On this page
Help Center/ ROMA Connect/ User Guide/ Service Integration Guide/ Exposing an API/ (Optional) Creating a Load Balance Channel
Updated on 2024-11-27 GMT+08:00
This channel allows ROMA Connect to access backend services deployed on servers in load balancing mode (direct access to ECSs in the same VPC, or to ECSs in other VPCs and private servers by specifying IP addresses).
For example, six ECSs deployed in a VPC have a load balance channel to reach ECS 1 and ECS 4. ROMA Connect can access these two ECSs through the channel.
  • The network between ROMA Connect and the servers in the load balance channel is working.
    • Same VPC: Let the instance directly access the servers.
    • Two VPCs in the same region: Connect the instance and the servers with a peering connection. For details, see VPC Peering Connection.
    • Two VPCs in two regions: Create a cloud connection and load the VPCs that need to communicate with each other. For details, see Network Communications Among VPCs Across Regions.
    • Communication over the public network: Ensure that the ROMA Connect instance has been bound with an EIP.
  • You have the VPC Administrator permission.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console of an instance.
  2. In the navigation pane on the left, choose API Connect > API Policies. On the Load Balance Channels tab, click Create Load Balance Channel.
  3. On the page displayed, configure the following parameters.
    Table 1 Load balance channel parameters
    Name
    Enter a load balance channel name. Using naming rules facilitates future search.
    Port
    Enter the access port number in the load balance channel.
    Routing Algorithm
    Select an algorithm for routing backend service requests. The channel determines the server to which the requests are to be sent by the algorithm.
  4. Configure servers.
    1. Select a mode for adding servers to the load balance channel. This mode cannot be changed once the channel is created.
      • Select cloud servers from the list.
      • Specify IP addresses of the servers.
    2. Click Create Server Group. In the dialog box displayed, configure the following parameters and click OK.
      Servers can be added to different groups.
      Table 2 Server group parameters
      Group Name
      Enter a server group name. Using naming rules facilitates future search.
      Weight
      Enter the weight of the server group. The larger weight, the more requests that can be forwarded to the servers in the group.
      Enter a brief description of the group.
    3. Add servers to the load balance channel.
      • Add cloud servers.
        1. Click Add Cloud Server.
        2. In the dialog box displayed, select a subnet, select the cloud servers to be added, and click OK.
        3. Configure the following parameters.
          Table 3 Cloud server parameters
          Standby Node
          After you enable this option, the backend server serves as a standby node. It works only when all non-standby nodes are faulty.
          Port
          Enter the access port number of the backend server.
          0: uses the port of the load balance channel.
          Server Status
          Specify whether to enable the server.
          When enabled: Requests are distributed to the server.
      • Add a backend server address.
        1. Click Add Backend Server Address.
        2. Configure the following parameters.
          Table 4 Backend server parameters
          Enter the IP address of the backend server.
          Standby Node
          Port
          Server Status
  5. Configure the health check (enabled by default), or disable this parameter.
    Table 5 Health check parameters
    Protocol
    Select the protocol used for the health check.
    Options: TCP, HTTP, HTTPS
    Two-way Authentication
    Available for Protocol set to HTTPS.
    Specify whether to enable two-way authentication between ROMA Connect and backend servers.
    Path
    Mandatory for Protocol set to HTTP or HTTPS.
    Enter the health check URL.
    Method
    Select the HTTP request method used for the health check.
    Options: GET or HEAD
    Check Port
    Destination port of the health check.
    Default: uses the port number configured for the load balance channel.
    Healthy Threshold
    Number of consecutive successful checks required for an ECS to be considered healthy. Example: If set to 2, ROMA Connect declares the ECS status to be healthy when the check is successful twice in a row.
    Unhealthy Threshold
    Number of consecutive failed checks required for an ECS to be considered unhealthy. Example: If set to 5, ROMA Connect declares the ECS status to be abnormal when the check fails five times in a row.
    Timeout (s)
    Response timeout of a health check, in seconds. If no response is received within this time, the health check fails.
    Interval (s)
    Interval between consecutive checks, in seconds.
    Status Codes
    When the server returns a specified HTTP response code, the server considers the response to be successful.
    Supports multiple response codes.
  6. Click Finish.
