Updated on 2026-10-26 GMT+08:00
Adding Work Types
  • You can add, edit, and delete work types in a project.
  • On the Person-Hour Details tab of the work item details page, you can set the person-hours required for a specific work type.
    The default work types are as follows: R&D design, backend development, frontend development (web), frontend development (applet), frontend development (app), test and verification, defect rectification, UI design, meeting, public affairs, training, study, reassignment and leave, and other. You can add more work types as required.
  1. Access the CodeArts Req homepage.
  2. Go to a Scrum project and choose Settings > Work ItemSettings > Work.
  3. In the navigation pane, choose Work Types.
    Figure 1 Work Types page
  4. Click Add to add a work type by referring to the following table. A maximum of 500 work types can be added.
    Table 1 Adding a work type
    Name
    Work type name. Enter a maximum of 30 characters.
    After setting the work type name, click OK on the right. The new work type appears in the list on the Work Types page.
  5. Edit or delete a work type if needed.
    Table 2 Work type operations
    Operation
    Edit
    Click to modify a work type.
    Delete
    Click to delete a work type. Work types that are currently in use cannot be deleted.
  6. Configure the following work type settings as required.
    Table 3 Configuring work type settings
    Operation
    Set Require work type
    Click next to Require work type to make work type required for person-hour settings. By default, the work type is not required.
    Set Read-only for Done Work Items
    Click next to Read-only for Done Work Items to make person-hour settings read-only for work items in a Done state. By default, person-hour settings are available for such work items.
  7. On the page for editing a work item, set the person-hours required for a specific work type.
  8. (Optional) After the configuration is complete, click Save as Template in the upper right corner of the page. In the Save as Template dialog box, enter a template name and description, and click OK. This template can be used to create Scrum projects. See the following figure.
    Figure 2 Applying a work item template
