Updated on 2025-11-04 GMT+08:00
Viewing the Third-Party Model Evaluation Report
After an evaluation job is created, you can view the task report. The procedure is as follows:
  1. Log in to ModelArts Studio Large Model Deveopment Platform. In the My Spaces area, click the required workspace.
    Figure 1 My Spaces
  2. In the navigation pane, choose Evaluation Center > Evaluation Task.
  3. Click Assessment report in the Operation column. On the displayed page, you can view the basic information and overview of the evaluation job.
    For details about each evaluation metric, see Third-Party Model Evaluation Metrics.
  4. Export the evaluation report.
    1. On the Evaluation Report > Service Result Analysis page, click Export, select the report to be exported, and click OK.
    2. Click Export Record on the right to view the exported task ID. Click Download in the Operation column to download the evaluation report to the local PC.
The third-party model supports automatic evaluation and manual evaluation. For details about the metrics, see Table 1, Table 2, and Table 3.
Table 1 Automatic evaluation metrics of the third-party model (not using preset evaluation datasets)
Evaluation Metric (Automatic Evaluation - Custom Evaluation Dataset)
Accuracy
Proportion of samples that are correctly predicted (the labeling and prediction are completely matched) to the total number of samples. A higher score indicates a higher proportion of samples that are correctly predicted by the model, and better model effectiveness.
F1 Score
Harmonic mean of the precision and recall. A higher score indicates better performance of the model on the two metrics, that is, the model achieves a better balance between precision and recall.
BLEU-1
Matching degree between the sentence generated by the model and the actual sentence at the single-word level. A larger score indicates better model effectiveness.
BLEU-2
Matching degree between the sentence generated by the model and the actual sentence at the phrase level. A larger score indicates better model effectiveness.
BLEU-4
Weighted average accuracy of the model generation result and actual sentences. A larger score indicates better model effectiveness.
ROUGE-1
Recall rate calculated after the model generation result and labeling result are split by 1-gram (n-gram refers to a segment consisting of n consecutive words in a sentence). A larger score indicates better model effectiveness.
ROUGE-2
Recall rate calculated after the model generation result and labeling result are split by 2-gram (n-gram refers to a segment consisting of n consecutive words in a sentence). A larger score indicates better model effectiveness.
ROUGE-L
Recall rate calculated after the model generation result and labeling result are split by longest-gram (longest-gram refers to a segment consisting of n consecutive words in a sentence). A larger score indicates better model effectiveness.
Table 2 Automatic evaluation metrics of the third-party model (using preset evaluation datasets)
Evaluation Metric (Automatic Evaluation- Evaluation Template Used)
Score
The score of each dataset is the pass rate of the model in the current dataset. If there are multiple datasets in the evaluation capability items, the weighted average pass rate is calculated based on the data volume.
Comprehensive capability
The comprehensive capability is the weighted average of the pass rates of all datasets.
Table 3 Manual evaluation metrics for third-party models
Evaluation Metric (Manual Evaluation)
Accuracy
The answer generated by the model is correct and there is no factual error.
average
The model calculates the average score of the generated sentence and the actual sentence based on the evaluation metric.
goodcase
The model calculates the proportion of test cases whose score is 5 after the generated sentence and the actual sentence are compared based on the evaluation metric.
badcase
The model calculates the proportion of test cases whose score is less than 1 after the generated sentence and the actual sentence are compared based on the evaluation metric.
Custom metric
Custom metrics, such as usability, logic, and security.
