Creating RRs
RRs are raw problems or requirements described from the perspective of customers. When creating an RR, you need to specify the background, value, details, and priority of the requirement.
There is an IPD-system device project, in which you have permission to create and duplicate RRs.
Creating RRs
- Access the CodeArts Req homepage.
- On the project homepage, click Raw Requirements.
- Click RR. On the RR page, set related parameters.
Table 1 Creating an RR Parameter
Title
Name of an RR.
Enter the background, value, and details of the RR based on actual conditions.
Use text, images, or links.
The maximum number of attachments for a single RR is 100, and their total size cannot exceed 500 MB.
Proposed Project
By default, it is the project to which the RR belongs and cannot be changed.
Raised By
By default, it is the creator of the RR. Multiple creators can be selected.
Responsible Project
Project to which the RR belongs.
- If the current project is selected, this requirement is internal.
- If another project of the tenant is selected, the requirement is submitted to external parties.
The current project is selected by default.
Recipient
Owner who undertakes the RR.
If multiple recipients are selected, data will be synchronized based on the recipients' processing speed.
Expected Completion
Expected completion time of the RR.
Priority
Priority of an RR, including Low, Medium, and High.
The default value is Medium.
Copy To
Other members of the project team.
- Click Submit. The Raw Requirements page is displayed and "Request submitted successfully" is displayed in the upper right corner.
- If you click Save as Draft, the RR list is displayed. The requirement status is --.
- If you click Cancel, the creation of the RR is cancelled.
The new requirement is displayed in the RR list, and the requirement state is Analyzing. If another project of the tenant is selected for Responsible Project, choose Other Projects to view the new RR.
After an RR is created, the people selected for Raised By, Recipient, and Copy To will receive email and system message notifications. If not, set notifications or modify notification settings. For details, see Configuring Notification Rules.
Related Operations
You can perform the following operations on a new RR.
| Operation | Description |
| Modify RR title | Click |
| Modify RR field | Click the target field value in the row of an RR to modify the value. |
| Create child requirement | Click
| Associate with child requirement | Click |
| Duplicate RR | Choose |
| View RR association map | Choose |
| Copy RR link | You can copy the title, ID, current owner, status, and link of a requirement to the clipboard. RRs of this project: Click Copy Link in the Operation column to copy the link. RRs of other projects/IRs/SRs/ARs: Click |
| Migrate RR | Choose
| Delete RR | Choose
