Updated on 2026-01-22 GMT+08:00
Creating System Features
Major capabilities of offering requirements or services to support a problem (PB) can be managed in system features. When creating a system feature, you can set its background, value, details, and priority.
An IPD-system device project is available, and you have permission to create and duplicate features for the project.
  1. Access the CodeArts Req homepage.
  2. On the project homepage, choose Feature Tree.
  3. Click SF. On the SF page, set related parameters.
    Table 1 System feature parameters
    Tag
    When creating or editing a work item, you can add a custom tag.
    Tag names can be marked in different colors.
    Title
    Name of a system feature.
    Enter the background, value, and details of the feature based on project requirements.
    Use text, images, or links.
    A maximum of 100 attachments can be added to a system feature, and their total size cannot exceed 500 MB.
    Responsible Project
    Project that the system feature belongs to. The value cannot be changed.
    Owner
    Owner of the system feature. Only one owner can be selected. The default owner is the creator.
    Feature Set
    The feature set to which the system feature belongs is a home structure of the feature tree.
    Priority
    Priority of the system feature, including Low, Medium, and High. The default value is Medium.
    Planned Start
    Planned start time.
    Planned Completion
    The planned completion time cannot be earlier than the planned start time.
    Planned Workload
    Planned workloads.
    High Value
    Whether the system feature is a key feature. The value can be Yes or No.
    Used For
    Scenario with a maximum of 512 characters.
    Domain
    Domain to which the system feature belongs.
    The options include software and hardware, hardware, performance, operations, and user experience. Select one based on the system feature.
    Copy To
    Person to whom the system feature is copied.
  4. Click OK. The feature tree page is displayed. A message indicating system feature created is displayed in the upper right corner.
    The new system feature is displayed in the feature tree, and the system feature state is Initial.
    Figure 1 Feature tree
    After a system feature is created, the people selected for Owner and Copy To will receive email and system message notifications. If not, configure or modify notification settings. For details, see Configuring Notification Rules.
Related Operations
You can perform the following operations on a new system feature.
Table 2 Basic operations on a system feature
Operation
Modify system feature title
Click next to a system feature title to modify it.
Modify system feature field
Click the target field value in the row of a system feature to modify the value.
Create child requirement
Click in the Operation column of a system feature to break it down into child requirements.
  • In the Break Down Subrequirements dialog box, click Add Subrequirement to create a child requirement. A maximum of 10 child requirements can be created at a time.
  • You can break down work items quickly. See Configuring Common Fields in a Project for related field configuration.
    If Quickly split sub-work items is enabled, the corresponding number of child work items are created based on the number of options selected. A maximum of 10 child work items can be created.
    If the work item already has child work items, the function of quickly breaking down work items does not work.
    If a work item is configured with multiple fields for quickly breaking down work items, the child work items are broken down based on the first field in the field template.
Duplicate system feature
Choose > Duplicate in the Operation column. This process is the same as that of creating a feature.
Associate with child requirement
Click in the Operation column to associate a child requirement of the same project.
View system feature association map
Choose > Association Map in the Operation column of a system feature to view all data of its related items.
Copy system feature link
In the system feature list, you can copy the title, ID, current owner, status, and link of a system feature to the clipboard.
SFs: Click Copy Link under in the Operation column.
IRs/SRs/ARs: Click in the Operation column of an SF.
Delete system feature
Choose > Delete in the Operation column of a system feature to delete it.
  • System features in change or baseline review cannot be deleted.
  • Once deleted, a system feature is moved to the recycle bin. System features in the recycle bin can be restored or permanently deleted. After a system feature is restored from the recycle bin, it restores to the original status.
