Help Center/ Config/ User Guide/ Resource Compliance/ Built-In Policies/ Relational Database Service/ Error Log Collection Is Enabled for RDS Instances
Updated on 2025-08-25 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
rds-instance-enable-errorLog
Identifier
If error log collection is not enabled for an RDS instance, this instance is non-compliant.
Tag
rds
Trigger Type
Configuration change
Filter Type
rds.instances
Rule Parameters
None
Application Scenarios
RDS log management allows you to view database-level logs, including error logs and slow SQL query logs. Error logs help you analyze problems in databases. You can download error logs for service analysis. For details, see Viewing and Downloading Error Logs.
Solution
Configure error log collection. For details, see Log Configuration Management.
Rule Logic
  • If error logging is not enabled for an RDS DB instance, this instance is non-compliant.
  • If error logging is enabled for an RDS DB instance, this instance is compliant.
