Updated on 2026-09-16 GMT+08:00
Creating a LINK Device Group
Overview
If there are a large number of devices, manage these devices by creating groups, which helps you quickly search for your desired devices.
Each device group must belong to an integration application. Before creating a device group, ensure that an integration application is available. Otherwise, create an integration application first.
Creating a Root Group
  1. Log in to the ROMA Connect console. In the navigation pane on the left, choose Resource. On the displayed page, click the instance to access its console.
  2. In the navigation pane on the left, choose LINK > Device Management. On the Device Groups tab page, click Create Root Group.
  3. In the Create Root Group dialog box, set group parameters and click OK.
    Table 1 Parameters for creating a root group
    Group Name
    Enter a device group name. It is recommended that you enter a name based on naming rules to facilitate search.
    The value can contain 2 to 64 characters, including letters, digits, underscores (_), and hyphens (-).
    Group Description
    Enter a brief description of the device group.
    Integration Application
    Select the integration application to which the device group belongs.
  4. View the device group list. If the new root group is displayed in the list, the group is created successfully.
Adding a Subgroup
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose LINK > Device Management. On the Device Groups tab page, click a device group for which you want to add a subgroup.
    The newly added subgroup and its devices must belong to the same application.
  3. Click on the right of the device group name.
  4. In the Create Group dialog box, set subgroup parameters and click OK.
    Table 2 Parameters for creating a subgroup
    Parent Group
    Parent group to which a subgroup belongs.
    Group Name
    Enter a subgroup name. It is recommended that you enter a name based on naming rules to facilitate search.
    Group Description
Adding a Device to a Device Group
  2. In the navigation pane on the left, choose LINK > Device Management. On the Device Groups tab page, click a device group for which you want to add a device.
  3. Click Add Device to Group.
  4. In the Add Device to Group dialog box, select the devices to be added and click OK.
