On this page
Handling Events
Updated on 2023-05-16 GMT+08:00
After you receive an event, you can mark its processing status.
  • Ignore: If the event does not cause any harm, ignore the result. After click Ignore, record the Handler and Reason in the Ignore Risk dialog box.
  • Mark as Offline: If the event has been handled offline, click Mark as Offline in the Operation column. In the displayed dialog box, fill in Processor, Processing Time, and Processing Result, and click OK.
On the Events page, SA also aggregates alarm data reported by other security services, such as Host Security Service (HSS), and Web Application Firewall (WAF). When you handle these alarms, follow the sequence below:
  1. View the Product Name column to locate the source service that reports an alarm to SA.
  2. Go to the source service to handle the alarm.
  3. Mark the alarm in SA after it is handled in the source service.
For example, if an event is reported by HSS, it is recommended that you handle the alarm on the HSS console first and then mark the alarm in SA.
SA has received events from other security products.
  2. Click in the upper left corner of the page and choose Security & Compliance > Situation Awareness.
  3. In the navigation pane on the left, choose Events.
    Figure 1 Processing events
  4. Filter events.
  5. Mark events in batches.
    Select one or more events in the Unhandled status and click Ignore or Mark as Offline above the result list to handle all selected events at a time.
  6. Mark an event.
    • In the Operation column of the event you want to mark, click Ignore or Mark as Offline.
    • Alternatively, you can mark a single event on its Result Details page by clicking Ignore or Mark as Offline at the lower right corner.
