Updated on 2025-11-04 GMT+08:00
Managing Custom Operators
Creating a Custom Processing Operator
Viewing the Custom Operator List
Viewing Custom Operator Details
Updating Custom Operators
Deleting Custom Operators
Restoring Custom Operators
Permanently Deleting Custom Operators
  1. Log in to ModelArts Studio. In the My Spaces area, click the required workspace.
    Figure 1 My Spaces
  2. In the navigation pane, choose Data Engineering > Data Processing > Processing Tasks. Click Manage Processing Operator in the upper right corner.
  3. On the Manage Processing Operators page, click the Custom tab, and click Create Custom Operator in the upper right corner.
  4. On the Create Custom Operator page, click Download samples to view the specifications of the operator configuration file and operator package. Use OBS to upload the operator configuration file and operator package, set the workspace visibility, and click OK in the lower right corner.
    Figure 2 Creating a custom operator
  5. Custom operators that are created can be used in Processing Text Datasets and Processing Other Datasets.
    Figure 3 My Spaces
  2. In the navigation pane, choose Data Engineering > Data Processing. On the Processing Tasks page, click Manage Processing Operator in the upper right corner.
    Figure 4 List of custom operators
    Figure 5 My Spaces
    Figure 6 List of custom operators
  3. Click the audio_speaker_detection operator to view its details.
    Figure 7 Operator details
    Figure 8 My Spaces
  2. In the navigation pane, choose Data Engineering > Data Processing. On the Processing Tasks page, click Manage Processing Operator in the upper right corner. Click the Custom tab.
    Figure 9 List of custom operators
  3. Click Update of the audio_speaker_detection operator. You can update only the operator configuration, only the operator package, or both the operator and operator package.
    Figure 10 Updating a custom operator
    Figure 11 My Spaces
    Figure 12 List of custom operators
  3. Select an operator, click Delete, and click OK.
    Figure 13 Deleting a custom operator
    Figure 14 My Spaces
  2. In the navigation pane, choose Data Engineering > Data Processing. On the Processing Tasks page, click Manage Processing Operator in the upper right corner. Click the Custom tab. Click Show Deleted Operators.
    Figure 15 List of custom operators
  3. Select any operator and click Update.
    Figure 16 Resuming a custom operator
    Figure 17 My Spaces
    Figure 18 List of custom operators
  3. Select any deleted operator, go to the details page, click permanently delete in the upper part of the page, and confirm the deletion.
    Figure 19 Permanently deleting a custom operator
