On this page
Creating a Topic
Updated on 2024-06-25 GMT+08:00
Overview
Create a topic for storing messages so that producers can publish messages and consumers can subscribe to messages in it.
Each topic must belong to an integration application. Before creating a topic, ensure that an integration application is available. Otherwise, create an integration application first.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console of an instance.
  2. In the navigation pane, choose Message Queue Service > Topic Management. On the page displayed, click Create Topic in the upper right corner.
  3. In the dialog box displayed, configure topic information and click OK.
    Table 1 Parameters for creating a topic
    Topic Name
    Enter a topic name. Using naming rules facilitates future search.
    Periods (.) and underscores (_) cannot be used to distinguish names. For example, if you create a topic named Topic.test first, you cannot create another topic named Topic_test.
    Integration Application
    Select the integration application to which the topic belongs.
    Permission
    Select the permission on a topic for the integration application to which the topic belongs.
    • Publish/Subscribe: Messages can be published to and subscribed from the topic.
    • Publish: Messages can only be published to the topic.
    • Subscribe: Messages can be subscribed only in the topic.
    Partitions
    Set the number of partitions of a topic to improve the concurrent performance of message production and consumption.
    If this parameter is set to 1, messages will be consumed in the FIFO order.
    Replicas
    Set the number of replicas of a topic. ROMA Connect automatically backs up data on each replica. If one replica is faulty, data will still be available. The reliability increases with the number of replicas of a topic.
    If a broker is faulty, an internal error will occur when you query messages using a topic with only one replica. Use topics with more than one replica instead.
    Aging Time (h)
    Set the aging time of messages stored in the topic. Messages that exceed the aging time will be deleted.
    Synchronous Replication
    When a client creates a message to a topic, ROMA Connect determines whether to replicate the message to all replicas and then returns a response to the client.
    After synchronous replication is enabled, you also need to set acks to -1 on the client. Otherwise, synchronous replication will not take effect.
    Synchronous Flushing
    This parameter specifies whether each message created by a client to the topic is immediately written to the disk. When synchronous flushing is enabled, the reliability is enhanced.
    Tag Name
    Add message publishing and subscription tags for the integration application to which a topic belongs. Generally, you do not need to add the tags. The tags are used only in special service scenarios.
    After a tag is added, the client needs to transmit the tag information when publishing and subscribing to messages in the topic. If there are multiple tags, the tags transmitted by the client must be a subset of the tags contained in the topic.
    Sensitive Word
    Enter values to filter out topic messages containing these values.
    Enter a brief description of the topic.
