On this page
Adding Work Item Modules
Updated on 2025-01-17 GMT+08:00
  • You can add, modify, and delete work item modules in a project.
  • You can add submodules to a module.
  • When creating or editing a work item, you can specify the module to which the work item belongs.
A Scrum project is available, and you have permission to set modules for the project.
  1. Access the CodeArts Req homepage.
  2. Go to a Scrum project and choose Settings > Work.
  3. In the navigation pane, choose Modules.
  4. Click Add Module to add a work item module by referring to the following table. A maximum of 1,024 modules can be added.
    Table 1 Adding a module
    Name
    Module name. Enter a maximum of 30 characters.
    Module description. Enter a maximum of 255 characters.
    Owner
    Module owner. Select from all members of the current project.
  5. Click Clone Module to replace the module settings of the target project with those of the current project.
  6. Edit or delete a module, or add a submodule.
    Table 2 Module operations
    Operation
    Edit
    Click to modify a module.
    Add submodule
    Click to add a submodule. A maximum of three levels are supported.
    Delete
    Click to delete a module. Modules that are currently in use by work items cannot be deleted.
  7. On the page for creating or editing a work item, select a module in the Module field.
    If there is no module, click to add one.
  • After the configuration is complete, click Save as Template in the upper right corner of the page. In the Save as Template dialog box, enter a template name and description, and click OK.
  • This template can be used to create Scrum projects.
    Figure 1 Creating a Scrum project
