Using a Sample Project
Sample projects use default templates that include work items and processes preset in CodeArts Req. After you select a sample project, the corresponding sample template project is automatically generated for your reference. The work items and code preset in the sample project can be directly used.
Before creating a CodeArts project, you must have permission to create a project. If the Create Project button is not displayed on the homepage, you do not have permission to create projects. In this case, contact the administrator to obtain the permission. For details about how to grant the project creator permission to users, see Configuring a CodeArts Project Creator.
Creating a CodeArts Project Using a Sample Project
- Click Create Project on the service homepage.
- On the Select Template page, select a sample project. Table 1 lists the supported sample projects.
Table 1 Sample projects Project Type
Project Name
Application Scenario
Scrum
DevOps Full-Process Sample Project
Agile development and DevOps continuous delivery through an automated E2E process. The templates have preset mind maps and instantiated Scrum work items (promotion, member, and order management), code repositories, code check tasks, build tasks, and pipeline tasks.
Scrum
One-Stop HarmonyOS Application Development
The sample project provides a one-stop distributed application development platform for all scenarios. It supports distributed multi-device development, debugging, and simulation, providing all-round quality and security assurance.
IPD
IPD-System Device
Complex products with embedded software that evolves with hardware. Examples: communications devices, automobiles, home appliances, and consumer electronics.
NOTE:This type of projects can be created only in the AP-Singapore region.
IPD-Standalone Software
IT application and platform software with standardized hardware or independent of dedicated hardware. Examples: ERP software, CRM, databases, and network management software.
IPD-Self-Operated Software/Cloud Service
Cloud service development, microservice architecture, and self-operated software scenarios, such as public cloud and Internet application software.
- On the Create Project page, set related parameters.
Table 2 Creating a project Parameter
Name
Set this parameter as required.
- The name of projects under the same tenant must be unique.
- The value can contain 1 to 128 characters. Only letters, digits, and symbols are supported.
Code
This parameter is set for third-party services. A project code is set to facilitate service management.
Enter a maximum of 200 characters. Only digits, letters, hyphens (-), and underscores (_) are supported.
Enter a brief description of the project.
The value can contain a maximum of 1,024 characters.
- Click OK. The project is created successfully and the project page is displayed.
Related Operations
For a new project, members with the edit permission can choose and perform the following operations.
Operation | Procedure | Remarks |
Edit basic project information |
Transfer the project creator |
| If the project creator is deleted from IAM, the project ownership is automatically transferred to the project manager. If the project creator is also the project manager, the project ownership is transferred to the administrator account. |
Archive a project |
Delete a project |
Manage the project service menu |
Manage project members/permissions |
