Managing System Features
After creating a system feature (see Procedure), you can perform the operations described in this section on it.
You have created a system feature in an IPD-system device project, and have system feature permissions for the project.
Managing System Features on the System Feature List Page
Operation |
Procedure |
Search for system feature |
Import work items |
Use the provided template to import system features.
Export work items |
Export system features in batches to an Excel file.
Configure fields to display |
Click ![]()
Clone SFs across projects |
Transition statuses in batches |
Perform batch operations |
You can select multiple SFs to perform batch operations: baseline/unbaseline, change, baseline review, edit, suspend/unsuspend, export, delete, cross-project clone, and transition. |
Group system features |
You can group work items by any supported field type. Constraints
Managing System Features on Their Details Pages
Operation |
Procedure |
Remarks |
Edit work item |
On the system feature details page, click the value box of the field to be modified, and enter a target value in the text box or select one from the drop-down list. The modification is saved automatically. |
You must have permission to edit features. |
Change work item status |
Go to the work item details page, click the Status field, and transition the work item to the target status. For details about status transition, see Table 1. |
You must have permission to set statuses for features. |
Baseline feature |
You must have permission to baseline features. |
Initiate baseline review (BR) |
You must have permission to view features. |
Initiate change review (CR) |
The change process can be initiated only for baselined system features.
Upload attachment |
Attachments can be pictures, workbooks, manuscripts, and text files. A maximum of 100 attachments can be added to each work item, and their total size cannot exceed 500 MB.
You must have permission to upload attachments for features. |
Add and check related item |
A work item can be associated with other types of work items in a project.
You must have permission to create/associate/dissociate child features, create/associate/dissociate child requirements, create/associate/dissociate work items, associate/dissociate files, and associate/dissociate wikis for features. |
Check review record |
You can check the review records related to system features only in the following situations:
Add workload |
You must have permission to add person-hours for features. Workloads can be edited and deleted by the creator. By default, the project administrator can edit and delete all workloads. |
View operation history |
History displays all operation logs of users, including creation, status transition, review initiation, work item association, and workload addition.
Tag work item |
Add comment |
