- What's New
- Function Overview
Service Overview
- What Is CodeArts Req?
- Advantages
- Use Cases
Features
- Multiple Built-in IPD Requirement Models
- E2E Traceability
- Baseline Management and Change Review
- Efficient Cross-Project Requirement Collaboration
- System Feature Management
- Customers' Raw Requirements Management
- Bug Full Lifecycle Management
- Efficient Cross-Organization Collaboration for Bug Tracking and Management
- Bug Trend Analysis and Quality Measurement
- Traceable Fixing Process
- Customizable Fixing Process
- Security
- Permission Management
- Constraints
- Getting Started
User Guide
- CodeArts Req Usage Process
- Purchasing and Authorizing CodeArts Req
- Accessing the CodeArts Req Homepage
- Creating a CodeArts Project
- Managing Scrum Project Requirements
Managing IPD-System Device Project Requirements
- Requirement Management Process
Configuring Common Settings
- Configuring Common Work Item Fields
- Configuring Common Work Item Statuses
- Configuring Work Item Templates
- Configuring Work Item Status Flows
- Configuring Work Item Tags
- Creating Work Item Modules
- Creating Work Types
- Configuring Work Item Status Roll-up Rules
- Configuring Notification Rules
- Viewing Work Item Import/Export Records
- Creating and Managing RRs
- Creating and Managing a Feature Tree and System Features
- Configuring Project Plans
- Creating and Managing R&D Requirements
- Creating and Managing Tasks
- Creating and Managing Bugs
- Reviewing Work Items
- Tracking the Project Progress
Managing IPD-Standalone Software Project Requirements
Common Configuration Management
- Configuring Automatic Roll-up Rules
- Configuring Notifications
- Configuring a Plan
- (Optional) Checking Audit Logs
Best Practices
- CodeArts Req Best Practices
- Best Practices of Scrum Projects
- Using IPD-System Device Projects to Manage RRs of a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Defects of a Smart Watch R&D Project
- Using IPD-System Device Projects to Perform a Baseline Review (BR) on a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Feature Trees of a Smart Watch R&D Project
- Huawei E2E DevOps Practice: Managing Requirements
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Work Items of the Scrum Project
- Creating a Customized Field for a Work Item Type
- Uploading an image
- Obtaining Work Item Completion Rate
- Obtaining Comments on a Specified Work Item
- Querying Labor Hours by User (Single Project)
- Querying Labor Hours by User (Multi-Project)
- Obtaining the Work Item History
- Create work items.
- Querying Work Items of a Project
- Advanced Query Work Item
- Deleting Work Items in Batches
- Querying Work Item Details
- Updating a Work Item
- Deleting a Work Item
- Obtains sub-work items.
- Querying Historical Records of All Work Items in a Project
- Querying the Work Item Transfer Configuration of a Scrum Project
- Creating a Work Item as a Fine-grained Permission User
- Queries the work items associated with the current work item.
- Queries the associated Wikis associated with the current work item.
- Queries the code submission records or branch creation records associated with the current work item.
- Querying Associated Wikis
- Querying Customized Fields of Scrum Work Items
- Downloading an Image
- Uploading an Attachment to a Work Item
- Iteration of the Scrum Project
- User Information
- Project members
- Project Information
- Project Indicators
- Project Statistics
- Modules of the Scrum Project
- Domain of the Scrum Project
- Scrum Project Statuses
- Application Examples
- Appendixes
- Change History
Work Items
- How Can I Assign One Scrum Project Work Item to Multiple Members?
- Why Is a Message Reporting Duplicate File Name Displayed During File Association in a Scrum Project?
- How Do I Handle the Verification Exceptions in the Number of Work Items Imported to an IPD Project?
- How Do I Modify the Recipient After an IPD Project Requirement Is Assigned?
- Member Management
Troubleshooting
- Why Is the Message "You have been invited to run projects with another account. Accept invitation" Displayed When Inviting Other Users to Join My Project in CodeArts Req?
- Why Can't I Create a Project Using "DevOps Full-Process"?
- Why Is a Message Indicating the Field Name Already Exists Displayed When Setting a Work Item Field in a Scrum Project?
Work Items
- Videos
Creating Tasks
Tasks are activities with a certain goal. They can be associated with raw requirements, features, and R&D requirements.
An IPD-system device project is available, and you have permission to create and duplicate tasks for the project.
Creating Tasks
- Access the CodeArts Req homepage.
- On the project homepage, choose Tasks.
- Click Create Task. The Task page is displayed.
- Fill in the basic task information.
Table 1 Creating a task Parameter
Tag
When creating or editing a work item, you can add a custom tag.
Tag names can be marked in different colors.
Title
Title of a work item.
Enter the background, value, and details of the task based on project requirements.
Use text, images, or links.
A maximum of 100 attachments can be added to a task, and the total capacity is 50 MB.
Responsible Project
Project that the task belongs to. The value cannot be changed.
Owner
Member who is responsible for this task. Only one person can be specified.
Module
Module to which a task belongs.
Priority
Priority of a task, including Low, Medium, and High. The default value is Medium.
Release
Release to which a task belongs.
The parameter value can be empty. You can create a PI and then associate it with the PI.
Sprint
The next level of PI.
The parameter value can be empty. You can create a sprint and then associate it with the sprint.
Planned Start
Planned start time of a task. The date format is yyyy-mm-dd.
Planned Completion
Planned completion time of a task. The date format is yyyy-mm-dd.
The planned completion time cannot be earlier than the planned start time.
Planned Workload
Estimated workload from the planned start time to the planned completion time for this task.
Copy To
Project members to whom the task is copied. After the copy is complete, the people selected for Copy To will receive a message.
- Click OK. The Tasks tab page is displayed, and a message is displayed in the upper right corner, indicating that the task is created successfully.
The new task is displayed in the task list, and the task state is Initial.
Figure 1 Task listNOTE:
After a task is created, the people selected for Owner and Copy To will receive email and direct messages. If not, set notifications or modify notification settings. For details, see Configuring Notification Rules.
Related Operations
You can perform the following operations on a new task.
Operation |
Description |
Modify task title |
Click |
Modify task field |
Click the target field value in the row of a task to modify the value. |
Create child task |
Click
View task association map |
Choose |
Clone task |
Click |
Delete task |
Choose ![]() Once deleted, a task is moved to the recycle bin. Tasks in the recycle bin can be restored or permanently deleted. After a task is restored from the recycle bin, it restores to the original status. |
