
- Layout initialization: When a workspace is created, its layout is initialized. A layout determines how pages in the service are displayed. Go to the Workspaces page and choose in the navigation pane on the left. The layout management page is displayed by default. You can view the preset layout. When a workspace is created, the following content is initialized in the preset layout: alert list, alert details, incident list, incident details, indicator list, indicator details, vulnerability list, vulnerability details, asset list, asset details, daily report, monthly report, and weekly report. For details about how to view the layout, see Viewing a Layout.
- Operations object initialization: You can check basic concepts of operations objects in Overview. Data classes and types are initialized during workspace initialization.
- Initialized data classes: indicator, vulnerability, common context, policy record, policy, alert, asset, service system, baseline check, department, incident, and evidence. For details about data class management, see Viewing Data Classes.
- Initialization types: alert, incident, threat intelligence, and vulnerability types. For details about built-in types, see Built-in Types. To view their details, see Viewing Alert Types, Viewing Incident Types, Viewing Indicator Types, and Viewing Existing Vulnerability Types.
- Playbook orchestration initialization: To learn about what is a playbook or workflow, see Overview. When a workspace is added, some playbooks, workflows, and plugins will be initialized.
Table 2 Initialized playbooks, workflows, and plugins Category
Initialization Content
Playbooks
Server vulnerability notification
Asset protection status statistics notification
New server protection status notification
Alert metric extraction
Automated handling of host Rootkit event attacks
WAF Synchronizes Black IP Addresses to Intelligence
CFW Synchronizes Black IP Addresses to Intelligence
HSS alert synchronization
Network Defense Alarms Are Associated With Historical Handling Information
Identity Defense Alarms Are Associated With Historical Handling Information
Application Defense Alarms Are Associated With Historical Handling Information
Host Defense Alarms Are Associated With Historical Handling Information
Unified buy
Real-time Notification of Critical Organization and Management Operations
Automatic Disabling of Repeated Alerts
Attack Link Analysis Alert Notification
HSS Isolation and Killing of Malware
Automatic Notification of High-Risk Alerts
Automatic clearing of low-risk alerts
Automated handling of host rebound Shell attacks
SecMaster WAF Address Group Association Policy
Web login burst interception
IP intelligence association
Automatic renaming of alert names
Auto High-Risk Vulnerability Notification
Mining host isolation
Alert statistics Notify
Auto Blocking for High-risk Alerts
Alert IP metric labeling
HSS High-Risk Alarm Interception Notification
Ransomware host isolation
WAF clear Non-domain Policy
Workflows
CIS_PostgreSQL Restricting the IP Addresses That Can Connect to Databases
Asset protection information notification
Host Auto Storage AirGap Breaker
CIS_MySQL Enabling Database Audit Log
Policy Management_VPC
Auto Host Backup and Copy Tampering Prevention
Unbinding The WAF IP Group from Policies
CIS_Enabling ECS Logs in LTS
CIS_Enabling ELB Access Logging
CIS_Enabling LTS and Collecting Container Logs
CIS_Ensuring That the Minimum Password Age Is Set
One-click WAF blocking
CIS_Enabling FunctionGraph Logging
Policy Management – Cancel CFW blocking
Policy Management – WAF blocking
CIS_Enabling MFA for the Administrator Account
Create Intelligence
Host defense alarms are associated with historical handling information - Threat Modeling - Login
CIS_Enabling Re-confirmation for Deleting Backup Data
CIS_DDS Enabling Encrypted Communication
CIS_Using a Dedicated Resource Pool
CIS_Enabling Access Key Management
One-click unblocking
CIS_MySQL Disabling Default Ports
WAF address group association policy
CIS_Using an IP Address Whitelist for Access to Notebook
Medium-Risk Host Auto Snapshot and Policy Configuration
CIS_GaussDB WAL Archiving Configuration
Policy Management_CFW
CIS_Enabling the Key Event Notifications in CTS
CIS_DDS Setting Maximum Connections
CIS_Ensuring That Only One Active Access Key Is Available for an IAM User
CIS_PostgreSQL Enabling Log Recording for User Logins
CIS_DDS Setting Second-Level Monitoring and Alarm Rules
High-Risk Host Auto Snapshot and Policy Configuration
Querying historical alarms
CIS_GaussDB User Password Security
CIS_Enabling Encryption for Private Images
CIS_Enabling Kerberos Authentication
Policy Management – IAM interception for policy delivery
CIS _MySQL Avoiding Binding an EIP to Access RDS for MySQL over Internet
Policy Management_WAF
Policy Management – Cancel WAF blocking
CIS_GaussDB Security Authentication
Policy Management_IAM
One-click host de-isolation
CIS_GaussDB Configuring Maximum Number of Concurrent Database Connections
Vulnerability handling
Automatic Renaming of Alert Names
CIS_PostgreSQL Enabling the Backup Function and Configuring a Backup Policy
CIS_PostgreSQL Disabling Default Ports
CIS_DDS Enabling Database Audit Log
CIS_Ensuring IAM Policies Are Not Created to Allow Wildcard Administrative Permissions
Real-time Close Alert Automatically
One-click CFW blocking
CIS_Using a Key Pair to Securely Log In to a BMS
CIS_PostgreSQL Enabling Database Audit Log
CIS_Enabling the CFW Log Management Capability
CIS_Creating an IAM User with Non-Administrator Permissions
CIS_Protecting the Cluster API Server
CIS_Preventing Cluster Nodes from Being Exposed to Public Networks
Adding IP address to alert
Labeled Hosts Backup
CIS_MySQL Updating the Database Version to the Latest
Host defense alarms are associated with historical handling information - Threat Modeling - Process
One-click CFW unblocking
CIS_PostgreSQL Configuring a Client Authentication Timeout
CIS_Enabling the Container Security Edition of HSS
Low-Risk Host Auto Snapshot and Policy Configuration
Host Defense Alarms Are Associated With Historical Handling Information - Automatic conversion to alerts.
One-click Blocking
Unified buy
CIS_Creating a VPC Flow Log
Policy Management – Policy Delivery IAM Decapsulation
CIS_Enabling Log File Integrity Verification
CIS_Configuring an ACL
CIS_Enabling Encrypted Storage of Log Files
Report Baseline Check Results
One-click WAF unblocking
Policy Management – CFW blocking
Host Isolation - Malware
Policy Management – Security group blocking
Policy Management – Security group blocking cancellation
One-click host isolation
CIS_DDS Enabling Disk Encryption
CIS_DDS Disabling the Script Running Function
Plugins
SecMasterWebTools
SMN
DDS
ELB
EPS
IMS
LTS
CFW
Kafka
SFS
SecMasterBiz
CSBS
VPC
HTTP
DBSS
HSS
ECS
BSS
IAM
ThreatBook
HBRD
EVS
SecMasterUtilities
RMS
EIP
OBS
WAF
CCE
VoiceCall
RDS
CTS
BMS
MRS
APIE
- Cloud service access initialization: Logs of other cloud services are aggregated to SecMaster. For details about the cloud service logs that can be accessed by SecMaster, see Cloud Service Log Access Supported by SecMaster. For details about how to manually access cloud service logs, see Enabling Log Access. The following table lists the cloud service logs that are accessed by default when a workspace is created.
Table 3 Logs accessed by default Service
Service Type
Log
Log Description
Host Security Service (HSS)
Tenant-side cloud service
hss-alarm
HSS security alarms
hss-log
HSS security logs
Web Application Firewall (WAF)
waf-attack
WAF attack logs
waf-access
WAF access logs
Cloud Trace Service (CTS)
cts-audit
CTS logs
NIP
Huawei device
nip-attack
IPS attack logs
Cloud Firewall (CFW)
cfw-block
Access control logs
cfw-risk
Attack logs
- Model initialization: SecMaster uses models to scan logs in pipelines. If SecMaster detects data that hits the trigger in a model, SecMaster generates an alert. Models are created based on templates. So you need to use available model templates to create models. SecMaster provides multiple model templates based on common scenarios. When a workspace is created, some models are automatically created by default. For details about how to view models, see Viewing a Model. For details about how to manage models, see Managing Models.
| Category | Initialization Content |
| Model | Application - Distributed URL Traversal Attack |
| Application - Source IP Brute-Forcing Domain Names | |
| Application - Source IP Conducting URL Traversal | |
| Application - WAF Key Attack Alert | |
| Host - Virtual Machine Lateral Connection | |
| Network - High-Risk Port Exposure to the Outside | |
| Network - Login Brute Force Alarm | |
| HSS - Abnormal Network Connection | |
| Network - Source IP Attacking Multiple Targets | |
| Network - Command Injection Alert | |
| Network - Malicious External Communications | |
| Host - Rootkit Events | |
| Host - Reverse Shell | |
| Host - Remote Login | |
| Host - Abnormal Shell | |
| Host - Weak Password | |
| Host - Malware | |
| Host - Brute Force Crack Success | |
| Host - High-risk Command Detection | |
| Network - Abnormal connection detection | |
| Network - Hacking tool detection | |
| Network - Malware (worms, viruses, Trojans) detection | |
| Network - Botnets | |
| Network - Backdoors | |
| Application - Possible source code leakage risks | |
| Application - Possible Log4j 2 vulnerabilities | |
| O&M - Attaching a NIC | |
| O&M - Creating a VPC peering connection | |
| O&M - Binding EIPs to resources | |
| Application - Possible Fastjson vulnerabilities | |
| Application - Possible Java framework common code execution vulnerabilities | |
| Application - Possible Apache Shiro vulnerabilities | |
| Network - Abnormal CFW external connections | |
| Network - Suspicious DoS attacks | |
| Application - Login Brute Force Attack | |
| Host - Abnormal file attribute modifications | |
| Host - Malicious scheduled tasks | |
| Host - Hidden processes and ports | |
| Host - Abnormal file permission modifications | |
| HSS - Key file path change | |
| Host - Abnormal outbound connections | |
| Host - File/Directory changes | |
| Host - Brute force cracking attempt | |
| Host - File accessed by suspicious process | |
| Host - Container Startup Exception | |
| Host - Untrusted Process Execution | |
| Host - Suspicious Crontab Task | |
| Host - User Account Change | |
| Network - CFW Malicious External Attacks |
Operations You Can Do with a Workspace
You can perform security operations after adding a workspace. Functions you can use vary depending on the SecMaster edition in use. For details, see Functions.
- Checking the Situation Overview, Checking Security Situation Through Large Screens, Security Reports, and Task Center: Check the security situation in a workspace, create security reports, handle to-do tasks, and check security situation on large screens.
- Resource Manager: Manage assets centrally.
- Risk Prevention: Reduce risks through baseline checks, vulnerability management, emergency vulnerability notifications, and security policy management.
- Threats: Manage threats, including incidents, alerts, and indicators.
- Security Orchestration: Implement security orchestration. Security orchestration combines security functions of different systems or components in a system involved in security operations in your organization based on certain logical relationships to complete a specific security operations process and procedure. It aims to help security teams of enterprises and organizations quickly and efficiently respond to network threats and implement efficient and automatic response and handling of security incidents. You can manage operations objects, playbooks, page layouts, plugins, and directories.
