CTS
The CTS connector interconnects with Cloud Trace Service (CTS) of Huawei Cloud.
CTS records operations on the cloud resources in your account. You can use the logs generated by CTS to perform security analysis, track resource changes, audit compliance, and locate faults.
Creating a CTS Connection
- Log in to the ROMA Connect console.
- In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
- Select the CTS connector.
- In the dialog box displayed, configure the connector and click OK.
Name
Enter a connector instance name.
App Key
AK of the current account. Obtain the AK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
App Secret
SK of the current account. Obtain the SK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
Enter the description of the connector to identify it.
Actions
- Deleting a tracker
- Querying trackers
- Creating a tracker
- Modifying a tracker
- Querying the trace list
Configuring Parameters
For details about the parameters, see the API Reference of CTS.
