Help Center/
      Relational Database Service_RDS for PostgreSQL/
        User Guide/
        Instance Management/
        Instance Lifecycle/
      Starting an Instance
        Updated on 2025-09-11 GMT+08:00
You can stop your instance temporarily to save money. After stopping your instance, you can restart it to begin using it again.
Billing
After a DB instance is started, the VM where the DB instance is located is billed again.
- If you start a primary instance, read replicas (if there are any) will also be started.
 - When a stopped DB instance is started, a full backup is automatically triggered.
 - Only instances in Stopped state can be started.
 - A stopped pay-per-use instance may fail to start due to insufficient ECS resources. If this happens, try again later. If you need assistance, submit a service ticket.
 - Click
 in the upper left corner and select a region. - Click
 in the upper left corner of the page and choose Databases > Relational Database Service. - On the Instances page, locate the primary instance that you want to start and choose in the Operation column.
 - In the displayed dialog box, click Yes.
     Figure 1 Starting an instance
      - Refresh the instance list and view the status of the instance. If the status is Available, the instance is started successfully.
