Updated on 2024-08-23 GMT+08:00
Cloud Operations Center (COC)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If resource types are specified for this column, specify the resource URN in the statement that contains the action.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by COC, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column of an action is empty (-), the action does not support any condition keys.
    For details about the condition keys defined by COC, see Conditions.
The following table lists the actions that you can define in SCP statements for COC.
Table 1 Actions supported by COC
Action
Access Level
Resource Type (*: required)
Condition Key
coc:customDashboard:update
Allows you to modify the permissions on a custom dashboard.
write
coc:customDashboard:get
Allows you to query the permissions on a custom dashboard.
read
coc:document:create
Allows you to create documents.
write
document
coc:document:listRunbookAtomics
Allows you to view the atomic capability list of a job.
list
document
coc:document:getRunbookAtomicDetails
Allows you to query details about an atomic capability of a job.
read
document
coc:document:list
Allows you to query the document list.
list
document
coc:document:delete
Allows you to delete documents.
write
document
coc:document:update
Allows you to modify documents.
write
document
coc:document:get
Allows you to view documents.
read
document
coc:document:analyzeRisk
Allows you to analyze document risks.
read
document
coc:systemConfig:get
Allows you to obtain the details about system configurations.
write
coc:systemConfig:create
Allows you to create system configurations.
read
coc:job:list
Allows you to query details about a service ticket.
write
job
coc:job:action
Allows you to perform operations on service tickets.
write
job
coc:instance:autoBatchInstances
Enables automatic instance batching.
list
instance
coc:instance:executeDocument
Allows you to execute documents on an ECS.
write
instance
coc:quota:get
Allows you to query instance quotas.
write
coc:job:get
write
job
coc:schedule:list
Allows you to query the scheduled task list.
read
schedule
coc:schedule:enable
Allows you to enable scheduled tasks.
read
schedule
coc:schedule:update
Allows you to update scheduled tasks.
list
schedule
coc:schedule:disable
Allows you to disable the scheduled task list.
write
schedule
coc:schedule:approve
Allows you to review the scheduled task list.
write
schedule
coc:schedule:create
Allows you to create a scheduled task list.
write
schedule
coc:schedule:delete
Allows you to delete scheduled tasks.
write
schedule
coc:schedule:count
Allows you to query the number of scheduled tasks.
write
schedule
coc:schedule:get
Allows you to query scheduled tasks.
write
schedule
coc:schedule:getHistories
Allows you to query the execution history of a scheduled task.
read
schedule
coc:parameter:list
Allows you to query the parameter list.
read
parameter
coc:parameter:delete
Allows you to delete parameters.
read
parameter
coc:parameter:update
Allows you to update parameters.
list
parameter
coc:parameter:create
Allows you to create parameters.
write
parameter
coc:parameter:get
Allows you to query parameter details.
write
parameter
coc:complianceReport:list
Allows you to query the compliance report list.
write
coc:patchBaseline:list
Allows you to query the patch baseline list.
read
coc:patchBaseline:get
Allows you to query the details about a patch baseline.
list
coc:patchBaseline:update
Allows you to update patch baselines.
list
coc:patchBaseline:registerDefault
Allows you to set the preset patch baseline.
write
coc:patchBaseline:delete
Allows you to delete patch baselines.
write
coc:patchBaseline:create
Allows you to create patch baselines.
write
coc:patchBaseline:getDefault
Allows you to query the preset patch baseline.
write
coc:patchBaseline:opsSystemGet
Allows you to view patch OS baselines.
write
coc:complianceReport:get
Allows you to query details about a compliance report.
read
coc:instance:scanOSCompliance
Allows you to scan OS patches on a server.
read
instance
coc:instance:installPatches
Allows you to install patches for ECSs.
read
instance
coc:patchBaseline:updateCustomBaseline
Allows you to update user-defined baselines.
read
coc:instance:startRDSInstance
Allows you to enable RDS DB instances.
write
instance
coc:instance:stopRDSInstance
Allows you to stop an RDS DB instance.
write
instance
coc:instance:restartRDSInstance
Allows you to reboot an RDS DB instance.
write
instance
coc:instance:start
Allows you to start ECSs.
write
instance
coc:instance:reboot
Allows you to restart ECSs.
write
instance
coc:instance:stop
Allows you to disable ECSs.
write
instance
coc:serverResourcesDetail:get
Allows you to obtain ESC resource information.
write
coc:instance:reinstallOS
Allows you to reinstall ECS OSs.
write
instance
coc:account:get
Allows you to query the list of managed accounts on a host.
write
coc:accountPasswordChangePolicy:get
Allows you to query enabled password change policies.
write
coc:accountEncryptionKey:list
Allows you to query added DEW keys.
write
coc:accountBaseline:list
Allows you to query the account baseline list.
list
accountBaseline
coc:accountAutoManagement:getRelations
Allows you to query information about components for which automatic management is enabled.
list
coc:accountEncryptionKey:listDEWKeys
Allows you to query existing DEW keys.
list
coc:accountBaseline:get
Allows you to query the account list in a baseline.
list
accountBaseline
coc:accountBaseline:create
Allows you to create account baselines.
list
accountBaseline
coc:accountBaseline:deleteAccount
Allows you to delete account permissions from a baseline.
list
accountBaseline
coc:account:add
Allows you to import a host account.
list
coc:instance:resetPassword
Allows you to reset the password of a host account.
write
instance
Allows you to delete account baselines.
write
accountBaseline
coc:accountAutoManagement:updateStatus
Allows you to update the automatic management statuses.
write
coc:accountAutoManagement:addRelations
Allows you to enable automatic management by component.
write
coc:accountBaseline:update
Allows you to modify account baselines.
write
accountBaseline
coc:accountPasswordChangePolicy:disable
Allows you to disable the password change policy.
write
coc:accountAutoManagement:deleteRelations
Allows you to disable automatic management by component.
write
coc:accountPasswordChangePolicy:enable
Allows you to enable the password change policy.
write
coc:accountEncryptionKey:add
Allows you to add an encryption key.
write
coc:account:sync
Allows you to synchronize accounts of hosts.
write
coc:account:getManagedStatus
Allows you to query the management step status.
write
coc:account:getPassword
Allows you to query the accounts and their passwords.
write
coc:accountAutoManagement:getStatus
Allows you to query whether the automatic management function is enabled.
write
coc:hostiAccount:describe
Allows you to query information about a hosting service account.
read
coc:vendorAccount:update
Allows you to update cloud vendor accounts.
read
coc:application:GetDiagnosisTaskDetails
Allows you to query application resource diagnosis tasks.
read
application
coc:application:CreateDiagnosisTask
Allows you to create application diagnosis tasks.
write
application
coc:vendorAccount:list
Allows you to query the list of cloud vendor accounts.
list
coc:vendorAccount:create
Allows you to create a cloud vendor account.
write
coc:vendorAccount:delete
Allows you to delete cloud vendor accounts.
list
coc:customApplication:get
Allows you to query custom application details.
write
application
coc:site:list
Allows you to query the region list.
write
coc:instance:listResources
Allows you to query the resource list.
list
instance
coc:application:listResources
Allows you to query the application resource list.
list
application
Allows you to query the application list.
list
application
coc:customApplication:list
Allows you to query the user-defined application list.
list
application
coc:application:listGroups
Allows you to query the permission of a specified application group list.
list
application
coc:region:list
list
coc:application:deleteGroup
Allows you to delete application groups.
list
application
coc:application:updateResources
Allows you to modify application resources.
list
application
coc:application:create
Allows you to create applications.
write
application
coc:application:addResources
Allows you to add resources to an application.
write
application
coc:application:createGroup
Allows you to create an application group.
write
application
coc:instance:syncResources
Allows you to synchronize the resource list.
write
instance
coc:application:removeResources
Allows you to remove permissions of an application resource.
write
application
Allows you to delete an application.
write
application
Allows you to modify the permissions of an application.
write
application
coc:application:updateGroup
Allows you to modify the permissions of an application group.
write
application
coc:contingencyPlan:list
Allows you to query the contingency plan list.
write
contingencyPlan
coc:contingencyPlan:delete
Allows you to delete a contingency plan.
write
contingencyPlan
coc:contingencyPlan:create
Allows you to create a contingency plan.
write
contingencyPlan
coc:contingencyPlan:update
Allows you to modify a user's permissions on a contingency plan.
list
contingencyPlan
coc:wechatkey:create
Allows you to create an enterprise WeChat application key.
write
coc:wechatkey:delete
Allows you to delete the enterprise WeChat application key.
write
coc:appkey:update
Allows you to update mobile app keys.
write
coc:wechatkey:update
Allows you to modify keys of WeCom.
write
coc:appkey:create
Allows you to create a mobile application key.
write
coc:appkey:delete
Allows you to delete mobile application keys.
write
coc:appkey:get
Allows you to view mobile application keys.
write
coc:wechatkey:get
Allows you to view WeCom application keys.
write
coc:systemConfig:update
Allows you to modify system configurations.
write
coc:hostAccount:delete
Allows SRE engineers to delete hosting accounts.
read
coc:hostAccount:update
Allows you to edit SRE hosting accounts.
read
coc:hostAccount:disable
Allows you to cancel the hosting service.
list
coc:hostAccount:create
Allows you to add a hosting account.
read
coc:hostAccount:list
Allows you to query SRE hosting accounts.
write
coc:hostAccount:enable
Allows you to enable the hosting service for accounts.
write
coc:systemConfig:list
Allows you to obtain the system configuration list.
write
coc:agency:create
Allows you to create a tenant agency.
write
coc:agency:get
Allows you to query agency information of a tenant.
read
coc:notificationRule:get
Allows you to query notification rule details.
write
coc:notification:listTypes
Allows you to query notification types.
write
coc:notification:listTemplates
Allows you to query the notification template list.
read
coc:notification:listModes
Allows you to query the notification mode.
list
coc:notificationRule:list
Allows you to query the notification rule list.
list
coc:notificationRule:update
Allows you to update notification rules.
list
coc:notificationRule:delete
Allows you to delete notification rules.
list
coc:notificationRule:create
Allows you to create notification rules.
list
coc:notificationRule:disable
Allows you to disable notification rules.
write
coc:ticket:get
Allows you to query incident ticket details.
write
coc:contingencyPlan:getHistories
Allows you to query the contingency plan history.
write
contingencyPlan
coc:ticket:listEnumTypes
Allows you to query the enumeration type list of incident tickets.
write
coc:ticket:listEnumValues
Allows you to query the enumerated value list of an incident ticket.
write
coc:ticket:getOperationHistories
Allows you to query the operation history of an incident ticket.
list
coc:ticket:listActions
Allows you to query the list of operations that can be performed.
list
coc:ticket:getEnumValues
Allows you to query details about enumerated values of an incident ticket.
list
coc:ticket:list
Allows you to query the incident ticket list.
list
coc:ticket:update
Allows you to modify incident tickets.
list
coc:contingencyPlan:downloadFile
Allows you to download attachments in contingency plans.
list
contingencyPlan
coc:ticket:delete
Allows you to delete incident tickets.
list
coc:ticket:downloadFile
Allows you to download attachments for incident tickets.
list
coc:ticket:action
Allows you to handle incident tickets.
write
coc:ticket:uploadFile
Allows you to upload attachments for incident tickets.
write
coc:ticket:create
Allows you to create incident tickets.
write
coc:contingencyPlan:uploadFile
Allows you to upload attachments for the contingency plan.
write
contingencyPlan
coc:ticket:getEnumTypes
Allows you to query details about incident ticket enumeration types.
write
coc:personnel:list
Allows you to query the personnel list.
write
coc:personnel:update
Allows you to update personnel information.
write
coc:personnel:add
Allows you to add personnel.
write
coc:personnel:remove
Allows you to remove personnel.
read
coc:notificationRule:confirm
Allows you to confirm notification rules.
list
coc:instance:changeOS
Allows you to change the OS of an ECS.
write
instance
coc:oncall:listPersonnels
Allows you to query the list of on-call personnel in schedules.
write
coc:oncall:listScenes
Allows you to view on-call scheduling scenarios.
write
coc:oncall:listRoles
Allows you to query on-call personnel roles in schedules.
write
coc:oncall:updatePersonnels
Allows you to update the on-call personnel in schedules.
list
coc:oncall:updateScene
Allows you to update on-call scheduling scenarios.
list
coc:oncall:removePersonnels
Allows you to remove on-call personnel from schedules.
list
coc:oncall:updateRole
Allows you to update on-call personnel roles in schedules.
write
coc:oncall:createRole
Allows you to create on-call personnel roles in schedules.
write
coc:oncall:deleteScene
Allows you to delete on-call scheduling scenarios.
write
coc:oncall:deleteRole
Allows you to delete on-call personnel roles from schedules
write
coc:oncall:addPersonnels
Allows you to add on-call personnel to schedules.
write
coc:oncall:createScene
Allows you to create on-call scheduling scenarios.
write
coc:transferRule:get
Allows you to query details about a forwarding rule.
write
coc:transferRule:list
Allows you to query the forwarding rule list.
write
coc:transferRule:delete
Allows you to delete forwarding rules.
write
coc:transferRule:disable
Allows you to disable forwarding rules.
list
coc:transferRule:enable
Allows you to enable forwarding rules.
list
coc:transferRule:create
Allows you to create forwarding rules.
write
coc:transferRule:update
Allows you to update forwarding rules.
write
coc:notificationRule:enable
Allows you to enable notification rules.
write
coc:transferRule:getHistory
Allows you to query the messages about incidents transferred recently.
write
coc:quotas:list
Allows you to query the list of purchased quotas.
write
coc:orders:change
Allows you to update Cloud Operations Center orders.
read
coc:orders:create
Allows you to create CloudOperationsCenter orders.
list
coc:integration:list
Allows you to query the integration configuration list.
write
coc:integration:get
Allows you to query integration configuration details.
write
coc:integration:getHistory
Allows you to query historical incident messages of integration configurations.
list
coc:integration:update
Allows you to modify integration configurations.
list
coc:integration:enable
Allows you to enable integration configurations.
list
coc:integration:disable
Allows you to disable integration configurations.
write
coc:integration:access
Allows you to access integration configurations.
write
coc:integration:remove
Allows you to remove integration configurations.
write
coc:attackTargetRecord:list
Allows you to view the execution record list of an attack target.
write
attackTargetRecord
coc:drillPlan:list
Allows you to query the drill plan list.
write
drillPlan
coc:attackRecord:list
Allows you to view the attack record list.
list
attackRecord
coc:faultMode:list
Allows you to query the failure mode list.
list
faultMode
coc:monitorMetricRecord:list
Allows you to query the monitoring metric data list.
list
coc:attackTask:list
Allows you to view the attack task list.
list
attackTask
coc:attackTarget:listCcePods
Allows you to query the pod list of attack targets from CCE clusters.
list
coc:improvementTask:list
Allows you to query the improvement item list.
list
coc:drillTask:list
Allows you to view the drill task list.
list
drillTask
coc:attackTarget:listCceWorkloads
Allows you to query the workload list of attack targets from CCE clusters.
list
coc:attackTarget:listCceNamespaces
Allows you to query the namespace list of attack targets from CCE clusters.
list
coc:drillPlan:listDelay
Allows you to query the list of delayed drill plans.
list
drillPlan
coc:monitorMetric:list
Allows you to query the monitoring metric list.
list
coc:faultMode:delete
Allows you to delete failure modes.
list
faultMode
coc:faultMode:update
Allows you to update failure modes.
list
faultMode
coc:drillTask:create
Allows you to create drill tasks.
write
drillTask
coc:attackTargetRecord:operate
Allows you to retry execution records of attack targets.
write
attackTargetRecord
coc:drillReport:create
Allows you to create drill reports.
write
coc:drillTask:delete
Allows you to delete drill tasks.
write
drillTask
coc:faultMode:create
Allows you to create failure modes.
write
faultMode
coc:drillRecord:create
Allows you to start a drill.
write
drillRecord
coc:drillPlan:create
Allows you to create a drill plan.
write
drillPlan
coc:drillReport:update
Allows you to update drill reports.
write
coc:application:CreateResourceTopo
Allows you to create resource topologies.
write
application
coc:drillTask:update
Allows you to modify drill tasks.
write
drillTask
coc:improvementTask:create
Allows you to create improvement items.
write
coc:drillPlan:update
Allows you to update drill plans.
write
drillPlan
coc:attackRecord:changeMetricType
Allows you to modify a metric type in an attack record.
write
attackRecord
coc:improvementTask:update
Allows you to handle improvement items.
write
coc:attackTask:create
Allows you to create attack tasks.
write
attackTask
coc:drillPlan:countStatus
Allows you to query the number of drill tasks that are in a specified drill plan state.
write
drillPlan
coc:faultMode:get
Allows you to query the details about a specified failure mode.
read
faultMode
Allows you to query contingency plan details.
read
contingencyPlan
coc:drillRecord:get
Allows you to query drill record details.
read
drillRecord
coc:drillTask:get
Allows you to query drill task details.
read
drillTask
coc:drillPlan:countDelay
Allows you to query the number of delayed drill plans.
read
drillPlan
coc:improvementTask:get
Allows you to query the details about an improvement item.
read
coc:drillReport:get
Allows you to query details about a drill report.
read
coc:drillPlan:get
Allows you to query details about a specified drill plan
read
drillPlan
coc:attackTask:get
Allows you to view details about an attack task.
read
attackTask
coc:alarm:listHandleHistories
Allows you to query the historical alarm handling list.
read
coc:alarm:list
Allows you to query the alarm list.
list
coc:alarm:createAlarmLinkedIncident
Allows you to create incidents associated with alarms.
list
coc:alarm:clear
Allows you to clear alarms.
write
coc:instance:getAlarms
Allows you to view the alarm list of a resource.
write
instance
coc:alarm:get
Allows you to query alarm information.
read
coc:alarm:count
Allows you to query the number of alarms.
read
coc:instance:listAlarms
Allows you to query the alarm list of all resources.
read
instance
coc:task:list
Allows you to query the O&M transaction list.
list
coc:task:create
Allows you to create O&M transactions
list
coc:task:complete
Allows you to end O&M transactions.
write
coc:task:cancel
Allows you to cancel O&M transactions.
write
coc:task:accept
Allows you to receive O&M transact.ions.
write
coc:task:get
Allows you to query details about an O&M transaction.
write
coc:task:count
read
coc:warroom:get
Allows you to query details about a war room.
read
coc:warroom:listConfigurations
Allows you to query the public enumeration configurations of war rooms.
list
coc:warroom:list
Allows you to query the war room list.
write
coc:warroom:listNotificationTemplates
Allows you to query the war room notification template list.
list
coc:warroom:listMeetings
list
coc:warroom:listRoles
Allows you to query the war room role list.
list
coc:warroom:listAffectedApplications
Allows you to query the list of applications of a war room.
list
coc:warroomMeetingRule:list
Allows you to query the war room startup rule list.
list
coc:warroom:getOperationHistory
Allows you to query war room operation history.
list
coc:warroom:addRolePersonnels
Allows you to add roles to war rooms.
list
coc:warroom:modifyBasicInformation
Allows you to modify basic war room information.
list
coc:warroomMeetingRule:delete
Allows you to delete war room setup rules.
list
coc:warroom:addAffectedApplications
Allows you to add applications to war rooms.
write
coc:warroom:addPersonnels
Allows you to add personnel to war rooms.
write
coc:warroomMeetingRule:update
Allows you to update war room startup rules.
write
coc:warroom:removeAffectedApplications
Allows you to remove the affected applications from war rooms.
write
coc:warroom:sendNotification
Allows you to update or send notifications in war rooms.
write
coc:warroom:removePersonnels
Allows you to remove personnel from war rooms.
write
coc:warroom:create
Allows you to create war rooms.
write
coc:warroom:sendNotificationBriefing
Allows you to send notification briefings in war rooms.
write
coc:warroom:updateAffectedApplications
Allows you to update applications in war rooms.
write
coc:warroomMeetingRule:create
Allows you to create war room startup rules.
write
coc:slo:list
Allows you to query the SLO list.
write
coc:slo:listSli
Allows you to query the SLI list.
write
coc:slo:update
Allows you to modify SLOs.
write
coc:slo:delete
Allows you to delete SLOs.
list
coc:slo:updateSli
Allows you to update the SLI list.
list
coc:slo:listInterruptRecords
Allows you to query the interruption record list.
write
coc:slo:listInterruptRecordsChangeHistory
Allows you to modify an interruption record.
write
coc:slo:updateInterruptRecords
Allows you to update interruption records.
write
coc:slo:createInterruptRecords
Allows you to create interruption records.
list
coc:slaTemplate:list
Allows you to query the SLA template list.
list
slaTemplate
coc:slaRecord:list
Allows you to query the SLA service ticket list.
write
coc:slo:get
Allows you to query SLO details.
write
coc:slaTemplate:update
Allows you to modify SLA template.
list
slaTemplate
coc:slaTemplate:enable
Allows you to enable the SLA template.
list
slaTemplate
coc:slaTemplate:delete
Allows you to delete the SLA template.
list
slaTemplate
coc:slaTemplate:disable
Allows you to disable an SLA template.
write
slaTemplate
coc:slaTemplate:create
Allows you to create an SLA template.
write
slaTemplate
coc:slo:create
Allows you to create an SLO.
write
coc:slaTemplate:get
Allows you to query details about an SLA template.
write
slaTemplate
coc:slaRecord:get
Allows you to query the details about an SLA service ticket.
write
coc:prrTemplate:list
Allows you to view the PRR template list.
write
coc:prrReview:list
Allows you to view the PRR review list.
read
coc:prrCheckItem:list
Allows you to view the PRR check item list.
read
coc:prrTemplate:create
Allows you to create a PRR template.
list
coc:prrReview:create
Allows you to initiate PRR reviews.
list
coc:prrReview:addImprovementTask
Allows you to add PRR improvement items.
list
coc:prrReview:update
Allows you to continue to initiate PRR review.s
write
coc:prrTemplate:delete
Allows you to delete PRR templates.
write
coc:prrTemplate:update
Allows you to modify PRR templates.
write
coc:prrReview:auditResult
Allows you to record PRR review conclusions.
write
coc:prrReview:delete
Allows you to revoke PRR reviews.
write
coc:prrReview:recordSummary
Allows you to input PRR review minutes.
write
coc:prrTemplate:get
Allows you to query details about PRR templates.
write
coc:prrReview:get
Allows you to query details about a PRR review.
write
coc:tag:list
Allows you to query the tag list.
write
coc:tag:create
Allows you to create tags.
read
coc:*:listSSHKeypairs
Allows you to query the SSH key list.
read
Each API of Cloud Cloud Operations Center usually supports one or more actions. Table 2 lists supported actions and their dependencies.
Table 2 Actions and dependencies supported by Cloud Connect APIs
API
Action
Dependency
GET /v1/patch/instance/compliant
GET /v1/patch/instance/compliant/{instance_compliant_id}
POST /v1/job/scripts
coc:document:create
DELETE /v1/job/scripts/{script_uuid
coc:document:delete
POST /v1/job/scripts/{script_uuid}
GET /v1/job/scripts/{script_uuid}
coc:document:get
GET /v1/job/scripts
coc:document:list
PUT /v1/job/scripts/{script_uuid}
coc:document:update
GET /v1/job/script/orders/{execute_uuid}/batches/{batch_index}
coc:job:get
GET /v1/job/script/orders/{execute_uuid}/statistics
coc:job:get
coc:job:list
PUT /v1/job/script/orders/{execute_uuid}/operation
coc:job:action
GET /v1/resources
coc:instance:countResources
POST https://coc-intl.myhuaweicloud.com/v1/resources/sync
GET https://coc-intl.myhuaweicloud.com/v1/applications
coc:application:countResourceRelations
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for Cloud Operations Center.
Table 3 Resource types supported by CloudOperationsCenter
Resource Type
URN
instance
ecs:<region>:<account-id>:instance:<server-id>
instance
bms:<region>:<account-id>:instance:<server-id>
document
coc::<account-id>:document:<document-name>
job
coc::<account-id>:job:<job-id>
application
coc::<account-id>:application:<application-id>
schedule
coc::<account-id>:schedule:<schedule-id>
faultMode
coc::<account-id>:faultMode:<fault-mode-id>
contingencyPlan
coc::<account-id>:contingencyPlan:<contingency-plan-id>
attackTask
coc::<account-id>:attackTask:<attack-task-name>
attackRecord
coc::<account-id>:attackRecord:<attack-record-id>
attackTargetRecord
coc::<account-id>:attackTargetRecord:<attack-target-record-id>
drillTask
coc::<account-id>:drillTask:<drill-task-id>
drillRecord
coc::<account-id>:drillRecord:<drill-record-id>
drillPlan
coc::<account-id>:drillPlan:<drill-plan-id>
slaTemplate
coc::<account-id>:slaTemplate:<sla_template-id>
parameter
coc:<region>:<account-id>:parameter:<parameter-name>
accountBaseline
coc::<account-id>:accountBaseline:<account_baseline_id>
resourceView
coc::<account-id>:resourceView:<resourceViewId>
instance
rds:<region>:<account-id>:instance:<instance-id>
Conditions
Cloud Operations Center does not support service-specific condition keys in SCPs.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
