Connecting to an RDS for PostgreSQL Instance Using pgAdmin
pgAdmin is an administration and development tool for PostgreSQL. Using pgAdmin, you can connect to specific databases from your clients, create tables, and run simple and complex SQL statements. pgAdmin can be used on Windows, Linux, macOS, and other operating systems. The latest version of pgAdmin is based on the browser/server (B/S) architecture. For more information, see the pgAdmin documentation.
This section uses pgAdmin 4-4.17 as an example to describe how to use pgAdmin to connect to an RDS for PostgreSQL instance and create databases and tables.
The pgAdmin version must be 4 or later.
- Obtain the pgAdmin installation package.
Download the pgAdmin installation package for Windows from the pgAdmin official website. The following uses pgAdmin4-4.17 as an example.
- Double-click the installation package and complete the installation as instructed.
- Start the pgAdmin client after the installation.
- In the displayed login window, right-click Servers and choose Register > Server from the shortcut menu. Figure 1 Login information
- On the General page, specify Name. On the Connection page, specify information about the DB instance to be connected. Then, click Save. Figure 2 Entering basic information
Figure 3 Entering connection information
Parameter description:
- Host name/address: indicates the EIP bound to the target DB instance.
- Port: indicates the database port. By default, the value is 5432.
- Username: By default, the value is root.
- Password: indicates the password of the username for accessing the RDS instance.
- In the login window, check that the connection information is correct. The target DB instance is successfully connected.
Basic Database Operations
- In the navigation pane on the left of pgAdmin, right-click the target instance node and choose Create > Database from the shortcut menu.
- On the General tab, specify Database and click Save. Figure 4 Creating a database
- Access the created database. In the navigation pane on the left, right-click Tables and choose Create > Table from the shortcut menu.
Create tables in the schema of the database created by the current user.
- On the General tab, enter required information and click Save. Figure 5 Basic information
- On the Columns tab, add table columns and click Save. Figure 6 Adding table columns
On the top menu bar, choose Tools > Query Tool. The SQL CLI is displayed.
Take care when adding, deleting, or modifying data in the instance. Improper operations can cause instance or service exceptions.
- Run the INSERT command to insert data into the table. Figure 8 Inserting data
- Run the SELECT command to query data from the table. Figure 9 Querying data
In the navigation pane on the left, select a database and click the Dashboard tab on the right pane to view database metrics, including Database sessions, Transactions per second, Tuples in, Tuples out, and Block I/O.
Cloud Eye monitors operating statuses of DB instances. You can view the DB instance metrics on the management console. For details, see Viewing Metrics.
- In the navigation pane on the left, right-click the database to be backed up and choose Backup from the shortcut menu.
- On the General tab, enter required information and click Backup.
- In the navigation pane on the left, right-click the database to be restored and choose Restore from the shortcut menu.
- On the displayed tab in the right pane, select a file name and click Restore.
