On this page
Help Center/ ROMA Connect/ User Guide/ Data Source Management/ Connecting to a PostgreSQL Data Source
Updated on 2024-05-07 GMT+08:00
Overview
ROMA Connect can use the PostgreSQL/openGauss data source for creating data integration tasks or data APIs. Before using this data source, connect it to ROMA Connect.
Each connected data source must belong to an integration application. Ensure that an integration application is available before connecting a data source, or create one first.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console of an instance.
  2. In the navigation pane on the left, choose Data Sources. In the upper right corner of the page, click Access Data Source.
  3. On the Default tab page, select PostgreSQL and click Next.
  4. Configure the data source connection information.
    Table 1 Data source connection information
    Name
    Enter a data source name. Using naming rules facilitates future search.
    Encoding Format
    Default: utf-8
    Integration Application
    Select the integration application to which the data source belongs.
    Enter a brief description of the data source.
    Connection Mode
    Select a database connection mode.
    • Default: The system automatically concatenates data source connection character strings based on your configured data.
    • Professional: You need to specify the data source connection string manually.
    Connection Address
    Mandatory only when Connection Mode is set to Default.
    Enter the IP address and port number for connecting the database.
    Database Name
    Enter the name of the database to be connected.
    Connection String
    Mandatory only when Connection Mode is set to Professional.
    Enter the JDBC connection string of the PostgreSQL database, for example, jdbc:postgresql://{hostname}:{port}/{dbname}.
    • {hostname} indicates the IP address for connecting to the database.
    • {port} indicates the port number for connecting to the database.
    • {dbname} indicates the name of the database to be connected.
    Username
    Enter the username for connecting to the database.
    Password
    Enter the password for connecting to the database.
    The connection configuration of the PostgreSQL data source is similar to that of the DB2 data source. For details, see Connecting to a DB2 Data Source.
  5. Click Check Connectivity to check the connectivity between ROMA Connect and the data source.
    • If the test result is Data source connected successfully, go to the next step.
    • If the test result is Failed to connect to the data source, check the data source status and connection parameters, and click Recheck until the connection is successful.
  6. Click Create.
