Changing the Storage Type
If the storage type of your RDS DB instance does not match your workloads, you can change it as needed.
For details about storage types, see DB Instance Storage Types.
| Phase | Constraints |
| Before the change |
| During the change |
| After the change |
| Instance Type | Original Storage Type | Target Storage Type |
| Single-node or primary/standby instance | Ultra-high I/O | Extreme SSD and Flexible SSD |
| Cloud SSD | Extreme SSD and Flexible SSD |
- Log in to the RDS console.
- Click
in the upper left corner and select a region. - On the Instances page, locate the target DB instance and choose More > Change Instance Class in the Operation column.
Alternatively, click the instance name to go to the Summary page. Under Instance Class, click Configure.
- On the displayed page, select a new storage type and click Next. Figure 1 Changing a storage type
- Confirm the new storage type.
- To modify your settings, click Previous.
- For pay-per-use DB instances, click Submit.
- For yearly/monthly DB instances, click Pay Now. The change starts only after the payment is successful.
- Check the result.
Return to the Instances page. After a few minutes, click the instance name and check the new storage type on the displayed Summary page.
