Updated on 2025-11-24 GMT+08:00
Configuring Expressions
You can reference pipeline contexts with expressions to specify the execution condition of a job. An expression can be any combination of contexts, operators, functions, or literals. Contexts can be accessed programmatically with expressions, so information such as pipeline runs, variables, and jobs can be transferred across pipelines.
  1. Create a pipeline.
  2. Add stage jobs or edit existing jobs.
  3. Click Job Configuration and set Execute to With expression to configure the expression for job execution. For a new stage and job, add an extension first and then click Job Configuration.
    Figure 1 Expressions
    Example:
    The following expression shows that a job runs only when the running branch of the specified code source is master.
    ${{ sources.my_repo.target_branch == 'master' }}
References
  • Operator
    The following table lists the operators that can be used in expressions.
    Table 1 Operators
    Operator
    Attribute reference. For example, the ${{ pipeline.trigger_type }} expression can be used to obtain the trigger type.
    False. For example, the ${{ !startsWith(sources.my_repo.target_branch, 'release') }} can be used to check whether the branch of the pipeline's code source does not start with "release".
    Equal. For example, the ${{ pipeline.trigger_type == 'Manual' }} expression can be used to check whether a pipeline is triggered manually.
    Not equal. For example, the ${{ pipeline.trigger_type != 'Manual' }} expression can be used to check whether a pipeline is not triggered manually.
    And. For example, the ${{ pipeline.trigger_type == 'Manual' && sources.my_repo.target_branch == 'master' }} expression can be used to check whether a pipeline is triggered manually and the branch of the pipeline code source is master.
    Or. For example, the ${{ pipeline.trigger_type == 'Manual' || sources.my_repo.target_branch == 'master' }} expression can be used to check whether a pipeline is triggered manually or the branch of the pipeline code source is master.
  • Function
    The following table lists the built-in functions that can be used in expressions.
    Table 2 Built-in functions
    Function
    contains
    • Format
      contains(search, item)
    • Description
      If search contains item, this function returns true.
      • If search is an array and item is an element in the array, this function returns true.
      • If search is a string and item is a substring of search, the function returns true.
    • Example
      contains('abc', 'bc') returns true.
    startsWith
    • Format
      startsWith(searchString, searchValue)
    • Description
      If searchString starts with searchValue, this function returns true.
    • Example
      startsWith('abc', 'ab') returns true.
    endsWith
    • Format
      endsWith(searchString, searchValue)
    • Description
      If searchString ends with searchValue, this function returns true.
    • Example
      endsWith('abc', 'bc') returns true.
    format
    • Format
      format(string, replaceValue0, replaceValue1, ..., replaceValueN)
    • Description
      Replaces the value in string with the value of replaceValueN.
    • Example
      format('Hello {0} {1}', 'a', 'b') returns Hello a b.
    substring
    • Format
      substring(string, beginIndex, endIndex)
    • Description
      Returns the characters in string from beginIndex to endIndex-1. If endIndex is not configured, the characters in string from beginIndex to the end are returned.
    • Example
      substring('202412091101', 0, 8) returns 20241209.
      substring ('202412091101', 8) returns 1101.
    replace
    • Format
      replace(string, target, replacement)
    • Description
      Replaces each character same as target in string with replacement.
    • Example
      replace('hello a', 'a', 'b') returns hello b.
    completed
    • Format
      completed(job1, job2, ..., jobN)
    • Description
      Returns true when the dependent job (no job specified) or the specified job is successfully executed. For example, completed() returns true when the dependent job is completed. Or, you can set Execute to When previous job succeeds to achieve the same purpose.
    • Example
      completed ('job1', 'job2') returns true when both job1 and job2 are successfully executed.
    always
    • Format
      always()
    • Description
      Executes the current job regardless of the status of the executed dependent job. You can set Execute to Always to achieve the same purpose.
    canceled
    • Format
      canceled()
    • Description
      Executes the current job when the dependent job is stopped.
    failed
    • Format
      failed(job1, job2, ..., jobN)
    • Description
      Returns true when the dependent job (no job specified) or the specified job fails. For example, failed() returns true when the dependent job fails. You can set Execute to If previous job fails to achieve the same purpose.
    • Example
      failed('job1', 'job2') returns true when either job1 or job2 fails to be executed.
    Object filter
    You can use the * syntax to apply a filter and select matching items in a collection.
    The following is the context of a job execution.
        "check_job": {
            "status": "COMPLETED",
            "metrics": {
                "critical": "0",
                "major": "0"
        "demo_job": {
            "status": "FAILED"
    • jobs.*.status indicates the status of all jobs. Therefore, ['COMPLETED', 'FAILED'] is returned.
    • Filters can be used together with the contains function. For example, contains(jobs.*.status, 'FAILED') will return true because jobs.*.status contains FAILED.
