Viewing API Call Logs
Updated on 2024-05-07 GMT+08:00
Overview
View API call logs on the ROMA Connect console.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console of an instance.
  2. In the navigation pane on the left, choose API Connect > API Analysis.
  3. Enable log analysis.
    1. On the Access Logs tab page, click Configure Access Log.
    2. In the Configure Access Log dialog box, configure log access information and click OK.
      Table 1 Parameters for configuring access logs
      Collect Access Logs
      Determine whether to enable logging. API call logs can be viewed only after you enable Collect Access Logs.
      Log Group
      Select the log group to which the log stream belongs.
      If no log group is available, click View Log Group to switch to the LTS console and create a log group. For details, see Creating a Log Group.
      Log Stream
      Select the log stream for storing the API call logs.
      If no log stream is available, click View Log Stream to switch to the LTS console and create a log stream. For details, see Creating a Log Stream.
  4. After the log analysis function is enabled, view the call logs of all open APIs in real time on the console. For details about the log fields, see Log Field Description.
    • In the upper right corner of the page, select a time segment.
    • Click View Log to go to the LTS console to view log details and download logs locally.
      Custom fields in log details:
      • _resource_id: ROMA Connect instance ID
      • _service_type: source service
No.
Field
remote_addr
Client IP address
2
request_id
Request ID
3
api_id
API ID
4
user_id
Project ID provided by a requester for IAM authentication.
5
app_id
Application ID provided by a requester using App authentication
6
time_local
Request time
7
request_time
Request latency, in seconds
8
request_method
HTTP request method
9
host
Request domain name
10
router_uri
Request URI
11
server_protocol
Request protocol
12
status
Response code
13
bytes_sent
Response size (including the status line, response header, and response body), in bytes
14
request_length
Request length (including the start line, request header, and request body), in bytes
15
http_user_agent
User agent ID
16
http_x_forwarded_for
X-Forwarded-For header field
17
upstream_addr
Backend address
18
upstream_uri
Backend URI
19
upstream_status
Backend response code
20
upstream_connect_time
Time taken for establishing a connection with the backend
21
upstream_header_time
Duration from the beginning of the establishment of a connection to receiving the first byte from the backend, in seconds
22
upstream_response_time
Duration from the beginning of the establishment of a connection to receiving the last byte from the backend, in seconds
23
region_id
AZ ID
24
all_upstream_response_time
Duration from the beginning of the establishment of a connection to receiving the last byte from the backend, in seconds. When a retry occurs, the value is the total time used.
25
errorType
Request error type. Options:
  • 0: non-throttling error
  • 1: throttling error
26
auth_type
API authentication mode
27
access_model1
Authentication mode 1
28
access_model2
Authentication mode 2. When two-factor authentication is enabled, the custom authorizer ID is used.
29
inner_time
Internal processing duration of APIC, in seconds
30
proxy_protocol_vni
VPC endpoint virtual network ID
31
proxy_protocol_vpce_id
VPC endpoint ID
32
proxy_protocol_addr
Client IP address
33
body_bytes_sent
Size of the API request body, in bytes
34
api_name
API name
35
app_name
Name of the application used by the requester when App authentication is used
36
provider_app_id
ID of the application to which the API belongs
37
provider_app_name
Name of the application to which the API belongs
38
custom_data_log1
Custom log field 1
39
custom_data_log2
Custom log field 2
40
custom_data_log3
Custom log field 3
41
custom_data_log4
Custom log field 4
42
custom_data_log5
Custom log field 5
43
custom_data_log6
Custom log field 6
44
custom_data_log7
Custom log field 7
45
custom_data_log8
Custom log field 8
46
custom_data_log9
Custom log field 9
47
custom_data_log10
Custom log field 10
48
response_source
Request response source. Options:
  • local: APIG
  • remote: backend service
