- What's New
- Function Overview
Service Overview
- What Is CodeArts Req?
- Advantages
- Use Cases
Features
- Multiple Built-in IPD Requirement Models
- E2E Traceability
- Baseline Management and Change Review
- Efficient Cross-Project Requirement Collaboration
- System Feature Management
- Customers' Raw Requirements Management
- Bug Full Lifecycle Management
- Efficient Cross-Organization Collaboration for Bug Tracking and Management
- Bug Trend Analysis and Quality Measurement
- Traceable Fixing Process
- Customizable Fixing Process
- Security
- Permission Management
- Constraints
- Getting Started
User Guide
- CodeArts Req Usage Process
- Purchasing and Authorizing CodeArts Req
- Accessing the CodeArts Req Homepage
- Creating a CodeArts Project
- Managing Scrum Project Requirements
Managing IPD-System Device Project Requirements
- Requirement Management Process
Configuring Common Settings
- Configuring Common Work Item Fields
- Configuring Common Work Item Statuses
- Configuring Work Item Templates
- Configuring Work Item Status Flows
- Configuring Work Item Tags
- Creating Work Item Modules
- Creating Work Types
- Configuring Work Item Status Roll-up Rules
- Configuring Notification Rules
- Viewing Work Item Import/Export Records
- Creating and Managing RRs
- Creating and Managing a Feature Tree and System Features
- Configuring Project Plans
- Creating and Managing R&D Requirements
- Creating and Managing Tasks
- Creating and Managing Bugs
- Reviewing Work Items
- Tracking the Project Progress
Managing IPD-Standalone Software Project Requirements
Common Configuration Management
- Configuring Automatic Roll-up Rules
- Configuring Notifications
- Configuring a Plan
- (Optional) Checking Audit Logs
Best Practices
- CodeArts Req Best Practices
- Best Practices of Scrum Projects
- Using IPD-System Device Projects to Manage RRs of a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Defects of a Smart Watch R&D Project
- Using IPD-System Device Projects to Perform a Baseline Review (BR) on a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Feature Trees of a Smart Watch R&D Project
- Huawei E2E DevOps Practice: Managing Requirements
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Work Items of the Scrum Project
- Creating a Customized Field for a Work Item Type
- Uploading an image
- Obtaining Work Item Completion Rate
- Obtaining Comments on a Specified Work Item
- Querying Labor Hours by User (Single Project)
- Querying Labor Hours by User (Multi-Project)
- Obtaining the Work Item History
- Create work items.
- Querying Work Items of a Project
- Advanced Query Work Item
- Deleting Work Items in Batches
- Querying Work Item Details
- Updating a Work Item
- Deleting a Work Item
- Obtains sub-work items.
- Querying Historical Records of All Work Items in a Project
- Querying the Work Item Transfer Configuration of a Scrum Project
- Creating a Work Item as a Fine-grained Permission User
- Queries the work items associated with the current work item.
- Queries the associated Wikis associated with the current work item.
- Queries the code submission records or branch creation records associated with the current work item.
- Querying Associated Wikis
- Querying Customized Fields of Scrum Work Items
- Downloading an Image
- Uploading an Attachment to a Work Item
- Iteration of the Scrum Project
- User Information
- Project members
- Project Information
- Project Indicators
- Project Statistics
- Modules of the Scrum Project
- Domain of the Scrum Project
- Scrum Project Statuses
- Application Examples
- Appendixes
- Change History
Work Items
- How Can I Assign One Scrum Project Work Item to Multiple Members?
- Why Is a Message Reporting Duplicate File Name Displayed During File Association in a Scrum Project?
- How Do I Handle the Verification Exceptions in the Number of Work Items Imported to an IPD Project?
- How Do I Modify the Recipient After an IPD Project Requirement Is Assigned?
- Member Management
Troubleshooting
- Why Is the Message "You have been invited to run projects with another account. Accept invitation" Displayed When Inviting Other Users to Join My Project in CodeArts Req?
- Why Can't I Create a Project Using "DevOps Full-Process"?
- Why Is a Message Indicating the Field Name Already Exists Displayed When Setting a Work Item Field in a Scrum Project?
Work Items
- Videos
Show all
Customize common statuses that can be used by any type of work items in your project.
- A Scrum project is available, and you have permission to customize work items for the project.
- The New and Closed statuses cannot be deleted.
- A maximum of 50 common statuses can be customized.
- Access the CodeArts Req homepage.
- Go to a Scrum project and choose Settings > Work.
- In the navigation pane, choose Common Statuses.
Click Add Status, and set the status information, including the name (for example, CommonStatus1), category, and description.
- The added status is displayed in the status list, including the name, description, category, and usage.
- Common statuses can be deleted.
- Add an existing common status (for example, CommonStatus1) for a work item.
The following uses a story status as an example:
- In the navigation pane, choose Stories > Statuses and Transitions.
On the Statuses tab page, click Add Existing Status. In the Status drop-down list, select CommonStatus1 and click OK.
Figure 1 Adding an existing status - Check this CommonStatus1 field when clicking the status of a story on the Work > Req > Work Items page.
Customized common statuses can be configured and used for all types of work items of the current project.
- After the configuration is complete, click Save as Template in the upper right corner of the page. In the Save as Template dialog box, enter a template name and description, and click OK.
- This template can be used to create Scrum projects.
Figure 2 Creating a Scrum project
