ThirdPartyAPI-v2
Call the ThirdPartyAPI-v2 extension to configure web APIs and call third-party APIs.
Notes and Constraints
- The ThirdPartyAPI-v2 extension requires certificate verification. Custom certificate is not supported.
- If the API return code is not 2XX, the operation fails.
Adding the Extension with GUI
Add the ThirdPartyAPI-v2 extension when you orchestrate a pipeline. Set parameters as show in Table 1.
Parameter |
Description |
Name |
Extension name.
API Method |
Select GET, POST, PATCH, PUT, or DELETE. |
API URL |
API that can be called by the public network. Certificate verification is required. |
API Header |
Configure key-value pairs. |
API Parameter |
API Body |
If the request method is POST, PATCH, or PUT, enter the body in JSON format. |
API Output |
The root object name is response, which includes multiple outputs.
Adding the Extension with YAML
Add the ThirdPartyAPI-v2 extension when you orchestrate a pipeline. Configure the YAML syntax as follows:
- ThirdPartyAPI-v2
uses: official_third_part_invoke with: API_METHOD: GET API_URL: htps://demo API_HEADER: '[{"key":"Content-Type","value":"application/json"}]' API_PARAM: '[{"key":"name","value":"value"}]' API_BODY: "{}" API_OUTPUT: '[{"key":"code","value":"response.status"}]'
