On this page
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) for access control.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to edit a custom SCP policy, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an identity policy SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by Workspace, see Resources.
  • The Condition Key column includes keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about condition keys defined by Workspace, see Conditions.
The following table lists the actions that you can define in SCP statements for Workspace.
Table 1 Actions supported by Workspace
Action
Access Level
Resource Type (*: Required)
Condition Key
workspace:authConfigs:get
Grants permission to query the configuration of the authentication login mode.
read
workspace:authConfigs:update
Grants permission to update authentication policy configurations.
write
workspace:assistAuthConfigs:get
Grants permission to query auxiliary authentication configurations.
read
workspace:assistAuthConfigs:update
Grants permission to update auxiliary authentication configurations.
write
workspace:jobs:retry
Grants permission to retry a task.
write
workspace:quotas:get
Grants permission to query tenant quotas.
read
workspace:tenants:getRoles
Grants permission to query tenant roles.
read
workspace:tenants:ListConfig
Grants permission to query customized tenant configurations.
list
workspace:tenants:updateConfig
Grants permission to modify customized tenant configurations.
write
workspace:natMappings:getConfig
Grants permission to query NAT mapping configuration items of a tenant.
read
workspace:natMappings:updateConfig
Grants permission to modify NAT mapping configuration items of a tenant.
write
Grants permission to query Huawei Cloud Workspace details.
read
workspace:tenants:open
Grants permission to subscribe to Huawei Cloud Workspace.
write
workspace:AccessMode
workspace:tenants:delete
Grants permission to unsubscribe from Huawei Cloud Workspace.
write
Grants permission to modify attributes of Huawei Cloud Workspace.
write
workspace:tenants:getLockStatus
Grants permission to query whether Huawei Cloud Workspace is locked.
read
workspace:tenants:unlock
Grants permission to unlock Huawei Cloud Workspace.
write
workspace:agencies:create
Grants permission to create an agency.
write
workspace:agencies:get
Grants permission to query agencies.
read
workspace:desktops:createAiAccelerateJob
Grants permission to create a rendering acceleration task.
write
workspace:desktops:getAiAccelerateJob
Grants permission to query rendering acceleration tasks.
read
workspace:desktops:getSysPrepInfo
Grants permission to query Sysprep details.
read
desktop *
  • g:ResourceTag/<tag-key>
  • g:EnterpriseProjectId
workspace:desktops:checkBatchChangeImage
Grants permission to verify batch image switchover.
write
desktop *
workspace:tenants:listDesktopNamePolicies
Grants permission to query desktop naming policies.
list
workspace:tenants:createDesktopNamePolicy
Grants permission to create a desktop naming policy.
write
workspace:tenants:updateDesktopNamePolicy
Grants permission to update a desktop naming policy.
write
workspace:tenants:batchDeleteDesktopNamePolicies
Grants permission to delete desktop naming policies in batches.
write
workspace:desktopPools:create
Grants permission to create a desktop pool.
write
desktopPool *
user
userGroup
  • g:RequestTag/<tag-key>
  • g:TagKeys
workspace:desktopPools:list
Grants permission to query desktop pools.
list
desktopPool *
workspace:desktopPools:update
Grants permission to modify desktop pool attributes.
write
desktopPool *
workspace:desktopPools:delete
Grants permission to delete a desktop pool.
write
desktopPool *
workspace:desktopPools:get
Grants permission to query desktop pool details.
read
desktopPool *
workspace:desktopPools:expand
Grants permission to expand the desktop pool capacity.
write
desktopPool *
workspace:desktopPools:resize
Grants permission to change desktop pool specifications.
write
desktopPool *
workspace:desktopPools:rebuild
Grants permission to recompose the system disk of a desktop pool.
write
desktopPool *
workspace:desktopPools:batchAddVolumes
Grants permission to add disks to desktop pools in batches.
write
desktopPool *
workspace:desktopPools:batchDeleteVolumes
Grants permission to delete disks from desktop pools in batches.
write
desktopPool *
workspace:desktopPools:batchExpandVolumes
Grants permission to expand the capacity of disks in batches in a desktop pool.
write
desktopPool *
workspace:desktopPools:operate
Grants permission to perform operations on a desktop pool.
write
desktopPool *
workspace:desktopPools:listUsers
Grants permission to query users and user groups authorized by the desktop pool.
list
desktopPool *
workspace:desktopPools:authorizeUsers
Grants permission to authorize users and user groups to access a desktop pool.
write
desktopPool *
user
userGroup
workspace:desktopPools:listDesktops
Grants permission to query desktop information in desktop pools.
list
desktopPool *
workspace:desktopPools:listScriptTasks
Grants permission to query the script execution task list of a desktop pool.
list
desktopPool *
workspace:desktopPools:executeScripts
Grants permission to execute desktop pool scripts in batches.
write
desktopPool *
script
workspace:desktopPools:sendNotifications
Grants permission to send notifications.
write
desktopPool *
workspace:desktops:export
Grants permission to export a desktop list.
list
desktop *
  • g:TagKeys
Grants permission to create a desktop.
write
desktop *
  • g:TagKeys
  • workspace:AssociatePublicIp
  • workspace:AccessMode
workspace:desktops:list
Grants permission to query desktops.
list
desktop *
  • g:TagKeys
workspace:desktops:update
Grants permission to update desktop information.
write
desktop *
workspace:desktops:delete
Grants permission to delete a desktop.
write
desktop *
Grants permission to query desktop details.
read
desktop *
workspace:desktops:batchDelete
Grants permission to delete desktops in batches.
write
desktop *
workspace:desktops:logoff
Grants permission to log out of desktops in batches.
write
desktop *
workspace:desktops:listDetail
list
desktop *
  • g:TagKeys
workspace:desktops:operate
Grants permission to perform operations on a desktop.
write
desktop *
workspace:desktops:resize
Grants permission to change specifications.
write
desktop *
workspace:desktops:getConnectStatus
Grants permission to query desktop login status statistics.
read
workspace:desktops:ListStatus
Grants permission to query desktop login statuses.
list
workspace:desktops:rebuild
Grants permission to recompose desktops.
write
desktop *
workspace:desktops:getActions
Grants permission to query desktop power-on/off information.
read
desktop *
workspace:desktops:createConsole
Grants permission to obtain the URL for remote login to the console.
write
desktop *
workspace:desktops:updateSids
Grants permission to update a desktop SID.
write
desktop *
workspace:desktops:rejoinDomain
Grants permission to rejoin the AD domain.
write
desktop *
workspace:desktops:createImage
Grants permission to convert a desktop to an image.
write
desktop *
workspace:desktops:batchDetach
Grants permission to unbind users in batches.
write
desktop *
workspace:desktops:detach
Grants permission to unbind a user.
write
desktop *
workspace:desktops:attach
Grants permission to assign a desktop to a user.
write
desktop *
workspace:desktops:getNetwork
Grants permission to query desktop network information.
read
desktop *
workspace:desktops:changeNetwork
Grants permission to switch the desktop network.
write
desktop *
workspace:exclusiveHosts:listDesktops
Grants permission to query exclusive desktop details.
list
exclusiveHost *
workspace:desktops:listAll
Grants permission to query general-purpose desktops and rendering desktops.
list
desktop *
workspace:desktopAssociate:listDiscoverVmInfo
Grants permission to query the list of VMs that can be managed.
list
workspace:desktopAssociate:startTask
Grants permission to start a VM management task.
write
workspace:desktopAssociate:switchScanTask
Grants permission to enable a management scanning task.
write
workspace:desktopAssociate:getScanTaskSwitch
Grants permission to query management scanning tasks.
read
workspace:desktops:setMaintenanceMode
Grants permission to set the desktop administrator maintenance mode in batches.
write
desktop *
workspace:desktops:prepAttachUsers
Grants permission to pre-assign desktops to users in batches.
write
desktop *
workspace:desktops:batchAttachUsers
Grants permission to assign desktops to users in batches.
write
desktop *
workspace:desktops:changeUsername
Grants permission to change usernames associated with desktops in Windows AD.
write
workspace:desktops:sendNotifications
write
desktop *
workspace:desktops:migrate
Grants permission to migrate desktops.
write
desktop *
workspace:desktops:listAgents
Grants permission to query the list of desktops with installed agents.
list
desktop *
workspace:desktops:batchInstallAgents
Grants permission to install agents for desktops in batches.
write
desktop *
workspace:desktops:listTags
Grants permission to query desktop tags.
list
desktop *
workspace:desktops:tag
Grants permission to create a desktop tag.
tagging
desktop *
  • g:TagKeys
workspace:desktops:untag
Grants permission to delete a desktop tag.
tagging
desktop *
  • g:TagKeys
workspace:desktops:listProjectTags
Grants permission to query project tags.
list
workspace:desktops:operateTags
Grants permission to add or delete tags in batches.
tagging
desktop *
  • g:TagKeys
workspace:desktops:listByTags
Grants permission to filter desktops by tag.
list
workspace:exclusiveHosts:create
Grants permission to create an exclusive host.
write
exclusiveHost *
Grants permission to query exclusive hosts.
list
exclusiveHost *
workspace:exclusiveHosts:check
Grants permission to check whether exclusive hosts can be created.
write
workspace:exclusiveHosts:get
Grants permission to query exclusive host details.
read
exclusiveHost *
workspace:exclusiveHosts:update
Grants permission to update exclusive host information.
write
exclusiveHost *
workspace:exclusiveHosts:delete
Grants permission to delete an exclusive host.
write
exclusiveHost *
workspace:mkp:listImages
Grants permission to query images in KooGallery.
list
workspace:mkp:listCommodityInfos
Grants permission to query product information in KooGallery.
list
workspace:mkp:createOrder
Grants permission to create a product order in KooGallery.
write
workspace:mkp:listListProductReserve
Grants permission to query the KooGallery inventory.
list
workspace:mkp:listCommodityDetails
Grants permission to query product details in KooGallery.
list
workspace:mkp:listRelationCommodityDetails
Grants permission to query associated products.
list
workspace:mkp:listCommodityAgreements
Grants permission to query product agreements in KooGallery.
list
workspace:networks:listEips
Grants permission to query EIPs.
list
workspace:networks:createEips
Grants permission to create an EIP.
write
workspace:networks:bindEips
Grants permission to bind an EIP.
write
workspace:networks:unbindEips
Grants permission to unbind an EIP.
write
workspace:networks:getEipQuota
Grants permission to query EIP quotas.
read
workspace:networks:ListNatGateways
Grants permission to query NAT gateways.
list
workspace:orders:create
Grants permission to place a yearly/monthly order.
write
  • workspace:CreateOrderType
workspace:orders:change
Grants permission to create a change order.
write
workspace:ChangeOrderType
workspace:orders:batchInquiry
Grants permission to inquire prices in batches.
write
workspace:quotas:check
Grants permission to verify quotas.
write
workspace:renderDesktops:create
Grants permission to create a rendering desktop.
write
workspace:renderDesktops:delete
Grants permission to delete a rendering desktop.
write
workspace:renderDesktops:list
Grants permission to query rendering desktops.
list
workspace:renderDesktops:action
Grants permission to perform operations on a rendering desktop.
write
workspace:scheduledTasks:list
Grants permission to query scheduled tasks.
list
scheduledTask *
workspace:scheduledTasks:create
Grants permission to create a scheduled task.
write
scheduledTask *
desktop
desktopPool
server
serverGroup
workspace:scheduledTasks:get
Grants permission to query scheduled task details.
read
scheduledTask *
workspace:scheduledTasks:update
Grants permission to update a scheduled task.
write
scheduledTask *
desktop
desktopPool
server
serverGroup
workspace:scheduledTasks:delete
Grants permission to delete a scheduled task.
write
scheduledTask *
workspace:scheduledTasks:getFuture
Grants permission to query the future execution time of a scheduled task.
read
workspace:scheduledTasks:batchDelete
Grants permission to delete scheduled tasks in batches.
write
scheduledTask *
workspace:scheduledTasks:listRecords
Grants permission to query the execution records of a scheduled task.
list
scheduledTask *
workspace:scheduledTasks:getRecord
Grants permission to query details about scheduled task execution records.
read
scheduledTask *
workspace:scheduledTasks:exportRecords
Grants permission to export details about scheduled task execution records.
list
scheduledTask *
workspace:users:subscribeSharer
Grants permission to subscribe to collaborative resources.
write
user *
workspace:desktops:addSubResources
Grants permission to purchase depended desktop resources.
write
desktop *
workspace:desktops:deleteSubResources
Grants permission to delete depended desktop resources.
write
desktop *
workspace:desktops:createSnapshots
Grants permission to create a desktop snapshot.
write
desktop *
workspace:desktops:getSnapshots
Grants permission to query desktop snapshots.
read
desktop *
workspace:desktops:deleteSnapshots
Grants permission to delete a desktop snapshot.
write
desktop *
workspace:desktops:restoreBySnapshot
Grants permission to restore desktops using desktop snapshots.
write
desktop *
workspace:statistics:listDesktopStatus
Grants permission to collect statistics on desktop statuses.
list
workspace:statistics:getUnused
Grants permission to query desktops that are not in use in a specified period.
read
workspace:statistics:getUsed
Grants permission to query the desktop usage duration.
read
workspace:bindingPolicies:export
Grants permission to export information about terminal-desktop binding to an Excel file.
list
workspace:bindingPolicies:getConfig
Grants permission to query a terminal-desktop binding configuration.
read
workspace:bindingPolicies:createConfig
Grants permission to configure terminal-desktop binding.
write
Grants permission to query terminal-desktop binding configurations.
read
workspace:bindingPolicies:add
Grants permission to add a terminal-desktop binding configuration.
write
workspace:bindingPolicies:update
Grants permission to modify a terminal-desktop binding configuration.
write
workspace:bindingPolicies:delete
Grants permission to delete a terminal-desktop binding configuration.
write
workspace:volumes:delete
Grants permission to delete a desktop data disk.
write
desktop
workspace:volumes:batchAdd
Grants permission to add a desktop disk.
write
desktop
workspace:volumes:batchExpand
Grants permission to expand a desktop disk.
write
desktop
workspace:wdh:getType
Grants permission to query Workspace host types.
read
wdh *
workspace:wdh:get
Grants permission to query Workspace hosts.
read
wdh *
workspace:desktops:getRemoteAssistance
Grants permission to query remote assistance information.
read
desktop *
workspace:desktops:createRemoteAssistance
Grants permission to create remote assistance.
write
desktop *
workspace:desktops:cancelRemoteAssistance
Grants permission to cancel remote assistance.
write
desktop *
workspace:volumes:add
Grants permission to add disks to a single desktop.
write
desktop
workspace:volumes:expand
Grants permission to expand disk capacity.
write
desktop
workspace:volumes:listDssPoolsDetail
Grants permission to obtain the dedicated distributed storage pool list.
list
workspace:common:listTimezones
Grants permission to query the time zone configuration.
list
workspace:connections:securityExport
Grants permission to export connection records.
list
workspace:images:list
Grants permission to query supported images.
list
workspace:policyGroups:import
Grants permission to import a policy group.
write
workspace:accessPolicies:create
Grants permission to create an access policy.
write
workspace:accessPolicies:get
Grants permission to query access policies.
read
workspace:accessPolicies:delete
Grants permission to delete a specified access policy.
write
workspace:accessPolicies:getTarget
Grants permission to query objects to which a specified access policy is applied.
read
workspace:accessPolicies:updateTarget
Grants permission to update objects to which a specified access policy is applied.
write
workspace:products:listDesktopProducts
Grants permission to query the list of available product packages.
list
workspace:products:listSharerProducts
Grants permission to query the list of collaboration packages.
list
workspace:products:listInternetProducts
Grants permission to query the list of Internet access packages.
list
workspace:availabilityZones:list
Grants permission to query AZs where Workspace is available.
list
workspace:userGroups:export
Grants permission to export a user group.
list
userGroup *
workspace:users:export
Grants permission to export a user.
list
user *
workspace:users:import
Grants permission to import a user.
write
user *
workspace:userGroups:exportUsers
Grants permission to export users in a user group.
list
userGroup *
workspace:users:operate
Grants permission to operators (locking, unlocking, and resetting passwords).
write
user *
workspace:users:randomPassword
Grants permission to reset a random password for a user.
write
user *
workspace:users:deleteOtps
Grants permission to unbind an OTP device.
write
user *
workspace:users:resendEmail
Grants permission to resend an email.
write
user *
workspace:connections:securityList
Grants permission to query connection information.
list
workspace:connections:listOnlineUsers
Grants permission to query the number of login users.
list
workspace:userGroups:list
Grants permission to query user groups.
list
userGroup *
workspace:userGroups:create
Grants permission to create a user group.
write
userGroup *
workspace:userGroups:batchDelete
Grants permission to delete user groups in batches.
write
userGroup *
workspace:userGroups:delete
Grants permission to delete a desktop user group.
write
userGroup *
workspace:userGroups:update
Grants permission to modify user group information.
write
userGroup *
workspace:userGroups:operate
Grants permission to perform operations on a user group.
write
userGroup *
user *
workspace:userGroups:getUsers
Grants permission to query users in a user group.
list
userGroup *
workspace:jobs:listSubJobs
Grants permission to query subtasks.
list
workspace:jobs:deleteSubJobRecords
Grants permission to delete a subtask record.
write
workspace:ou:get
Grants permission to query OU information.
list
workspace:ou:create
Grants permission to add OU information.
write
workspace:ou:delete
Grants permission to delete OU information.
write
workspace:ou:update
Grants permission to update OU information.
write
workspace:policyGroups:list
Grants permission to query policy groups.
list
policyGroup *
workspace:policyGroups:create
Grants permission to add a policy group.
write
policyGroup *
desktop
desktopPool
user
userGroup
appGroup
workspace:policyGroups:delete
Grants permission to delete a policy group.
write
policyGroup *
workspace:policyGroups:get
read
policyGroup *
workspace:policyGroups:update
Grants permission to modify a policy group.
write
policyGroup *
user
userGroup
appGroup
workspace:policyGroups:export
Grants permission to export a policy group.
list
policyGroup *
workspace:policyGroups:listPolicies
Grants permission to query policy items of a policy group.
list
policyGroup *
workspace:policyGroups:updatePolicies
Grants permission to modify policy items of a policy group.
write
policyGroup *
workspace:policyGroups:listTargets
Grants permission to query objects to which the policy group is applied.
list
policyGroup *
workspace:policyGroups:updateTargets
Grants permission to modify objects to which the policy group is applied.
write
policyGroup *
desktop
desktopPool
user
userGroup
appGroup
workspace:policyGroups:listDetail
Grants permission to query details about policy groups.
list
policyGroup *
workspace:policyGroups:getOriginalPolicies
Grants permission to query initial policy items.
read
policyGroup *
workspace:users:list
Grants permission to query users.
list
user *
workspace:users:create
Grants permission to create a user.
write
user *
Grants permission to delete a specified user.
write
user *
workspace:users:get
Grants permission to query user details.
read
user *
workspace:users:update
Grants permission to modify user information.
write
user *
workspace:users:batchDelete
Grants permission to delete users in batches.
write
user *
workspace:users:resetPassword
Grants permission to reset a user password.
write
user *
workspace:users:checkResetPasswordToken
Grants permission to verify tokens for resetting passwords of domain users.
write
user *
workspace:users:getTemplate
Grants permission to download a user template.
read
workspace:users:checkExist
Grants permission to check whether the user exists.
write
user *
workspace:users:listOtps
Grants permission to query OTP devices.
list
user *
workspace:users:getImportTemplate
Grants permission to download a created user template.
read
workspace:users:batchCreate
Grants permission to create users in batches.
write
user *
workspace:products:listVolumeProducts
Grants permission to query disk products.
list
workspace:tenants:listExportTasks
Grants permission to query export tasks.
list
workspace:tenants:deleteExportTasks
Grants permission to delete export task records in batches.
write
workspace:tenants:exportData
Grants permission to download an exported file.
read
workspace:statistics:listAlarm
Grants permission to query alarms.
list
workspace:statistics:getAlarm
Grants permission to query the number of alarms.
read
workspace:statistics:getGrowthRate
Grants permission to query the chain value of a metric.
read
workspace:statistics:getMetric
Grants permission to query metrics.
read
workspace:statistics:getMetricTrend
Grants permission to query the metric trend.
read
workspace:statistics:updateNotificationRules
Grants permission to update a metric notification rule.
write
workspace:statistics:deleteNotificationRules
Grants permission to delete a metric notification rule.
write
workspace:statistics:createNotifyRules
Grants permission to add a metric notification rule.
write
workspace:statistics:listNotificationRules
Grants permission to query metric notification rules.
list
workspace:statistics:listNotificationRecords
Grants permission to query metric notification records.
list
workspace:statistics:listDesktopMetrics
Grants permission to query desktop usage statistics.
list
workspace:statistics:exportDesktopMetrics
Grants permission to export desktop usage statistics.
list
workspace:statistics:listUserMetrics
Grants permission to query user usage statistics.
list
workspace:statistics:exportUserMetrics
Grants permission to export user usage statistics.
list
workspace:appcenter:createBucketCredential
Grants permission to generate OBS bucket credential information.
write
workspace:appcenter:createAndAuthorizeBucket
Grants permission to add a default OBS bucket and access the bucket.
write
workspace:appcenter:listApps
Grants permission to query applications by name.
list
workspace:appcenter:createApp
Grants permission to upload an application.
write
workspace:appcenter:updateApp
Grants permission to modify an application.
write
workspace:appcenter:deleteApp
Grants permission to delete an application.
write
workspace:appcenter:installApp
Grants permission to automatically install an application.
write
workspace:appcenter:listAppAuthorizations
Grants permission to query application authorization information.
list
workspace:appcenter:batchUpdateAppAuthorizations
Grants permission to set application authorization.
write
workspace:appcenter:batchDeleteApps
Grants permission to delete applications in batches.
write
workspace:appcenter:batchDisableApps
Grants permission to set applications to be invisible in batches.
write
workspace:appcenter:batchEnableApps
Grants permission to set applications to be visible in batches.
write
workspace:appcenter:batchInstallApps
Grants permission to automatically install applications in batches.
write
workspace:appcenter:listAppCatalogs
Grants permission to query application categories.
list
workspace:appcenter:listJobs
Grants permission to query application installation job information.
list
workspace:appcenter:batchDeleteJobs
Grants permission to delete jobs in batches.
write
workspace:appcenter:retryJobs
Grants permission to retry a failed job.
write
workspace:appcenter:createAppRule
Grants permission to create an application rule.
write
workspace:appcenter:listAppRule
Grants permission to query application rules.
list
workspace:appcenter:updateAppRule
Grants permission to modify an application rule.
write
workspace:appcenter:deleteAppRule
Grants permission to delete an application rule.
write
workspace:appcenter:batchDeleteAppRules
Grants permission to delete application rules in batches.
write
workspace:appcenter:enableRuleRestriction
Grants permission to enable rule control.
write
workspace:appcenter:disableRuleRestriction
Grants permission to disable rule control.
write
workspace:appcenter:addRestrictedRule
Grants permission to add a control rule.
write
workspace:appcenter:listRestrictedRule
Grants permission to query control rules.
list
workspace:appcenter:deleteRestrictedRule
Grants permission to delete control rules in batches.
write
workspace:appcenter:updateTenantProfile
Grants permission to enable or disable the tenant function.
write
workspace:appcenter:listTenantProfiles
Grants permission to query the tenant function status.
list
workspace:scripts:create
Grants permission to create a script.
write
script *
workspace:scripts:list
Grants permission to query the script list.
list
script *
workspace:scripts:get
Grants permission to query script details.
read
script *
workspace:scripts:put
Grants permission to update a script.
write
script *
workspace:scripts:delete
Grants permission to delete a script.
write
script *
workspace:scripts:execute
Grants permission to run scripts or commands in batches.
write
script *
desktop *
workspace:scripts:getRecordDetail
Grants permission to query script or command execution record details.
read
script *
workspace:scripts:listRecords
Grants permission to query script execution records.
list
script *
workspace:scripts:listTasks
Grants permission to query script tasks.
list
script *
workspace:scripts:retry
Grants permission to retry a script.
write
script *
workspace:scripts:stop
Grants permission to stop a script or command execution task.
write
script *
workspace:scripts:download
Grants permission to download a script output record.
write
script *
workspace:tenants:getShareSpaceConfig
Grants permission to query collaboration configurations.
read
workspace:tenants:updateShareSpaceConfig
Grants permission to modify collaboration configurations.
write
workspace:authConfigs:getStatus
Grants permission to query the authentication status.
read
workspace:privacystatements:sign
Grants permission to sign the privacy statement.
write
workspace:sites:get
Grants permission to query site information.
read
workspace:sites:add
Grants permission to add a site.
write
workspace:sites:delete
Grants permission to delete a site.
write
workspace:sites:updateAccessMode
Grants permission to change the site access mode.
write
workspace:sites:updateSubnets
Grants permission to change the site service subnet.
write
workspace:tenants:checkEnterpriseIds
Grants permission to check whether the enterprise ID has been used.
write
workspace:tenants:updateEnterpriseId
Grants permission to change the enterprise ID.
write
workspace:bandwidth:create
Grants permission to enable the Workspace bandwidth.
write
workspace:bandwidth:list
Grants permission to query the Workspace bandwidth list.
list
workspace:bandwidth:update
Grants permission to modify the Workspace bandwidth.
write
workspace:bandwidth:delete
Grants permission to cancel the Workspace bandwidth.
write
workspace:bandwidth:getControlConfig
Grants permission to query the control configuration of the Workspace bandwidth.
read
workspace:bandwidth:updateControlConfig
Grants permission to modify the control configuration of the Workspace bandwidth.
write
workspace:bandwidth:createChangeOrder
Grants permission to create a Workspace bandwidth change order.
write
workspace:desktops:batchCreateSnapshots
Grants permission to create desktop snapshots in batches.
write
desktop *
workspace:desktops:batchDeleteSnapshots
Grants permission to delete desktop snapshots in batches.
write
desktop *
workspace:desktops:batchRestoreSnapshots
Grants permission to restore desktop snapshots in batches.
write
desktop *
workspace:desktops:listSnapshots
list
workspace:desktops:verifyDesktopName
Grants permission to verify the desktop name.
write
workspace:networks:getAvailableIp
Grants permission to query available IP addresses of a subnet by subnet ID.
read
workspace:desktops:getAdStatus
Grants permission to query the AD network status.
read
workspace:networks:checkIpIfExist
Grants permission to check whether the IP address exists.
write
workspace:images:checkIfExist
Grants permission to check whether the image exists.
write
workspace:wdh:listDesktops
Grants permission to query desktops of a Workspace host.
list
wdh *
workspace:wdh:update
Grants permission to update Workspace host information.
write
wdh *
workspace:bindingPolicies:getTemplate
Grants permission to download the template for terminal-desktop binding.
read
workspace:bindingPolicies:import
Grants permission to import terminal-desktop binding in batches.
write
workspace:statistics:getRunState
Grants permission to collect statistics on running statuses.
read
workspace:statistics:getLoginState
Grants permission to collect statistics on login statuses.
read
workspace:networks:getUsingSubnets
Grants permission to query subnets being used.
read
workspace:networks:listPorts
Grants permission to query ports.
list
workspace:renderDesktops:createConsole
write
workspace:renderDesktops:resize
Grants permission to change rendering desktop specifications.
write
workspace:exclusiveHosts:resizeLites
Grants permission to modify exclusive host specifications.
write
exclusiveHost *
workspace:desktops:getMonitor
Grants permission to query desktop monitoring information.
read
desktop *
workspace:desktops:listDetachInfo
Grants permission to query users unbound from the desktop.
list
desktop *
  • g:TagKeys
workspace:desktops:getSysprepVersion
Grants permission to query Sysprep version information.
read
desktop *
workspace:networks:createNat
Grants permission to enable the Internet access function of the NAT Gateway.
write
workspace:networks:listNats
Grants permission to query the Internet access function of the NAT Gateway.
list
workspace:networks:listSubnets
Grants permission to query subnets.
list
workspace:networks:listVpcs
Grants permission to query VPCs.
list
workspace:policyGroups:createTemplate
Grants permission to create a policy template.
write
workspace:policyGroups:listTemplate
Grants permission to query policy templates.
list
workspace:policyGroups:updateTemplate
Grants permission to update a policy template.
write
workspace:networks:listSecurityGroups
Grants permission to query security groups.
list
workspace:availabilityZones:getSummary
Grants permission to query AZ summary.
read
Grants permission to query AZ details.
read
workspace:users:importUser
Grants permission to import a user list.
write
user *
workspace:users:uploadTemplate
Grants permission to import a desktop user list.
write
user *
Grants permission to update a specified access policy.
write
workspace:desktops:verifySource
Grants permission to verify desktop sources.
write
desktop *
workspace:desktops:listDesktopNetworks
Grants permission to query desktop network information in batches.
list
desktop *
workspace:desktops:batchChangeNetwork
Grants permission to switch desktop networks in batches.
write
desktop *
workspace:jobs:get
Grants permission to query task details.
read
workspace:accessPolicies:importIp
Grants permission to import the IP address list.
write
workspace:accessPolicies:getIpImportTemplate
Grants permission to download the template for importing IP addresses.
read
workspace:sites:listEdgeSites
Grants permission to query edge sites.
list
workspace:sites:checkEdgeSiteResources
Grants permission to verify edge site resources.
write
workspace:ou:listAdOus
Grants permission to query OU information in the AD domain.
list
workspace:ou:listOuUsers
Grants permission to query user information in the OU.
list
workspace:ou:importUsersByOU
Grants permission to import OU users.
write
workspace:appGroup:list
Grants permission to query application groups.
list
appGroup *
workspace:appGroup:create
Grants permission to create an application group.
write
appGroup *
serverGroup
workspace:appGroup:delete
Grants permission to delete an application group.
write
appGroup *
workspace:appGroup:get
Grants permission to query application group details.
read
appGroup *
workspace:appGroup:update
Grants permission to modify an application group.
write
appGroup *
serverGroup
workspace:app:listPublishedApp
Grants permission to query published applications.
list
app *
appGroup *
workspace:app:publish
Grants permission to publish an application.
write
app *
appGroup *
workspace:app:get
Grants permission to query application details.
read
app *
appGroup *
workspace:app:update
Grants permission to modify application information.
write
app *
appGroup *
workspace:app:deleteIcon
Grants permission to delete a custom application icon.
write
app *
appGroup *
workspace:app:uploadIcon
Grants permission to modify a custom application icon.
write
app *
appGroup *
workspace:app:check
Grants permission to verify applications.
write
app *
appGroup *
workspace:app:batchDisable
Grants permission to disable applications in batches.
write
app *
appGroup *
workspace:app:batchEnable
Grants permission to enable applications in batches.
write
app *
appGroup *
workspace:app:unpublish
Grants permission to unpublish applications in batches.
write
app *
appGroup *
workspace:appGroup:listPublishableApp
Grants permission to query applications that can be published.
list
appGroup *
workspace:appGroup:batchDeleteAuthorization
Grants permission to remove application group authorization.
write
appGroup *
user
userGroup
workspace:appGroup:disassociate
Grants permission to disassociate a service group from all application groups.
write
workspace:appGroup:listAuthorization
Grants permission to query application group authorization records.
list
appGroup *
workspace:appGroup:addAuthorization
Grants permission to add application group authorization.
write
appGroup *
user
userGroup
Grants permission to delete application groups in batches.
write
appGroup *
workspace:appGroup:check
Grants permission to verify an application group.
write
workspace:serverGroup:list
Grants permission to query server groups.
list
serverGroup *
  • g:TagKeys
workspace:serverGroup:create
Grants permission to create a server group.
write
serverGroup *
  • g:TagKeys
workspace:serverGroup:delete
Grants permission to delete a server group.
write
serverGroup *
workspace:serverGroup:get
Grants permission to query a specified server group.
read
serverGroup *
workspace:serverGroup:update
Grants permission to modify a server group.
write
serverGroup *
workspace:serverGroup:getServerState
Grants permission to query server statuses in a specified server group.
read
serverGroup *
workspace:serverGroup:listDetail
Grants permission to query basic information about a tenant server group.
list
serverGroup *
workspace:serverGroup:getRestrict
Grants permission to query specified tenant server groups.
read
serverGroup *
workspace:serverGroup:validate
Grants permission to verify a server group.
write
serverGroup *
workspace:serverGroup:tagResource
Grants permission to add a tag to a server group.
tagging
serverGroup *
  • g:TagKeys
workspace:serverGroup:unTagResource
Grants permission to delete a tag from a server group.
tagging
serverGroup *
  • g:TagKeys
workspace:serverGroup:listTagsForResource
Grants permission to query server group tags.
list
serverGroup *
Grants permission to query tags on all servers of a tenant.
list
serverGroup *
workspace:serverGroup:batchCreateTags
Grants permission to add server group tags in batches.
tagging
serverGroup *
  • g:TagKeys
workspace:serverGroup:batchDeleteTags
Grants permission to delete server group tags in batches.
tagging
serverGroup *
  • g:TagKeys
workspace:server:list
Grants permission to query servers.
list
server *
workspace:server:delete
Grants permission to delete a server.
write
server *
workspace:server:get
Grants permission to query a specified server.
read
server *
workspace:server:update
Grants permission to modify a server.
write
server *
workspace:server:changeImage
Grants permission to modify a server image.
write
server *
workspace:server:reinstall
Grants permission to reinstall a server.
write
server *
workspace:server:getVncUrl
Grants permission to obtain a VNC login address.
write
server *
workspace:accessAgent:list
Grants permission to query the latest versions of all HDAs of a tenant.
list
workspace:accessAgent:batchUpgrade
Grants permission to upgrade the HDA version of servers in batches.
write
server *
workspace:accessAgent:listLatestVersion
Grants permission to query the latest HDA version of a tenant.
list
workspace:server:listAccessAgentDetails
Grants permission to query HDA information of a server.
list
server *
workspace:accessAgent:getUpgradeFlag
Grants permission to query HDA upgrade notification flags.
read
workspace:accessAgent:updateUpgradeFlag
Grants permission to update an HDA upgrade notification flag.
write
workspace:accessAgent:listUpgradeRecords
Grants permission to query HDA upgrade tracing records of a server.
list
workspace:server:batchDelete
Grants permission to delete servers in batches.
write
server *
workspace:server:batchChangeMaintainMode
Grants permission to mark the server maintenance status.
write
server *
workspace:server:batchReboot
Grants permission to restart a server.
write
server *
workspace:server:batchRejoinDomain
Grants permission to add servers to a domain again in batches.
write
server *
workspace:server:batchStart
Grants permission to start a server.
write
server *
workspace:server:batchStop
Grants permission to stop a server.
write
server *
workspace:server:batchUpdateTsvi
Grants permission to update virtual session IP configurations of servers in batches.
write
server *
workspace:server:create
Grants permission to create an APS.
write
server *
serverGroup *
  • g:TagKeys
workspace:server:batchMigrateHosts
Grants permission to migrate servers at the source Workspace host to the destination one.
write
server *
wdh *
workspace:server:getMetricData
Grants permission to query monitoring information of an APS.
read
server *
workspace:jobs:batchDeleteSubJobs
Grants permission to delete subtasks in batches.
write
workspace:jobs:countSubJobs
Grants permission to query the number of subtasks.
list
workspace:appWarehouse:authorizeObs
Grants permission to obtain the AK/SK uploaded to an OBS bucket.
write
workspace:appWarehouse:batchDeleteApp
Grants permission to delete specified applications from the application repository in batches.
write
workspace:appWarehouse:ListWarehouseApps
Grants permission to query applications in a tenant application repository.
list
workspace:appWarehouse:createApp
Grants permission to add an application to the application repository.
write
workspace:appWarehouse:deleteApp
Grants permission to delete a specified application from the application repository.
write
workspace:appWarehouse:uploadAppIcon
Grants permission to upload an icon file to the application repository.
write
workspace:appWarehouse:createBucketOrAcl
Grants permission to add a bucket or authorize access to a bucket.
write
workspace:images:listImageJobs
Grants permission to query tasks of a tenant.
list
workspace:images:getImageJob
read
workspace:imageServer:list
Grants permission to query image instances.
list
imageServer *
workspace:imageServer:create
Grants permission to create an image instance.
write
imageServer *
workspace:imageServer:get
Grants permission to query a specified image instance.
read
imageServer *
workspace:imageServer:update
Grants permission to modify an image instance.
write
imageServer *
workspace:imageServer:attachApp
Grants permission to distribute software information to image instances.
write
imageServer *
workspace:imageServer:listLatestAttachedApp
Grants permission to query information about the latest distributed software.
list
imageServer *
workspace:imageServer:recreate
Grants permission to build an Application Streaming image.
write
imageServer *
workspace:imageServer:batchDelete
Grants permission to delete image instances in batches.
write
imageServer *
workspace:imageServer:listImageSubJobs
list
workspace:imageServer:batchDeleteImageSubJobs
write
workspace:imageServer:countImageSubJobs
read
workspace:appGroup:listMailRecord
Grants permission to query records of sending emails on application group authorization.
list
workspace:appGroup:resendMail
Grants permission to resend an email on application group authorization (based on authorization email records).
write
workspace:storage:listPersistentStorage
Grants permission to query Workspace storage space.
list
storage *
workspace:storage:createPersistentStorage
Grants permission to create Workspace storage space.
write
storage *
workspace:storage:deletePersistentStorage
Grants permission to delete Workspace storage space.
write
storage *
workspace:storage:updateUserFolderAssignment
Grants permission to create a personal storage directory.
write
storage *
workspace:storage:updateShareFolderAssignment
Grants permission to change members of a shared directory.
write
storage *
workspace:storage:createShareFolder
Grants permission to create a shared storage directory.
write
storage *
workspace:storage:deleteStorageClaim
Grants permission to delete a shared directory.
write
storage *
workspace:storage:deleteUserStorageAttachment
Grants permission to delete a personal storage directory.
write
storage *
workspace:storage:batchDeletePersistentStorage
Grants permission to delete Workspace storage space in batches.
write
storage *
workspace:storage:listStorageAssignment
Grants permission to query personal storage directories.
list
storage *
workspace:storage:listShareFolder
Grants permission to query shared storage directories.
list
storage *
workspace:policyGroups:deleteTemplate
Grants permission to delete a policy template.
write
workspace:privacystatements:get
Grants permission to query the latest privacy statement.
read
workspace:scalingPolicy:delete
Grants permission to delete an auto scaling policy.
write
workspace:scalingPolicy:list
Grants permission to query auto scaling policies of a server group.
read
workspace:scalingPolicy:create
Grants permission to add or modify an auto scaling policy.
write
workspace:session:listAppConnection
Grants permission to query application usage records.
write
workspace:session:logoffUserSession
Grants permission to log out of a session.
write
workspace:session:listUserConnection
Grants permission to query user login records.
write
workspace:session:listSessionByUserName
Grants permission to query current sessions by username.
list
workspace:storagePolicy:create
Grants permission to add or update a custom policy for storage directory access.
write
storage *
workspace:storagePolicy:list
Grants permission to query policies for storage directory access.
list
storage *
workspace:storage:listSfs3Storage
Grants permission to query SFS 3.0.
list
storage *
workspace:baseResource:list
Grants permission to query AZs.
list
workspace:tenants:listConfigInfo
Grants permission to query enterprise system configurations.
list
workspace:tenants:active
Grants permission to activate and initialize a tenant service.
write
workspace:tenants:listTenantProfile
Grants permission to query tenant information.
list
workspace:server:listServerMetricData
Grants permission to query server monitoring data.
list
server *
workspace:session:listSessions
Grants permission to query enterprise sessions.
list
workspace:appWarehouse:updateApp
Grants permission to update an application in the application repository.
write
workspace:server:batchChangeImage
Grants permission to switch server images in batches.
write
server *
workspace:server:batchReinstall
Grants permission to reinstall servers in batches.
write
server *
read
write
read
write
write
read
read
list
write
read
write
read
write
write
write
read
write
write
read
workspace:desktops:commitAiAccelerateJob
write
read
read
desktop *
write
desktop *
list
write
write
write
write
desktopPool *
user
userGroup
  • g:TagKeys
list
desktopPool *
write
desktopPool *
write
desktopPool *
read
desktopPool *
write
desktopPool *
write
desktopPool *
write
desktopPool *
write
desktopPool *
write
desktopPool *
write
desktopPool *
write
desktopPool *
list
desktopPool *
write
desktopPool *
user
userGroup
list
desktopPool *
list
desktopPool *
write
desktopPool *
script
write
desktopPool *
list
desktop *
  • g:TagKeys
write
desktop *
  • g:TagKeys
list
desktop *
  • g:TagKeys
write
desktop *
write
desktop *
read
desktop *
write
desktop *
write
desktop *
list
desktop *
  • g:TagKeys
write
desktop *
write
desktop *
read
list
write
desktop *
read
desktop *
write
desktop *
write
desktop *
write
desktop *
write
desktop *
write
desktop *
write
desktop *
write
desktop *
read
desktop *
write
desktop *
list
exclusiveHost *
list
desktop *
list
write
write
read
write
desktop *
write
desktop *
write
desktop *
write
write
desktop *
write
desktop *
list
desktop *
write
desktop *
list
desktop *
tagging
desktop *
  • g:TagKeys
tagging
desktop *
  • g:TagKeys
list
tagging
desktop *
  • g:TagKeys
list
write
exclusiveHost *
list
exclusiveHost *
write
read
exclusiveHost *
write
exclusiveHost *
write
exclusiveHost *
list
list
write
list
list
list
list
list
write
write
write
read
list
write
write
write
write
write
write
list
write
list
scheduledTask *
write
scheduledTask *
desktop
desktopPool
server
serverGroup
read
scheduledTask *
write
scheduledTask *
desktop
desktopPool
server
serverGroup
write
scheduledTask *
read
write
scheduledTask *
list
scheduledTask *
read
scheduledTask *
list
scheduledTask *
write
user *
write
desktop *
write
desktop *
write
desktop *
read
desktop *
write
desktop *
write
desktop *
list
read
read
list
read
write
read
write
write
write
write
desktop
write
desktop
write
desktop
read
wdh *
workspace:wdh:get
read
wdh *
read
desktop *
write
desktop *
write
desktop *
write
desktop
write
desktop
list
list
list
list
write
write
read
write
read
write
list
list
list
list
list
userGroup *
list
user *
write
user *
list
userGroup *
write
user *
write
user *
write
user *
write
user *
list
list
list
userGroup *
write
userGroup *
write
userGroup *
write
userGroup *
write
userGroup *
write
userGroup *
user *
list
userGroup *
list
write
workspace:ou:get
list
workspace:ou:create
write
workspace:ou:delete
write
workspace:ou:update
write
list
policyGroup *
write
policyGroup *
desktop
desktopPool
user
userGroup
appGroup
write
policyGroup *
read
policyGroup *
write
policyGroup *
user
userGroup
appGroup
list
policyGroup *
list
policyGroup *
write
policyGroup *
list
policyGroup *
write
policyGroup *
desktop
desktopPool
user
userGroup
appGroup
list
policyGroup *
read
policyGroup *
list
user *
write
user *
write
user *
workspace:users:get
read
user *
write
user *
write
user *
write
user *
write
user *
read
write
user *
list
user *
read
write
user *
list
list
write
read
list
read
read
read
read
write
write
write
list
list
list
list
list
list
write
write
list
write
write
write
write
list
write
write
write
write
write
list
list
write
write
write
list
write
write
write
write
write
write
list
write
Grants permission to disable the tenant function.
write
list
write
script *
list
script *
read
script *
write
script *
write
script *
write
script *
desktop *
read
script *
list
script *
list
script *
write
script *
write
script *
write
script *
read
write
read
write
workspace:sites:get
read
workspace:sites:add
write
write
write
write
write
write
write
list
write
write
read
write
write
write
desktop *
write
desktop *
write
desktop *
list
write
read
read
write
write
list
wdh *
write
wdh *
read
write
read
read
read
list
write
write
write
exclusiveHost *
read
desktop *
list
desktop *
  • g:TagKeys
read
desktop *
write
list
list
list
write
list
write
list
read
read
write
user *
write
user *
write
write
desktop *
list
desktop *
write
desktop *
workspace:jobs:get
read
write
read
list
write
list
list
write
list
appGroup *
write
appGroup *
serverGroup
write
appGroup *
read
appGroup *
write
appGroup *
serverGroup
list
app *
appGroup *
write
app *
appGroup *
workspace:app:get
read
app *
appGroup *
write
app *
appGroup *
write
app *
appGroup *
write
app *
appGroup *
workspace:app:check
write
app *
appGroup *
write
app *
appGroup *
write
app *
appGroup *
write
app *
appGroup *
list
appGroup *
write
appGroup *
user
userGroup
write
list
appGroup *
write
appGroup *
user
userGroup
write
appGroup *
write
list
serverGroup *
  • g:TagKeys
write
serverGroup *
  • g:TagKeys
write
serverGroup *
read
serverGroup *
write
serverGroup *
read
serverGroup *
list
serverGroup *
read
serverGroup *
write
serverGroup *
tagging
serverGroup *
  • g:TagKeys
tagging
serverGroup *
  • g:TagKeys
list
serverGroup *
list
serverGroup *
tagging
serverGroup *
  • g:TagKeys
tagging
serverGroup *
  • g:TagKeys
list
server *
write
server *
read
server *
write
server *
write
server *
write
server *
write
server *
list
write
server *
list
list
server *
read
write
list
write
server *
write
server *
write
server *
write
server *
write
server *
write
server *
write
server *
write
server *
serverGroup *
  • g:TagKeys
write
server *
wdh *
read
server *
write
list
write
write
list
write
write
write
write
list
read
list
imageServer *
write
imageServer *
read
imageServer *
write
imageServer *
write
imageServer *
list
imageServer *
write
imageServer *
write
imageServer *
list
write
read
list
write
list
storage *
write
storage *
write
storage *
write
storage *
write
storage *
write
storage *
write
storage *
write
storage *
write
storage *
list
storage *
list
storage *
write
read
write
read
write
write
write
write
list
write
storage *
list
storage *
list
storage *
list
list
write
list
list
server *
list
write
write
server *
write
server *
workspace:tenants:updateAccessAddressBackupConfig
Grants permission to modify the backup configuration of the Workspace access address.
write
workspace:tenants:listAccessAddressBackupConfig
Grants permission to obtain the backup configuration of the Workspace access address.
list
workspace:desktops:listWithConnectStatus
Grants permission to query desktop connection statuses.
list
workspace:orders:createDesktopOrder
Grants permission to create a desktop order.
write
workspace:products:listHourPackageProducts
Grants permission to query available hourly packages.
list
Each API of Workspace supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by Workspace APIs
API
Action
Dependency
GET /v2/{project_id}/auth-config/method-config
PUT /v2/{project_id}/auth-config/method-config
GET /v2/{project_id}/assist-auth-config/method-config
PUT /v2/{project_id}/assist-auth-config/method-config
POST /v2/{project_id}/workspace-jobs/{job_id}/actions
GET /v2/{project_id}/quotas
GET /v2/{project_id}/tenants/roles
GET /v2/{project_id}/tenant-configs
PUT /v2/{project_id}/tenant-configs
GET /v2/{project_id}/nat-mapping-configs
PUT /v2/{project_id}/nat-mapping-configs
GET /v2/{project_id}/workspaces
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:securityGroups:get
POST /v2/{project_id}/workspaces
  • eip:bandwidths:create
  • eip:publicIps:create
  • elb:healthmonitors:create
  • elb:healthmonitors:show
  • elb:listeners:create
  • elb:listeners:update
  • elb:listeners:show
  • elb:listeners:list
  • elb:loadbalancers:create
  • elb:loadbalancers:update
  • elb:loadbalancers:show
  • elb:members:create
  • elb:members:list
  • elb:members:update
  • elb:pools:create
  • elb:pools:update
  • elb:pools:show
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:securityGroupRules:create
  • vpc:securityGroupRules:delete
  • vpc:securityGroupRules:get
  • vpc:securityGroups:create
  • vpc:subnets:get
  • vpc:subnets:update
  • vpc:vpcs:get
  • vpcep:endpoints:create
  • vpcep:endpoints:get
DELETE /v2/{project_id}/workspaces
  • elb:healthmonitors:delete
  • elb:listeners:delete
  • elb:loadbalancers:delete
  • elb:members:delete
  • elb:members:list
  • elb:pools:delete
  • elb:pools:show
  • vpc:ports:delete
  • vpc:securityGroups:delete
  • vpcep:endpoints:delete
  • eip:publicIps:disassociateInstance
  • eip:bandwidths:delete
  • eip:publicIps:delete
PUT /v2/{project_id}/workspaces
  • elb:members:list
  • elb:pools:create
  • elb:pools:delete
  • elb:pools:update
  • elb:pools:show
  • vpc:subnets:get
  • vpc:vpcs:get
GET /v2/{project_id}/workspaces/lock-status
PUT /v2/{project_id}/workspaces/lock-status
POST /v2/{project_id}/agencies
  • iam:agencies:listV5
  • iam:agencies:getV5
  • iam:agencies:createServiceLinkedAgencyV5
  • iam:roles:getRole
  • iam:roles:listRoles
  • iam:agencies:getAgency
  • iam:agencies:listAgencies
  • iam:agencies:createAgency
  • iam:permissions:listRolesForAgencyOnProject
  • iam:permissions:grantRoleToAgencyOnProject
GET /v2/{project_id}/agencies
POST /v3/{project_id}/desktops/{desktop_id}/ai-accelerate-job
POST /v2/{project_id}/desktops/{desktop_id}/ai-accelerate-job
GET /v2/{project_id}/ai-accelerate-job/{job_id}
POST /v2/{project_id}/sysprep
POST /v2/{project_id}/verification/batch-change-image
ims:images:list
GET /v2/{project_id}/desktop-name-policies
POST /v2/{project_id}/desktop-name-policies
PUT /v2/{project_id}/desktop-name-policies/{policy_id}
POST /v2/{project_id}/desktop-name-policies/batch-delete
POST /v2/{project_id}/desktop-pools
  • ims:images:get
  • ims:images:list
  • ims:images:share
  • ims:images:updateMemberStatus
  • ims:images:deleteMember
  • ims:images:addMember
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
  • dss:pools:list
GET /v2/{project_id}/desktop-pools
ims:images:list
PUT /v2/{project_id}/desktop-pools/{pool_id}
DELETE /v2/{project_id}/desktop-pools/{pool_id}
GET /v2/{project_id}/desktop-pools/{pool_id}
ims:images:list
POST /v2/{project_id}/desktop-pools/{pool_id}/expand
  • ims:images:get
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
  • dss:pools:list
POST /v2/{project_id}/desktop-pools/{pool_id}/resize
  • vpc:subnets:get
  • ims:images:list
POST /v2/{project_id}/desktop-pools/{pool_id}/rebuild
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
POST /v2/{project_id}/desktop-pools/{pool_id}/volumes/batch-add
POST /v2/{project_id}/desktop-pools/{pool_id}/volumes/batch-delete
POST /v2/{project_id}/desktop-pools/{pool_id}/volumes/batch-expand
POST /v2/{project_id}/desktop-pools/{pool_id}/action
GET /v2/{project_id}/desktop-pools/{pool_id}/users
POST /v2/{project_id}/desktop-pools/{pool_id}/users
ims:images:list
GET /v2/{project_id}/desktop-pools/{pool_id}/desktops
  • vpc:ports:get
  • vpc:ports:list
  • eip:publicIps:list
  • nat:snatRules:list
GET /v2/{project_id}/desktop-pools/script-execution-tasks/detail
POST /v2/{project_id}/desktop-pools/{pool_id}/script-executions
POST /v2/{project_id}/desktop-pools/{pool_id}/notifications
GET /v3/{project_id}/desktops/export
  • vpc:ports:get
  • vpc:ports:list
  • ims:images:get
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • eip:publicIps:get
  • eip:publicIps:associateInstance
  • eip:publicIps:createTags
  • vpc:quotas:list
  • vpc:subnets:get
  • vpc:vpcs:get
  • dss:pools:list
GET /v2/{project_id}/desktops
PUT /v2/{project_id}/desktops/{desktop_id}
DELETE /v2/{project_id}/desktops/{desktop_id}
  • vpc:ports:get
  • vpc:ports:delete
GET /v2/{project_id}/desktops/{desktop_id}
  • vpc:ports:get
  • vpc:ports:list
POST /v2/{project_id}/desktops/batch-delete
  • vpc:ports:get
  • vpc:ports:delete
POST /v2/{project_id}/desktops/logoff
GET /v2/{project_id}/desktops/detail
  • vpc:ports:get
  • vpc:ports:list
POST /v2/{project_id}/desktops/action
POST /v2/{project_id}/desktops/resize
  • vpc:subnets:get
  • ims:images:list
GET /v2/{project_id}/connections/status
GET /v2/{project_id}/desktops/status
POST /v2/{project_id}/desktops/rebuild
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
GET /v2/{project_id}/desktops/{desktop_id}/actions
GET /v2/{project_id}/desktops/{desktop_id}/remote-consoles
PUT /v2/{project_id}/desktops/sids
POST /v2/{project_id}/desktops/{desktop_id}/rejoin-domain
POST /v2/{project_id}/desktops/desktop-to-image
  • ims:quotas:get
  • ims:images:get
  • ims:images:list
  • ims:images:setTags
  • ims:images:setOrDeleteTags
  • ims:images:copyInRegion
  • ims:serverImages:create
POST /v2/{project_id}/desktops/batch-detach
vpc:ports:get
POST /v2/{project_id}/desktops/detach
vpc:ports:get
POST /v2/{project_id}/desktops/attach
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
GET /v2/{project_id}/desktops/{desktop_id}/networks
  • vpc:vpcs:get
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:get
PUT /v2/{project_id}/desktops/{desktop_id}/networks
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:networks:get
  • vpc:ports:get
  • vpc:ports:create
  • vpc:ports:update
  • vpc:ports:delete
GET /v2/{project_id}/exclusive-hosts/{host_id}/desktops
GET /v2/{project_id}/all-desktops
GET /v2/{project_id}/desktop-associate/discover-vm/infos
POST /v2/{project_id}/desktop-associate/tasks
POST /v2/{project_id}/desktop-associate/discover-vm/switch
GET /v2/{project_id}/desktop-associate/discover-vm/switch
PUT /v2/{project_id}/desktops/maintenance-mode
POST /v2/{project_id}/desktops/pre-batch-attach
POST /v2/{project_id}/desktops/batch-attach
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
PUT /v2/{project_id}/desktops/change-username
POST /v2/{project_id}/desktops/notifications
POST /v2/{project_id}/desktops/{desktop_id}/migrate
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:update
  • vpc:ports:get
GET /v2/{project_id}/desktops/agents
POST /v2/{project_id}/desktops/agents
GET /v2/{project_id}/desktops/{desktop_id}/tags
POST /v2/{project_id}/desktops/{desktop_id}/tags
DELETE /v2/{project_id}/desktops/{desktop_id}/tags/{key}
GET /v2/{project_id}/desktops/tags
POST /v2/{project_id}/desktops/{desktop_id}/tags/action
POST /v2/{project_id}/desktops/resource_instances/action
POST /v2/{project_id}/desktops/batch-tags
DELETE /v2/{project_id}/desktops/batch-tags
POST /v2/{project_id}/exclusive-hosts
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
POST /v2/{project_id}/exclusive-hosts/check-limits
PUT /v2/{project_id}/exclusive-hosts/{host_id}
DELETE /v2/{project_id}/exclusive-hosts/{host_id}
GET /v2/{project_id}/market-images
ims:images:list
GET /v2/{project_id}/mkp/commodities/commodity-ids
POST /v2/{project_id}/mkp/order
POST /v2/{project_id}/mkp/product-reserve
GET /v2/{project_id}/mkp/commodities/{commodity_id}/relation-commodities
GET /v2/{project_id}/mkp/commodities/agreements
GET /v2/{project_id}/eips
  • eip:bandwidths:list
POST /v2/{project_id}/eips
  • vpc:quotas:list
POST /v2/{project_id}/eips/binding
  • eip:publicIps:get
POST /v2/{project_id}/eips/unbinding
GET /v2/{project_id}/eips/quotas
vpc:quotas:list
GET /v2/{project_id}/nat-gateways
  • vpc:subnets:get
  • vpc:vpcs:get
  • nat:natGateways:list
POST /v2/{project_id}/periodic/subscribe/order
  • ims:images:list
  • vpc:vpcs:get
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:get
  • bss:order:update
POST /v2/{project_id}/periodic/{desktop_id}/change/order
  • ims:images:list
  • bss:order:update
POST /v2/{project_id}/periodic/change/batch-order
  • ims:images:list
  • bss:order:update
POST /v2/{project_id}/periodic/inquiry/change-image
ims:images:list
POST /v2/{project_id}/desktop-pool/periodic/change/order
  • ims:images:list
  • bss:order:update
POST /v2/{project_id}/desktop-pool/periodic/inquiry/add-volume
ims:images:list
POST /v2/{project_id}/desktop-pool/periodic/inquiry/change-image
ims:images:list
POST /v2/{project_id}/desktop-pool/periodic/inquiry/extend-volume
ims:images:list
POST /v2/{project_id}/desktop-pool/periodic/inquiry/resize
ims:images:list
POST /v2/{project_id}/periodic/inquiry/add-resources
ims:images:list
GET /v2/{project_id}/checkOrderLimits
POST /v2/{project_id}/render-desktops
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
DELETE /v2/{project_id}/render-desktops
  • vpc:ports:get
  • vpc:ports:delete
GET /v2/{project_id}/render-desktops
POST /v2/{project_id}/render-desktops/action
GET /v2/{project_id}/scheduled-tasks
POST /v2/{project_id}/scheduled-tasks
GET /v2/{project_id}/scheduled-tasks/{task_id}
PUT /v2/{project_id}/scheduled-tasks/{task_id}
DELETE /v2/{project_id}/scheduled-tasks/{task_id}
POST /v2/{project_id}/scheduled-tasks/future-executions
POST /v2/{project_id}/scheduled-tasks/batch-delete
GET /v2/{project_id}/scheduled-tasks/{task_id}/records
GET /v2/{project_id}/scheduled-tasks/{task_id}/records/{record_id}
POST /v2/{project_id}/scheduled-tasks/{task_id}/records/export
POST /v2/{project_id}/user/share-resources
POST /v2/{project_id}/desktop/sub-resources
POST /v2/{project_id}/desktop/delete-sub-resources
POST /v2/{project_id}/desktops/{desktop_id}/snapshots
GET /v2/{project_id}/desktops/{desktop_id}/snapshots
DELETE /v2/{project_id}/desktops/{desktop_id}/snapshots
POST /v2/{project_id}/desktops/{desktop_id}/snapshots/restore
GET /v2/{project_id}/statistics
GET /v2/{project_id}/desktops/statistics/unused
POST /v2/{project_id}/desktops/statistics/used
GET /v3/{project_id}/terminals/binding-desktops/template/export
GET /v2/{project_id}/terminals/binding-desktops/config
POST /v2/{project_id}/terminals/binding-desktops/config
PUT /v2/{project_id}/terminals/binding-desktops
POST /v2/{project_id}/terminals/binding-desktops/batch-delete
POST /v2/{project_id}/desktops/{desktop_id}/volumes/batch-delete
POST /v2/{project_id}/volumes
POST /v2/{project_id}/volumes/expand
GET /v2/{project_id}/hosts/types
workspace:wdh:get
GET /v2/{project_id}/desktops/{desktop_id}/remote-assistance
POST /v2/{project_id}/desktops/{desktop_id}/remote-assistance
DELETE /v2/{project_id}/desktops/{desktop_id}/remote-assistance
POST /v2/{project_id}/desktops/{desktop_id}/volumes/{volume_id}/expand
GET /v2/{project_id}/dss-pools/detail
dss:pools:list
GET /v2/{project_id}/common/timezones
GET /v3/{project_id}/desktops/connections/export
GET /v2/{project_id}/images
ims:images:list
POST /v2/{project_id}/policy-groups/import
POST /v2/{project_id}/access-policy
GET /v2/{project_id}/access-policy
DELETE /v2/{project_id}/access-policy
GET /v2/{project_id}/access-policy/{access_policy_id}/objects
PUT /v2/{project_id}/access-policy/{access_policy_id}/objects
GET /v2/{project_id}/products
ecs:cloudServerFlavors:get
GET /v2/{project_id}/products/sharer
GET /v2/{project_id}/products/adninternet
GET /v2/{project_id}/availability-zones
GET /v2/{project_id}/groups/export
POST /v3/{project_id}/users/export
POST /v2/{project_id}/users/import
GET /v3/{project_id}/groups/{group_id}/users/export
GET /v2/{project_id}/groups/{group_id}/users/export
POST /v2/{project_id}/users/{user_id}/actions
GET /v2/{project_id}/users/{user_id}/random-password
DELETE /v2/{project_id}/users/{user_id}/otp-devices
POST /v2/{project_id}/users/{user_id}/resend-email
GET /v2/{project_id}/connections/desktops
GET /v2/{project_id}/connections/desktops/export
GET /v2/{project_id}/connections/online-users
GET /v2/{project_id}/desktops/connections
GET /v2/{project_id}/desktops/connections/export
GET /v2/{project_id}/desktops/online-users
POST /v2/{project_id}/groups
POST /v2/{project_id}/groups/batch-delete
DELETE /v2/{project_id}/groups/{group_id}
PUT /v2/{project_id}/groups/{group_id}
POST /v2/{project_id}/groups/{group_id}/actions
GET /v2/{project_id}/workspace-sub-jobs
POST /v2/{project_id}/workspace-sub-jobs/batch-delete
GET /v2/{project_id}/ous
workspace:ou:get
POST /v2/{project_id}/ous
workspace:ou:create
DELETE /v2/{project_id}/ous/{ou_id}
workspace:ou:delete
PUT /v2/{project_id}/ous/{ou_id}
workspace:ou:update
GET /v2/{project_id}/policy-groups
DELETE /v2/{project_id}/policy-groups/{policy_group_id}
GET /v2/{project_id}/policy-groups/{policy_group_id}
PUT /v2/{project_id}/policy-groups/{policy_group_id}
POST /v2/{project_id}/policy-groups/export
GET /v2/{project_id}/policy-groups/{policy_group_id}/policies
PUT /v2/{project_id}/policy-groups/{policy_group_id}/policies
GET /v2/{project_id}/policy-groups/{policy_group_id}/targets
PUT /v2/{project_id}/policy-groups/{policy_group_id}/targets
GET /v2/{project_id}/policy-groups/detail
GET /v2/{project_id}/policy-groups/original-policies
workspace:users:get
PUT /v2/{project_id}/users/{user_id}
POST /v2/{project_id}/users/batch-delete
POST /v2/{project_id}/users/password
POST /v2/{project_id}/users/password-token
GET /v2/{project_id}/users/desktop-users/template
POST /v2/{project_id}/users/exist
GET /v2/{project_id}/users/{user_id}/otp-devices
GET /v2/{project_id}/users/template/download
POST /v2/{project_id}/users/export
POST /v2/{project_id}/users/batch-create
GET /v2/{project_id}/volume/products
GET /v2/{project_id}/export-tasks
POST /v2/{project_id}/export-tasks/batch-delete
GET /v2/{project_id}/export-tasks/{task_id}/download
GET /v2/{project_id}/alarms
ces:alarmHistory:list
GET /v2/{project_id}/statistics/alarms
GET /v2/{project_id}/statistics/growth-rate
GET /v2/{project_id}/statistics/metrics
GET /v2/{project_id}/statistics/metrics/trend
PUT /v2/{project_id}/statistics/notify-rules/{rule_id}
smn:topic:get
DELETE /v2/{project_id}/statistics/notify-rules/{rule_id}
POST /v2/{project_id}/statistics/notify-rules
smn:topic:get
GET /v2/{project_id}/statistics/notify-rules
GET /v2/{project_id}/statistics/notification-records
GET /v2/{project_id}/statistics/metrics/desktops
GET /v2/{project_id}/statistics/metrics/desktops/export
GET /v2/{project_id}/statistics/metrics/users
GET /v2/{project_id}/statistics/metrics/users/export
GET /v3/{project_id}/statistics/metrics/desktops/export
GET /v3/{project_id}/statistics/metrics/users/export
POST /v1/{project_id}/app-center/buckets/actions/create-credential
  • obs:bucket:GetBucketAcl
  • obs:object:PutObject
  • obs:object:DeleteObject
  • obs:bucket:HeadBucket
  • obs:bucket:PutBucketAcl
  • obs:bucket:PutReplicationConfiguration
  • obs:bucket:CreateBucket
  • obs:bucket:PutBucketCORS
GET /v1/{project_id}/app-center/apps
POST /v1/{project_id}/app-center/apps
PATCH /v1/{project_id}/app-center/apps/{app_id}
DELETE /v1/{project_id}/app-center/apps/{app_id}
POST /v1/{project_id}/app-center/apps/{app_id}/actions/auto-install
GET /v1/{project_id}/app-center/apps/{app_id}/authorizations
POST /v1/{project_id}/app-center/apps/{app_id}/actions/assign-authorizations
POST /v1/{project_id}/app-center/apps/actions/batch-delete
POST /v1/{project_id}/app-center/apps/actions/batch-disable
POST /v1/{project_id}/app-center/apps/actions/batch-enable
POST /v1/{project_id}/app-center/apps/actions/batch-assign-authorization
POST /v1/{project_id}/app-center/apps/actions/batch-auto-install
GET /v1/{project_id}/app-center/app-catalogs
GET /v1/{project_id}/app-center/jobs
POST /v1/{project_id}/app-center/jobs/actions/batch-delete
POST /v1/{project_id}/app-center/jobs/actions/retry
POST /v1/{project_id}/app-center/app-rules
GET /v1/{project_id}/app-center/app-rules
PATCH /v1/{project_id}/app-center/app-rules/{rule_id}
DELETE /v1/{project_id}/app-center/app-rules/{rule_id}
POST /v1/{project_id}/app-center/app-rules/batch-delete
POST /v1/{project_id}/app-center/app-rules/actions/enable-rule-restriction
POST /v1/{project_id}/app-center/app-rules/actions/disable-rule-restriction
POST /v1/{project_id}/app-center/app-restricted-rules
GET /v1/{project_id}/app-center/app-restricted-rules
POST /v1/{project_id}/app-center/app-restricted-rules/actions/batch-delete
PATCH /v1/{project_id}/app-center/profiles
GET /v1/{project_id}/app-center/profiles
POST /v2/{project_id}/scripts
GET /v2/{project_id}/scripts
GET /v2/{project_id}/scripts/{script_id}
PUT /v2/{project_id}/scripts/{script_id}
DELETE /v2/{project_id}/scripts/{script_id}
POST /v2/{project_id}/script-executions
GET /v2/{project_id}/script-execution-records/{record_id}
GET /v2/{project_id}/script-execution-tasks
POST /v2/{project_id}/script-executions/retry
POST /v2/{project_id}/script-executions/stop
POST /v2/{project_id}/script-execution-records/{record_id}/download
GET /v2/{project_id}/share-space/configuration
PUT /v2/{project_id}/share-space/configuration
GET /v2/{project_id}/auth-config/status
POST /v2/{project_id}/privacystatement
GET /v2/{project_id}/quotas/detail
workspace:quotas:get
GET /v2/{project_id}/sites
workspace:sites:get
POST /v2/{project_id}/sites
workspace:sites:add
  • elb:members:list
  • elb:pools:create
  • elb:pools:update
  • elb:pools:show
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:subnets:get
  • vpc:vpcs:get
DELETE /v2/{project_id}/sites/{site_id}
  • elb:members:list
  • elb:pools:delete
  • elb:pools:show
  • vpc:ports:delete
PUT /v2/{project_id}/sites/{site_id}/access-mode
  • elb:members:list
  • elb:pools:create
  • elb:pools:delete
  • elb:pools:update
  • elb:pools:show
  • vpc:subnets:get
  • vpc:vpcs:get
PUT /v2/{project_id}/sites/{site_id}/subnet-ids
  • vpc:subnets:get
  • vpc:vpcs:get
GET /v2/{project_id}/tenants/lock-status
workspace:tenants:getLockStatus
PUT /v2/{project_id}/tenants/lock-status
workspace:tenants:unlock
POST /v2/{project_id}/workspaces/enterprise-ids/check
PUT /v2/{project_id}/workspaces/enterprise-id
POST /v2/{project_id}/bandwidths
GET /v2/{project_id}/bandwidths
POST /v2/{project_id}/bandwidths/{bandwidth_id}/update
DELETE /v2/{project_id}/bandwidths/{bandwidth_id}
GET /v2/{project_id}/bandwidths/{bandwidth_id}/control-list
PUT /v2/{project_id}/bandwidths/{bandwidth_id}/control-list
POST /v2/{project_id}/bandwidths/{bandwidth_id}/periodic/change/order
POST /v2/{project_id}/adns
GET /v2/{project_id}/adns
POST /v2/{project_id}/desktops-adn/batch-delete
POST /v2/{project_id}/snapshots/batch-create
POST /v2/{project_id}/snapshots/batch-delete
POST /v2/{project_id}/snapshots/batch-restore
GET /v2/{project_id}/snapshots
POST /v2/{project_id}/verification/desktop-name
GET /v2/{project_id}/subnets/{subnet_id}/available-ip
GET /v2/{project_id}/ad/status
GET /v2/{project_id}/ip-exist
POST /v2/{project_id}/desktops/check-images
ims:images:list
GET /v2/{project_id}/hosts/{host_id}/servers
PUT /v2/{project_id}/hosts
GET /v2/{project_id}/terminals/binding-desktops/template
POST /v2/{project_id}/terminals/binding-desktops/template/import
GET /v2/{project_id}/terminals/binding-desktops/template/export
GET /v2/{project_id}/desktops/statistics/run-state
GET /v2/{project_id}/desktops/statistics/login-state
GET /v2/{project_id}/subnets/using-subnets
GET /v2/{project_id}/ports
GET /v2/{project_id}/render-desktops/{desktop_id}/remote-consoles
PUT /v2/{project_id}/render-desktops/resize
POST /v2/{project_id}/exclusive-hosts/{host_id}/resize-lites
GET /services/v2/{project_id}/desktops/{desktop_id}
  • vpc:ports:get
  • vpc:ports:list
GET /v2/{project_id}/desktop-monitor/{desktop_id}
ces:metricData:get
GET /v2/{project_id}/desktops/export
workspace:desktops:export
  • vpc:ports:get
  • vpc:ports:list
GET /v2/{project_id}/desktops/{desktop_id}/detach-info
GET /v2/{project_id}/desktops/{desktop_id}/sysprep
POST /v2/{project_id}/internet
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:networks:get
  • eip:publicIps:update
  • nat:snatRules:create
  • nat:natGateways:create
GET /v2/{project_id}/internet
  • vpc:subnets:get
  • vpc:vpcs:get
POST /v2/{project_id}/quotas/check
workspace:quotas:check
  • vpc:subnets:list
  • vpc:subnets:get
GET /v2/{project_id}/vpcs
vpc:vpcs:list
POST /v2/{project_id}/policy-groups/policy-template
GET /v1/{project_id}/policy-templates
PUT /v2/{project_id}/policy-groups/policy-template/{policy_group_id}
GET /v2/{project_id}/security-groups
GET /v2/{project_id}/availability-zones/summary
GET /v2/{project_id}/availability-zones/detail
POST /v2/{project_id}/users/desktop-users/action/import
POST /v2/{project_id}/users/template-upload
POST /v2/{project_id}/desktops/{desktop_id}/verify-source
GET /v2/{project_id}/desktops/networks
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:networks:get
  • vpc:ports:get
POST /v2/{project_id}/desktops/networks/batch-change
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:networks:get
  • vpc:ports:get
  • vpc:ports:create
  • vpc:ports:update
  • vpc:ports:delete
GET /v2/{project_id}/workspace-jobs/{job_id}
workspace:jobs:get
POST /v2/{project_id}/ip/import
GET /v2/{project_id}/ip/template/download
GET /v2/{project_id}/wks-edge-sites
  • ies:edgeSite:list
  • ies:edgeSite:getMetricData
POST /v2/{project_id}/check-edge-site-resources
  • ies:edgeSite:list
GET /v2/{project_id}/ad-ous
GET /v2/{project_id}/ou-users
POST /v2/{project_id}/ou-users/import
GET /v1/{project_id}/app-groups
POST /v1/{project_id}/app-groups
DELETE /v1/{project_id}/app-groups/{app_group_id}
GET /v1/{project_id}/app-groups/{app_group_id}
PATCH /v1/{project_id}/app-groups/{app_group_id}
GET /v1/{project_id}/app-groups/{app_group_id}/apps
POST /v1/{project_id}/app-groups/{app_group_id}/apps
GET /v1/{project_id}/app-groups/{app_group_id}/apps/{app_id}
workspace:app:get
PATCH /v1/{project_id}/app-groups/{app_group_id}/apps/{app_id}
DELETE /v1/{project_id}/app-groups/{app_group_id}/apps/{app_id}/icon
POST /v1/{project_id}/app-groups/{app_group_id}/apps/{app_id}/icon
POST /v1/{project_id}/app-groups/{app_group_id}/apps/actions/check
workspace:app:check
POST /v1/{project_id}/app-groups/{app_group_id}/apps/actions/disable
POST /v1/{project_id}/app-groups/{app_group_id}/apps/actions/enable
POST /v1/{project_id}/app-groups/{app_group_id}/apps/batch-unpublish
GET /v1/{project_id}/app-groups/{app_group_id}/publishable-app
POST /v1/{project_id}/app-groups/actions/batch-delete-authorization
POST /v1/{project_id}/app-groups/actions/disassociate-app-group
GET /v1/{project_id}/app-groups/actions/list-authorizations
POST /v1/{project_id}/app-groups/authorizations
POST /v1/{project_id}/app-groups/batch-delete
POST /v1/{project_id}/app-groups/rules/validate
GET /v1/{project_id}/app-server-groups
POST /v1/{project_id}/app-server-groups
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
DELETE /v1/{project_id}/app-server-groups/{server_group_id}
GET /v1/{project_id}/app-server-groups/{server_group_id}
PATCH /v1/{project_id}/app-server-groups/{server_group_id}
ims:images:list
GET /v1/{project_id}/app-server-groups/{server_group_id}/state
GET /v1/{project_id}/app-server-groups/actions/list
GET /v1/{project_id}/app-server-groups/resources/restrict
POST /v1/{project_id}/app-server-groups/rules/validate
POST /v1/{project_id}/server-group/{server_group_id}/tags/create
DELETE /v1/{project_id}/server-group/{server_group_id}/tags/delete
GET /v1/{project_id}/server-group/{server_group_id}/tags
GET /v1/{project_id}/server-group/tags
POST /v1/{project_id}/server-group/tags/batch-create
DELETE /v1/{project_id}/server-group/tags/batch-delete
GET /v1/{project_id}/app-servers
DELETE /v1/{project_id}/app-servers/{server_id}
  • vpc:ports:delete
  • vpc:ports:get
GET /v1/{project_id}/app-servers/{server_id}
PATCH /v1/{project_id}/app-servers/{server_id}
POST /v1/{project_id}/app-servers/{server_id}/actions/change-image
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
POST /v1/{project_id}/app-servers/{server_id}/actions/reinstall
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
GET /v1/{project_id}/app-servers/{server_id}/actions/vnc
GET /v1/{project_id}/app-servers/access-agent/latest-version
PATCH /v1/{project_id}/app-servers/access-agent/actions/upgrade
GET /v1/{project_id}/app-servers/access-agent/list
GET /v1/{project_id}/app-servers/access-agent/upgrade-flag
PATCH /v1/{project_id}/app-servers/access-agent/upgrade-flag
GET /v1/{project_id}/app-servers/access-agent/upgrade-record
POST /v1/{project_id}/app-servers/actions/batch-delete
  • vpc:ports:delete
  • vpc:ports:get
PATCH /v1/{project_id}/app-servers/actions/batch-maint
PATCH /v1/{project_id}/app-servers/actions/batch-reboot
PATCH /v1/{project_id}/app-servers/actions/batch-rejoin-domain
PATCH /v1/{project_id}/app-servers/actions/batch-start
PATCH /v1/{project_id}/app-servers/actions/batch-stop
PATCH /v1/{project_id}/app-servers/actions/batch-update-tsvi
  • vpc:subnets:get
  • vpc:ports:update
POST /v1/{project_id}/app-servers/actions/create
  • ims:images:list
  • ims:images:share
  • ims:images:get
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:create
  • vpc:ports:get
  • vpc:ports:delete
  • vpc:vpcs:get
  • dss:pools:list
PATCH /v1/{project_id}/app-servers/hosts/batch-migrate
GET /v1/{project_id}/app-servers/metric-data/{server_id}
GET /v1/{project_id}/app-server-sub-jobs
POST /v1/{project_id}/app-server-sub-jobs/actions/batch-delete
GET /v1/{project_id}/app-server-sub-jobs/actions/count
POST /v1/{project_id}/app-warehouse/action/authorize
POST /v1/{project_id}/app-warehouse/actions/batch-delete
GET /v1/{project_id}/app-warehouse/apps
POST /v1/{project_id}/app-warehouse/apps
DELETE /v1/{project_id}/app-warehouse/apps/{id}
POST /v1/{project_id}/app-warehouse/apps/icon
POST /v1/{project_id}/app-warehouse/bucket-and-acl/create
GET /v1/{project_id}/check/quota
GET /v1/{project_id}/image-server-jobs
GET /v1/{project_id}/image-server-jobs/{job_id}
GET /v1/{project_id}/image-servers
POST /v1/{project_id}/image-servers
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
GET /v1/{project_id}/image-servers/{server_id}
PATCH /v1/{project_id}/image-servers/{server_id}
POST /v1/{project_id}/image-servers/{server_id}/actions/attach-app
GET /v1/{project_id}/image-servers/{server_id}/actions/latest-attached-app
POST /v1/{project_id}/image-servers/{server_id}/actions/recreate-image
  • vpc:ports:get
  • vpc:subnets:get
  • ims:quotas:get
  • ims:images:get
  • ims:images:list
PATCH /v1/{project_id}/image-servers/actions/batch-delete
GET /v1/{project_id}/image-server-sub-jobs
PATCH /v1/{project_id}/image-server-sub-jobs/actions/batch-delete
GET /v1/{project_id}/image-server-sub-jobs/actions/count
GET /v2/{project_id}/job/{job_id}
workspace:jobs:get
GET /v1/{project_id}/mails
POST /v1/{project_id}/mails/actions/send
POST /v1/{project_id}/mails/actions/send-by-authorization
GET /v1/{project_id}/persistent-storages
POST /v1/{project_id}/persistent-storages
  • obs:bucket:PutBucketPolicy
DELETE /v1/{project_id}/persistent-storages/{storage_id}
  • obs:object:GetObject
POST /v1/{project_id}/persistent-storages/{storage_id}/actions/assign-folder
POST /v1/{project_id}/persistent-storages/{storage_id}/actions/assign-share-folder
POST /v1/{project_id}/persistent-storages/{storage_id}/actions/create-share-folder
POST /v1/{project_id}/persistent-storages/{storage_id}/actions/delete-storage-claim
POST /v1/{project_id}/persistent-storages/{storage_id}/actions/delete-user-attachment
POST /v1/{project_id}/persistent-storages/actions/batch-delete
GET /v1/{project_id}/persistent-storages/actions/list-attachments
GET /v1/{project_id}/persistent-storages/actions/list-share-folders
GET /v1/{project_id}/policy-groups/{policy_group_id}
GET /v1/{project_id}/policy-groups/{policy_group_id}/policy
workspace:policyGroups:listPolicies
GET /v1/{project_id}/policy-groups/{policy_group_id}/target
workspace:policyGroups:listTargets
GET /v1/{project_id}/policy-groups/show/detail
DELETE /v1/{project_id}/policy-templates/{policy_template_id}
PATCH /v1/{project_id}/policy-templates/{policy_template_id}
GET /v1/{project_id}/privacy-statement
DELETE /v1/{project_id}/scaling-policy
GET /v1/{project_id}/scaling-policy
PUT /v1/{project_id}/scaling-policy
GET /v1/{project_id}/schedule-task/{task_id}/execute-history
workspace:scheduledTasks:list
POST /v1/{project_id}/schedule-task
workspace:scheduledTasks:create
GET /v1/{project_id}/schedule-task/{execute_history_id}/execute-detail
workspace:scheduledTasks:getRecord
DELETE /v1/{project_id}/schedule-task/{task_id}
workspace:scheduledTasks:delete
POST /v1/{project_id}/schedule-task/future-executions
PATCH /v1/{project_id}/schedule-task/{task_id}
workspace:scheduledTasks:update
workspace:scheduledTasks:listRecords
POST /v1/{project_id}/schedule-task/actions/batch-delete
workspace:scheduledTasks:batchDelete
POST /v1/{project_id}/session/app-connection
POST /v1/{project_id}/session/logoff
POST /v1/{project_id}/session/user-connection
GET /v1/{project_id}/session/user-session-info
PUT /v1/{project_id}/storages-policy/actions/create-statements
GET /v1/{project_id}/storages-policy/actions/list-statements
GET /v1/{project_id}/users
workspace:users:list
GET /v1/persistent-storages/actions/list-sfs-storages
  • obs:bucket:ListBucket
  • obs:bucket:GetBucketStorage
  • obs:bucket:ListAllMyBuckets
GET /v1/{project_id}/product
ecs:availabilityZones:list
POST /v1/{project_id}/bundles/batch-query-config-info
GET /v1/{project_id}/volume-type
POST /v1/{project_id}/tenant/action/active
GET /v1/{project_id}/tenant/profile
GET /v1/{project_id}/app-servers/server-metric-data/{server_id}
GET /v1/{project_id}/session/list-sessions
PATCH /v1/{project_id}/app-warehouse/apps/{id}
POST /v1/{project_id}/app-servers/actions/batch-change-image
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
POST /v1/{project_id}/app-servers/actions/batch-reinstall
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
workspace:authConfigs:update
workspace:assistAuthConfigs:get
workspace:assistAuthConfigs:update
workspace:jobs:retry
workspace:tenants:getRoles
workspace:tenants:ListConfig
workspace:tenants:updateConfig
workspace:natMappings:getConfig
workspace:natMappings:updateConfig
  • vpc:vpcs:get
  • vpc:subnets:get
workspace:tenants:open
  • elb:members:list
  • elb:pools:create
  • elb:pools:update
  • elb:pools:show
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:tenants:delete
  • elb:members:list
  • elb:pools:delete
  • elb:pools:show
  • vpc:ports:delete
  • elb:members:list
  • elb:pools:create
  • elb:pools:delete
  • elb:pools:update
  • elb:pools:show
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:agencies:create
  • iam:roles:getRole
workspace:agencies:get
workspace:desktops:createAiAccelerateJob
workspace:desktops:getAiAccelerateJob
workspace:desktops:getSysPrepInfo
workspace:desktops:checkBatchChangeImage
ims:images:list
workspace:tenants:listDesktopNamePolicies
workspace:tenants:createDesktopNamePolicy
workspace:tenants:updateDesktopNamePolicy
workspace:tenants:batchDeleteDesktopNamePolicies
workspace:desktopPools:create
  • ims:images:get
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
  • dss:pools:list
workspace:desktopPools:list
ims:images:list
workspace:desktopPools:update
workspace:desktopPools:delete
workspace:desktopPools:get
ims:images:list
workspace:desktopPools:expand
  • ims:images:get
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
  • dss:pools:list
workspace:desktopPools:resize
  • vpc:subnets:get
  • ims:images:list
workspace:desktopPools:rebuild
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
workspace:desktopPools:batchAddVolumes
workspace:desktopPools:batchDeleteVolumes
workspace:desktopPools:batchExpandVolumes
workspace:desktopPools:operate
workspace:desktopPools:listUsers
workspace:desktopPools:authorizeUsers
ims:images:list
workspace:desktopPools:listDesktops
  • vpc:ports:get
  • vpc:ports:list
workspace:desktopPools:listScriptTasks
workspace:desktopPools:executeScripts
workspace:desktopPools:sendNotifications
  • vpc:ports:get
  • vpc:ports:list
  • ims:images:get
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • eip:publicIps:get
  • vpc:quotas:list
  • vpc:subnets:get
  • vpc:vpcs:get
  • dss:pools:list
workspace:desktops:update
workspace:desktops:delete
  • vpc:ports:get
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:list
  • vpc:ports:get
  • vpc:ports:delete
workspace:desktops:logoff
workspace:desktops:listDetail
  • vpc:ports:get
  • vpc:ports:list
workspace:desktops:operate
workspace:desktops:resize
  • vpc:subnets:get
  • ims:images:list
workspace:desktops:getConnectStatus
workspace:desktops:ListStatus
workspace:desktops:rebuild
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
workspace:desktops:getActions
workspace:desktops:createConsole
workspace:desktops:updateSids
workspace:desktops:rejoinDomain
workspace:desktops:createImage
  • ims:quotas:get
  • ims:images:get
  • ims:images:list
workspace:desktops:batchDetach
vpc:ports:get
workspace:desktops:detach
vpc:ports:get
workspace:desktops:attach
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
workspace:desktops:getNetwork
  • vpc:vpcs:get
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:get
workspace:desktops:changeNetwork
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:networks:get
  • vpc:ports:get
  • vpc:ports:create
  • vpc:ports:update
  • vpc:ports:delete
workspace:exclusiveHosts:listDesktops
workspace:desktops:listAll
workspace:desktopAssociate:listDiscoverVmInfo
workspace:desktopAssociate:startTask
workspace:desktopAssociate:switchScanTask
workspace:desktopAssociate:getScanTaskSwitch
workspace:desktops:setMaintenanceMode
workspace:desktops:prepAttachUsers
workspace:desktops:batchAttachUsers
  • vpc:ports:get
  • ims:images:get
  • ims:images:list
  • ims:images:share
workspace:desktops:changeUsername
workspace:desktops:sendNotifications
workspace:desktops:migrate
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:update
  • vpc:ports:get
workspace:desktops:listAgents
workspace:desktops:batchInstallAgents
workspace:desktops:listTags
workspace:desktops:tag
workspace:desktops:untag
workspace:desktops:listProjectTags
workspace:desktops:operateTags
workspace:desktops:listByTags
workspace:exclusiveHosts:create
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:exclusiveHosts:check
workspace:exclusiveHosts:get
workspace:exclusiveHosts:update
workspace:exclusiveHosts:delete
workspace:mkp:listImages
ims:images:list
workspace:mkp:listCommodityInfos
workspace:mkp:createOrder
workspace:mkp:listListProductReserve
workspace:mkp:listCommodityDetails
workspace:mkp:listRelationCommodityDetails
workspace:mkp:listCommodityAgreements
workspace:networks:listEips
workspace:networks:createEips
  • vpc:quotas:list
workspace:networks:bindEips
  • eip:publicIps:get
workspace:networks:unbindEips
workspace:networks:getEipQuota
vpc:quotas:list
workspace:networks:ListNatGateways
  • vpc:subnets:get
  • vpc:vpcs:get
  • ims:images:list
  • vpc:vpcs:get
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:get
  • bss:order:update
workspace:orders:change
  • ims:images:list
  • bss:order:update
  • ims:images:list
  • bss:order:update
workspace:orders:batchInquiry
ims:images:list
  • ims:images:list
  • bss:order:update
ims:images:list
ims:images:list
ims:images:list
ims:images:list
ims:images:list
  • ims:images:list
  • ims:images:share
  • vpc:networks:get
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:ports:update
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:renderDesktops:delete
  • vpc:ports:get
  • vpc:ports:delete
workspace:renderDesktops:list
workspace:renderDesktops:action
workspace:scheduledTasks:getFuture
workspace:scheduledTasks:exportRecords
workspace:users:subscribeSharer
workspace:desktops:addSubResources
workspace:desktops:deleteSubResources
workspace:desktops:createSnapshots
workspace:desktops:getSnapshots
workspace:desktops:deleteSnapshots
workspace:desktops:restoreBySnapshot
workspace:statistics:listDesktopStatus
workspace:statistics:getUnused
workspace:statistics:getUsed
workspace:bindingPolicies:export
workspace:bindingPolicies:getConfig
workspace:bindingPolicies:createConfig
workspace:bindingPolicies:add
workspace:bindingPolicies:update
workspace:bindingPolicies:delete
workspace:volumes:delete
workspace:volumes:batchAdd
workspace:volumes:batchExpand
workspace:wdh:getType
workspace:wdh:get
workspace:desktops:getRemoteAssistance
workspace:desktops:createRemoteAssistance
workspace:desktops:cancelRemoteAssistance
workspace:volumes:add
workspace:volumes:expand
workspace:volumes:listDssPoolsDetail
dss:pools:list
workspace:common:listTimezones
workspace:connections:securityExport
ims:images:list
workspace:policyGroups:import
workspace:accessPolicies:create
workspace:accessPolicies:delete
workspace:accessPolicies:getTarget
workspace:accessPolicies:updateTarget
workspace:products:listDesktopProducts
workspace:products:listSharerProducts
workspace:products:listInternetProducts
workspace:availabilityZones:list
workspace:userGroups:export
workspace:users:export
workspace:userGroups:exportUsers
workspace:users:operate
workspace:users:randomPassword
workspace:users:deleteOtps
workspace:users:resendEmail
workspace:connections:securityList
workspace:connections:listOnlineUsers
workspace:userGroups:list
workspace:userGroups:create
workspace:userGroups:batchDelete
workspace:userGroups:delete
workspace:userGroups:update
workspace:userGroups:operate
workspace:userGroups:getUsers
workspace:jobs:listSubJobs
workspace:jobs:deleteSubJobRecords
workspace:ou:get
workspace:ou:create
workspace:ou:delete
workspace:ou:update
workspace:policyGroups:get
workspace:policyGroups:export
workspace:policyGroups:updatePolicies
workspace:policyGroups:updateTargets
workspace:policyGroups:listDetail
workspace:policyGroups:getOriginalPolicies
workspace:users:create
workspace:users:get
workspace:users:update
workspace:users:batchDelete
workspace:users:resetPassword
workspace:users:checkResetPasswordToken
workspace:users:getTemplate
workspace:users:checkExist
workspace:users:listOtps
workspace:users:getImportTemplate
workspace:users:batchCreate
workspace:products:listVolumeProducts
workspace:tenants:listExportTasks
workspace:tenants:deleteExportTasks
workspace:tenants:exportData
workspace:statistics:listAlarm
workspace:statistics:getAlarm
workspace:statistics:getGrowthRate
workspace:statistics:getMetric
workspace:statistics:getMetricTrend
workspace:statistics:updateNotificationRules
smn:topic:get
workspace:statistics:deleteNotificationRules
workspace:statistics:createNotifyRules
smn:topic:get
workspace:statistics:listNotificationRules
workspace:statistics:listNotificationRecords
workspace:statistics:listDesktopMetrics
workspace:statistics:exportDesktopMetrics
workspace:statistics:listUserMetrics
workspace:statistics:exportUserMetrics
workspace:appcenter:createBucketCredential
workspace:appcenter:createAndAuthorizeBucket
workspace:appcenter:listApps
workspace:appcenter:createApp
workspace:appcenter:updateApp
workspace:appcenter:deleteApp
workspace:appcenter:installApp
workspace:appcenter:listAppAuthorizations
workspace:appcenter:batchUpdateAppAuthorizations
workspace:appcenter:batchDeleteApps
workspace:appcenter:batchDisableApps
workspace:appcenter:batchEnableApps
workspace:appcenter:batchInstallApps
workspace:appcenter:listAppCatalogs
workspace:appcenter:listJobs
workspace:appcenter:batchDeleteJobs
workspace:appcenter:retryJobs
workspace:appcenter:createAppRule
workspace:appcenter:listAppRule
workspace:appcenter:updateAppRule
workspace:appcenter:deleteAppRule
workspace:appcenter:batchDeleteAppRules
workspace:appcenter:enableRuleRestriction
workspace:appcenter:disableRuleRestriction
workspace:appcenter:addRestrictedRule
workspace:appcenter:listRestrictedRule
workspace:appcenter:deleteRestrictedRule
workspace:appcenter:updateTenantProfile
workspace:appcenter:listTenantProfiles
workspace:scripts:create
workspace:scripts:list
workspace:scripts:get
workspace:scripts:put
workspace:scripts:delete
workspace:scripts:execute
workspace:scripts:getRecordDetail
workspace:scripts:listRecords
workspace:scripts:listTasks
workspace:scripts:retry
workspace:scripts:stop
workspace:scripts:download
workspace:tenants:getShareSpaceConfig
workspace:tenants:updateShareSpaceConfig
workspace:authConfigs:getStatus
workspace:privacystatements:sign
workspace:sites:get
workspace:sites:add
  • elb:members:list
  • elb:pools:create
  • elb:pools:update
  • elb:pools:show
  • vpc:ports:create
  • vpc:ports:delete
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:sites:delete
  • elb:members:list
  • elb:pools:delete
  • elb:pools:show
  • vpc:ports:delete
workspace:sites:updateAccessMode
  • elb:members:list
  • elb:pools:create
  • elb:pools:delete
  • elb:pools:update
  • elb:pools:show
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:sites:updateSubnets
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:tenants:checkEnterpriseIds
workspace:tenants:updateEnterpriseId
workspace:bandwidth:create
workspace:bandwidth:list
workspace:bandwidth:update
workspace:bandwidth:delete
workspace:bandwidth:getControlConfig
workspace:bandwidth:updateControlConfig
workspace:bandwidth:createChangeOrder
workspace:desktops:batchCreateSnapshots
workspace:desktops:batchDeleteSnapshots
workspace:desktops:batchRestoreSnapshots
workspace:desktops:listSnapshots
workspace:desktops:verifyDesktopName
workspace:networks:getAvailableIp
workspace:desktops:getAdStatus
workspace:networks:checkIpIfExist
workspace:images:checkIfExist
ims:images:list
workspace:wdh:listDesktops
workspace:wdh:update
workspace:bindingPolicies:getTemplate
workspace:bindingPolicies:import
workspace:statistics:getRunState
workspace:statistics:getLoginState
workspace:networks:getUsingSubnets
workspace:networks:listPorts
workspace:renderDesktops:createConsole
workspace:renderDesktops:resize
workspace:exclusiveHosts:resizeLites
  • vpc:ports:get
  • vpc:ports:list
workspace:desktops:getMonitor
ces:metricData:get
  • vpc:ports:get
  • vpc:ports:list
workspace:desktops:listDetachInfo
workspace:desktops:getSysprepVersion
workspace:networks:createNat
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:networks:get
workspace:networks:listNats
  • vpc:subnets:get
  • vpc:vpcs:get
workspace:networks:listSubnets
  • vpc:subnets:list
  • vpc:subnets:get
workspace:networks:listVpcs
vpc:vpcs:list
workspace:policyGroups:createTemplate
workspace:policyGroups:listTemplate
workspace:policyGroups:updateTemplate
workspace:networks:listSecurityGroups
workspace:availabilityZones:getSummary
workspace:users:importUser
workspace:users:uploadTemplate
workspace:desktops:verifySource
workspace:desktops:listDesktopNetworks
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:networks:get
  • vpc:ports:get
workspace:desktops:batchChangeNetwork
  • vpc:vpcs:get
  • vpc:subnets:get
  • vpc:networks:get
  • vpc:ports:get
  • vpc:ports:create
  • vpc:ports:update
  • vpc:ports:delete
workspace:jobs:get
workspace:accessPolicies:importIp
workspace:accessPolicies:getIpImportTemplate
workspace:sites:listEdgeSites
  • ies:edgeSite:list
workspace:sites:checkEdgeSiteResources
  • ies:edgeSite:list
workspace:ou:listAdOus
workspace:ou:listOuUsers
workspace:ou:importUsersByOU
workspace:appGroup:create
workspace:appGroup:delete
workspace:appGroup:get
workspace:appGroup:update
workspace:app:listPublishedApp
workspace:app:publish
workspace:app:get
workspace:app:update
workspace:app:deleteIcon
workspace:app:uploadIcon
workspace:app:check
workspace:app:batchDisable
workspace:app:batchEnable
workspace:app:unpublish
workspace:appGroup:listPublishableApp
workspace:appGroup:batchDeleteAuthorization
workspace:appGroup:disassociate
workspace:appGroup:listAuthorization
workspace:appGroup:addAuthorization
workspace:appGroup:check
workspace:serverGroup:create
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
workspace:serverGroup:delete
workspace:serverGroup:get
workspace:serverGroup:update
ims:images:list
workspace:serverGroup:getServerState
workspace:serverGroup:listDetail
workspace:serverGroup:getRestrict
workspace:serverGroup:validate
workspace:serverGroup:tagResource
workspace:serverGroup:unTagResource
workspace:serverGroup:listTagsForResource
  • vpc:ports:delete
  • vpc:ports:get
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
  • vpc:ports:delete
  • vpc:ports:get
  • vpc:subnets:get
  • vpc:ports:update
  • ims:images:list
  • ims:images:share
  • ims:images:get
  • vpc:networks:get
  • vpc:subnets:get
  • vpc:ports:create
  • vpc:ports:get
  • vpc:ports:delete
  • vpc:vpcs:get
  • dss:pools:list
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
  • vpc:ports:get
  • vpc:subnets:get
  • ims:quotas:get
  • ims:images:get
  • ims:images:list
workspace:jobs:get
GET /v1/{project_id}/availability-zone
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
  • ims:images:list
  • vpc:ports:get
  • vpc:subnets:get
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for Workspace.
Table 3 Resource types supported by Workspace
Resource Type
URN
desktop
Desktop
workspace:<region>:<account-id>:desktop:<desktop-id>
desktopPool
Desktop pool
workspace:<region>:<account-id>:desktopPool:<pool-id>
wdh
Workspace host
workspace:<region>:<account-id>:wdh:<wdh-id>
exclusiveHost
Exclusive host
workspace:<region>:<account-id>:exclusiveHost:<host-id>
user
User
workspace:<region>:<account-id>:user:<user-id>
userGroup
User group
workspace:<region>:<account-id>:userGroup:<group-id>
policyGroup
Policy group
workspace:<region>:<account-id>:policyGroup:<policy-group-id>
script
Script
workspace:<region>:<account-id>:script:<script-id>
scheduledTask
Scheduled task
workspace:<region>:<account-id>:scheduledTask:<task-id>
server
APS
workspace:<region>:<account-id>:server:<server-id>
serverGroup
APS group
workspace:<region>:<account-id>:serverGroup:<server-group-id>
app
Application
workspace:<region>:<account-id>:app:<app-id>
appGroup
Application group
workspace:<region>:<account-id>:appGroup:<app-group-id>
imageServer
Application image server
workspace:<region>:<account-id>:imageServer:<image-server-id>
storage
workspace:<region>:<account-id>:storage:<storage-id>
Conditions
A Condition element lets you specify conditions for an SCP to take effect. It contains condition keys and operators.
  • The condition key that you specify can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, workspace:) only apply to operations of Workspace. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • A condition operator, condition key, and condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. See supported operators.
The following table lists the condition keys that you can define in SCPs for Workspace. You can include these condition keys to specify conditions for an SCP to take effect.
Table 4 Service-specific condition keys supported by Workspace
Condition Key
Type
Single-valued/Multivalued
workspace:AccessMode
string
Multivalued
Access is filtered based on the access mode specified in the request parameter. The valid condition values are INTERNET, DEDICATED, and BOTH.
workspace:CreateOrderType
string
FALSE
Access is filtered based on the created order types specified in the request parameter. The valid condition values are createDesktops, addVolumes, createDehHosts, rebuildDesktops, createDesktopPool, expandDesktopPool, applyDesktopsInternet, createExclusiveHosts, subscribeUserSharer, and createApps.
workspace:ChangeOrderType
string
FALSE
Access is filtered based on the changed order types specified in the request parameter. The valid condition values are resizeDesktops, expandVolumes, meteredToPeriod, ADD_VOLUME, EXTEND_VOLUME, RESIZE, CHANGE_IMAGE, ADD_SUB_RESOURCES, and DELETE_SUB_RESOURCES.
workspace:AssociatePublicIp
boolean
FALSE
Permissions for binding EIPs to desktops are filtered based on whether the associated EIP is enabled.
