The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by GaussDB(DWS), see Resource Type.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about condition keys defined by GaussDB(DWS), see Conditions.
The following table lists the actions that you can define in SCP statements for GaussDB(DWS).
Action |
Description |
Access Level |
Resource Type (*: Required) |
Condition Key |
dws:cluster:list |
Grants the permission to query the cluster list. |
list |
dws:cluster:getDetail |
Grants the permission to view cluster details. |
read |
cluster * |
dws:cluster:create |
Grants the permission to create a GaussDB(DWS) cluster. |
write |
dws:cluster:delete |
Grants the permission to delete a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:scaleIn |
Grants the permission to scale in a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:listRing |
Grants the permission to obtain the proper scale-in ring list. |
list |
cluster * |
dws:cluster:restore |
Grants the permission to restore a snapshot to the original cluster. |
write |
cluster * |
dws:cluster:scaleOut |
Grants the permission to scale out a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:resize |
Grants the permission to scale out and resize a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:expandDisk |
Grants the permission to expand the disk capacity of a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:restart |
Grants the permission to restart a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:resetPassword |
Grants the permission to reset the password of a GaussDB(DWS) cluster. |
write |
cluster * |
dws:cluster:listAuditLog |
Grants the permission to view the audit log list. |
list |
cluster * |
dws:cluster:setMaintainceWindow |
Grants the permission to modify the maintenance time window. |
write |
cluster * |
dws:cluster:switchover |
Grants the permission to restore a primary/standby cluster. |
write |
cluster * |
dws:cluster:cancelReadonly |
Grants the permission to remove the read-only status of a cluster. |
write |
cluster * |
dws:cluster:addCN |
Grants the permission to add CNs to a cluster. |
write |
cluster * |
dws:cluster:listCN |
Grants the permission to obtain the CN list of a cluster. |
list |
cluster * |
dws:cluster:deleteCN |
Grants the permission to delete CN nodes. |
write |
cluster * |
dws:cluster:redistribution |
Grants the permission to redistribute cluster data. |
write |
cluster * |
dws:cluster:createDataSource |
Grants the permission to create MRS data sources. |
write |
cluster * |
dws:cluster:updateDataSource |
Grants the permission to update MRS data sources. |
write |
cluster * |
dws:cluster:deleteDataSource |
Grants the permission to delete MRS data sources. |
write |
cluster * |
dws:alarm:listDetail |
Grants the permission to query the alarm details list. |
list |
dws:alarm:report |
Grants the permission to report alarms. |
write |
dws:event:createSpec |
Grants the permission to create event configurations. |
write |
dws:event:deleteSpec |
Grants the permission to delete event configurations. |
write |
dws:event:report |
Grants the permission to report events. |
write |
dws:cluster:createConnection |
Grants the permission to create a GaussDB(DWS) cluster connection. |
write |
cluster * |
dws:cluster:deleteConnection |
Grants the permission to delete GaussDB(DWS) cluster connections. |
write |
cluster * |
dws:cluster:updateConnection |
Grants the permission to update GaussDB(DWS) cluster connections. |
write |
cluster * |
dws:cluster:bindEIP |
Grants the permission to bind public IP addresses. |
write |
cluster * |
dws:cluster:unbindEIP |
Grants the permission to unbind public IP addresses. |
write |
cluster * |
dws:cluster:listELB |
Grants the permission to obtain the ELB list. |
list |
cluster * |
dws:cluster:bindELB |
Grants the permission to bind ELBs. |
write |
cluster * |
dws:cluster:unbindELB |
Grants the permission to unbind ELBs. |
write |
cluster * |
dws:cluster:createSnapshotPolicy |
Grants the permission to set automated snapshot policies. |
write |
cluster * |
dws:cluster:listSnapshotStatistics |
Grants the permission to query the snapshot space capacity. |
list |
cluster * |
dws:cluster:listSnapshot |
Grants the permission to view the cluster snapshot list. |
list |
cluster |
dws:cluster:getSnapshotDetail |
Grants the permission to view cluster snapshot details. |
list |
cluster |
dws:cluster:createSnapshot |
Grants the permission to create snapshots using APIs. |
write |
cluster * |
dws:cluster:deleteSnapshotPolicy |
Grants the permission to delete snapshot policies. |
write |
cluster * |
dws:cluster:listSnapshotPolicy |
Grants the permission to query snapshot policies. |
list |
cluster * |
dws:cluster:copySnapshot |
Grants the permission to replicate snapshots. |
write |
cluster * |
dws:cluster:deleteSnapshot |
Grants the permission to delete snapshots. |
write |
cluster * |
dws:cluster:restoreSnapshot |
Grants the permission to restore snapshots. |
write |
cluster * |
dws:cluster:deleteDisasterRecovery |
Grants the permission to delete DR tasks. |
write |
cluster * |
dws:cluster:createDisasterRecovery |
Grants the permission to create DR tasks. |
write |
cluster * |
dws:cluster:restoreDisaster |
Grants the permission to restore DR tasks. |
write |
cluster * |
dws::listTagsForProject |
Grants the permission to query the tag list in the project. |
list |
dws:cluster:listConfig |
Grants the permission to view cluster configuration parameters. |
list |
cluster * |
dws:service:listSpec |
Grants the permission to view the service specification list. |
list |
dws:cluster:listDataSource |
Grants the permission to view cluster data sources. |
list |
cluster * |
dws:service:listJobDetail |
Grants the permission to view task progress details. |
list |
dws:service:listStatistics |
Grants permission to view available resources. |
list |
dws:service:listQuotas |
Grants the permission to view user quotas. |
list |
dws:cluster:updateConfig |
Grants the permission to update cluster configuration parameters. |
write |
cluster * |
dws:service:listAZ |
Grants the permission to view the service AZ list. |
list |
dws:service:listDssPools |
Grants the permission to view the storage pool list. |
list |
dws:service:listEps |
Grants the permission to view the EPS list. |
list |
dws:service:authorize |
Grant the permission to obtain user authorization. |
write |
dws:service:checkAuthorize |
Grant the permission to check user authorization. |
read |
dws::updateTag |
Grants the permission to update tags. |
tagging |
cluster * |
dws:cluster:getSnapshotPolicy |
Grants the permission to view snapshot policies. |
read |
cluster * |
dws:cluster:bindOrUnbindELB |
Grants the permission to bind or unbind ELBs. |
write |
cluster * |
dws:cluster:bindOrUnbindEIP |
Grants the permission to bind or unbind EIPs. |
write |
cluster * |
dws:cluster:deleteNode |
Grants the permission to delete nodes. |
write |
cluster * |
dws:cluster:listConnection |
Grants the permission to query the GaussDB(DWS) cluster connection list. |
list |
cluster * |
dws:cluster:checkConnection |
Grants the permission to check the GaussDB(DWS) cluster connections. |
read |
cluster * |
dws:cluster:listDN |
Grants the permission to obtain the DN list of a cluster. |
list |
cluster * |
dws:cluster:listBucket |
Grants the permission to obtain the bucket list. |
list |
cluster * |
dws:cluster:listScaleInNode |
Grants the permission to obtain the list of nodes to be deleted. |
list |
cluster * |
dws:cluster:listFlavorForResize |
Grants the permission to query the list of flavors that can be modified. |
list |
cluster * |
dws:cluster:listFlavorForRestore |
Grants the permission to query the list of flavors that can be restored. |
list |
cluster * |
dws::countResourceByTag |
Grants the permission to query clusters using tags. |
read |
cluster * |
dws:cluster:updateSnapshotPolicy |
Grants the permission to update snapshot policies. |
write |
cluster * |
dws::listResourceByTag |
Grants the permission to query clusters by tag. |
list |
cluster * |
dws:cluster:assessRisk |
Grants the permission to evaluate the risk of resizing. |
read |
cluster * |
dws:cluster:checkRestoreTable |
Grants the permission to check the restored table. |
read |
cluster * |
dws:cluster:checkSupportFineGrainedBackup |
Grants the permission to check whether a cluster supports fine-grained backup. |
read |
cluster * |
dws:cluster:configureNetwork |
Grants the permission to configure the cluster network. |
write |
cluster * |
dws:cluster:expandWithExistedNodes |
Grants the permission to scale out a cluster from an idle node. |
write |
cluster * |
dws:cluster:getAntiAffinity |
Grants the permission to query the anti-affinity status. |
read |
cluster * |
dws:cluster:getCnCount |
Grants the permission to query the number of CNs in a cluster. |
read |
cluster * |
dws:cluster:getCredential |
Grants the permission to obtain the JDBC connection credential of a cluster. |
read |
cluster * |
dws:cluster:getDiskExpandScope |
Grants the permission to obtain the disk scale-out scope. |
read |
cluster * |
dws:cluster:getEncryptInfo |
Grants the permission to view cluster encryption information. |
read |
cluster * |
dws:cluster:listHistoryConfig |
Grants the permission to query parameter modification history. |
list |
cluster * |
dws:cluster:getHistoryConfigDetail |
Grants the permission to query parameter modification history details. |
read |
cluster * |
dws:cluster:getInstanceDetail |
Grants the permission to view instance details. |
read |
cluster * |
dws:cluster:getProcessTopo |
Grants the permission to query the cluster node process topology. |
read |
cluster * |
dws:cluster:getRedistribution |
Grants the permission to query redistribution details. |
read |
cluster * |
dws:cluster:getRestoreDatabase |
Grants the permission to restore databases. |
read |
cluster * |
dws:cluster:getRoachConfig |
Grants the permission to obtain roach parameter configurations. |
read |
cluster * |
dws:cluster:getSnapshotEncryptInfo |
Grants the permission to view snapshot encryption information. |
read |
cluster * |
dws:cluster:getSnapshotStorage |
Grants the permission to query the snapshot capacity usage. |
read |
cluster * |
dws:cluster:getTaskDetail |
Grants the permission to query cluster task details. |
read |
cluster * |
dws:cluster:getVolumeInfo |
Grants the permission to query disk information. |
read |
cluster * |
dws:cluster:listNode |
Grants the permission to query the node list. |
list |
cluster * |
dws:cluster:listSchema |
Grants the permission to obtain the user structure list. |
list |
cluster * |
dws:cluster:listTable |
Grants the permission to obtain the user list. |
list |
cluster * |
dws:cluster:listDatabase |
Grants the permission to obtain the database list. |
list |
cluster * |
dws:cluster:recoverRedistribution |
Grants the permission to restore redistribution. |
write |
cluster * |
dws:cluster:resizeFlavor |
Grants the permission to change specifications. |
write |
cluster * |
dws:cluster:resizeRetry |
Grants the permission to retry failed resize attempts. |
write |
cluster * |
dws:cluster:restoreTable |
Grants the permission to restore tables. |
write |
cluster * |
dws:cluster:retryELBSwitch |
Grants the permission to retry an ELB switchover task. |
write |
cluster * |
dws:cluster:listRingForScaleIn |
Grants the permission to obtain the scale-in ring list. |
list |
cluster * |
dws:cluster:stopSnapshot |
Grants the permission to stop snapshots. |
write |
cluster * |
dws:cluster:suspendRedistribution |
Grants the permission to suspend redistribution. |
write |
cluster * |
dws:cluster:updateInstanceAliasName |
Grants the permission to update the node alias. |
write |
cluster * |
dws:cluster:updateRoachConfig |
Grants the permission to update roach parameter configurations. |
write |
cluster * |
dws:cluster:updateScheduleConfig |
Grants the permission to update scheduling configurations. |
write |
cluster * |
dws:service:getClusterSum |
Grants the permission to query the number of clusters. |
read |
dws:service:getResourceStatistics |
Grants the permission to query resource statistics. |
read |
dws:service:getStorageStatistics |
Grants the permission to query storage statistics. |
read |
dws:cluster:listDisasterRecovery |
Grants the permission to query the DR task list. |
list |
cluster * |
dws:cluster:checkDisasterRecoveryName |
Grants the permission to check DR task names. |
read |
cluster * |
dws:cluster:updateDisasterRecoveryConfig |
Grants the permission to update DR configurations. |
write |
cluster * |
dws:cluster:addOperationalTask |
Grants the permission to add scheduling tasks. |
write |
cluster * |
dws:cluster:bindManageIp |
Grants the permission to bind management plane IP addresses. |
write |
cluster * |
dws:cluster:checkAccessLts |
Grants the permission to check whether LTS is normal. |
read |
cluster * |
dws:cluster:checkLogicalClusterData |
Grants the permission to check whether a logical cluster has the service data operation permission. |
read |
cluster * |
dws:cluster:closeAccessLts |
Grants the permission to disable cloud service logs. |
write |
cluster * |
dws:cluster:createLogicalCluster |
Grants the permission to create a logical cluster. |
write |
cluster * |
dws:cluster:createApplicationForDM |
Grants the permission to add jobs and tasks during data migration. |
write |
cluster * |
dws:cluster:createClusterForDM |
Grants the permission to create clusters during data migration. |
write |
cluster * |
dws:cluster:createConnectionForDM |
Grants the permission to add connections during data migration. |
write |
cluster * |
dws:cluster:createMappingForDM |
Grants the permission to add mappings during data migration. |
write |
cluster * |
dws:cluster:deleteApplicationForDM |
Grants the permission to delete jobs and tasks during data migration. |
write |
cluster * |
dws:cluster:deleteClusterForDM |
Grants the permission to delete clusters during data migration. |
write |
cluster * |
dws:cluster:deleteConnectionForDM |
Grants the permission to delete connections during data migration. |
write |
cluster * |
dws:cluster:deleteMappingForDM |
Grants the permission to delete mappings during data migration. |
write |
cluster * |
dws:cluster:dialsConnectionForDM |
Grants the permission to probe connection activity during data migration. |
read |
cluster * |
dws:cluster:getApplicationForDM |
Grants the permission to query job and task details during data migration. |
read |
cluster * |
dws:cluster:listApplicationConfigForDM |
Grants the permission to configure data migration job and task parameters. |
list |
cluster * |
dws:cluster:listApplicationForDM |
Grants the permission to query all jobs in a cluster during data migration. |
list |
cluster * |
dws:cluster:getClusterForDM |
Grants the permission to query cluster details during data migration. |
read |
cluster * |
dws:cluster:listClusterForDM |
Grants the permission to query the cluster list during data migration. |
list |
cluster * |
dws:cluster:listConfigurationTemplateForDM |
Grants the permission to query parameter templates during data migration. |
list |
cluster * |
dws:cluster:getConnectionForDM |
Grants the permission to query connection details during data migration. |
read |
cluster * |
dws:cluster:listConnectionForDM |
Grants the permission to query all connections during data migration. |
list |
cluster * |
dws:cluster:listDependApplicationForDM |
Grants the permission to query all dependent jobs during data migration. |
list |
cluster * |
dws:cluster:getMappingForDM |
Grants the permission to query mapping details during data migration. |
read |
cluster * |
dws:cluster:listMappingForDM |
Grants the permission to query all mappings during data migration. |
list |
cluster * |
dws:cluster:listProductForDM |
Grants the permission to query product information in GDS-Kafka. |
list |
cluster * |
dws:cluster:updateConnectionForDM |
Grants the permission to modify the specified connection during data migration. |
write |
cluster * |
dws:cluster:updateMappingForDM |
Grants the permission to modify the specified mapping during data migration. |
write |
cluster * |
dws:cluster:startApplicationForDM |
Grants the permission to start jobs and tasks during data migration. |
write |
cluster * |
dws:cluster:stopApplicationForDM |
Grants the permission to stop jobs and tasks during data migration. |
write |
cluster * |
dws:cluster:deleteCrossRegionSnapshotPolicy |
Grants the permission to delete cross-region backup configurations. |
write |
cluster * |
dws:cluster:deleteLogicalCluster |
Grants the permission to delete a logical cluster. |
write |
cluster * |
dws:cluster:deleteOperationalTask |
Grants the permission to delete scheduling tasks in the scheduler. |
write |
cluster * |
dws:cluster:operateDisasterRecovery |
Grants permissions for DR operations, including starting, stopping, and switching over. |
write |
cluster * |
dws:cluster:updateLogicalCluster |
Grants the permission to update a logical cluster. |
write |
cluster * |
dws:cluster:listAllCrossRegionSnapshotConfig |
Grants the permission to query all cross-region snapshot configurations. |
list |
cluster * |
dws:cluster:getDisasterRecoveryProject |
Grants the permission to query available projects. |
read |
cluster * |
dws:cluster:getDisasterRecoveryRegion |
Grants the permission to query available regions. |
read |
cluster * |
dws:cluster:getLastOperationalTask |
Grants the permission to query the operations of the last built tasks in the scheduler. |
read |
cluster * |
dws:cluster:getLogicalClusterRings |
Grants the permission to query the cluster ring information of a logical cluster. |
read |
cluster * |
dws:cluster:getLogicalClusterVolume |
Grants the permission to query disk information of a logical cluster. |
read |
cluster * |
dws:cluster:getOperationalTaskConfig |
Grants the permission to obtain the O&M task common configurations of the scheduler. |
read |
cluster * |
dws:cluster:getOperationalTaskDetail |
Grants the permission to obtain the O&M task details of the scheduler. |
read |
cluster * |
dws:cluster:getOperationalTaskStatus |
Grants permission to check the status of the scheduler. |
read |
cluster * |
dws:cluster:listSnapshotRegion |
Grants permission to view the regions where cross-region snapshots are available. |
list |
cluster * |
dws:cluster:getTargetAllCrossRegionSnapshotConfig |
read |
cluster * |
dws:cluster:initLogicalClusterSwitch |
Grants the permission to enable and disable a logical cluster. |
write |
cluster * |
dws:cluster:listAccessLts |
Grants the permission to query the LTS list. |
list |
cluster * |
dws:cluster:listLogicalCluster |
Grants the permission to query the logical cluster list. |
list |
cluster * |
dws:cluster:listLogicalClusterTask |
Grants the permission to query task information of a logical cluster. |
list |
cluster * |
dws:cluster:listOperationalTask |
Grants the permission to obtain the O&M task list of the scheduler. |
list |
cluster * |
dws:cluster:openAccessLts |
Grants the permission to enable cloud service logs. |
write |
cluster * |
dws:cluster:pauseOperationalTask |
Allows the scheduler to suspend scheduling tasks. |
write |
cluster * |
dws:cluster:getDisasterRecoveryDetail |
Grants the permission to query DR details. |
write |
cluster * |
dws:cluster:refreshOperationalTask |
Allows remote refreshing of O&M tasks for the current cluster. |
write |
cluster * |
dws:cluster:restartLogicalCluster |
Grants the permission to restart a logical cluster. |
write |
cluster * |
dws:cluster:resumeOperationalTask |
Grants the permission to resume scheduling tasks of the scheduler. |
write |
cluster * |
dws:cluster:setCrossRegionSnapshotPolicy |
Grants the permission to configure cross-region backup. |
write |
cluster * |
dws:cluster:startOperationalTask |
Grants the permission to enable the scheduler. |
write |
cluster * |
dws:cluster:stopOperationalTask |
Grants the permission to disable the scheduler. |
write |
cluster * |
dws:cluster:switchLogicalCluster |
Grants the permission to switch to a logical cluster. |
write |
cluster * |
dws:cluster:syncCrossRegionBackupClusterInfo |
Grants the permission to synchronize cross-region backup cluster information. |
write |
cluster * |
dws:cluster:syncCrossRegionBackupConfig |
Grants the permission to synchronize cross-region snapshot configurations. |
write |
cluster * |
dws:cluster:syncCrossRegionBackupInfo |
Grants the permission to synchronize cross-region snapshots. |
write |
cluster * |
dws:cluster:syncLogicalCluster |
Grants the permission to synchronize data from the background in a logical cluster. |
write |
cluster * |
dws:cluster:updateOperationalTaskConfig |
Grants the permission to modify the O&M task common configurations of the scheduler. |
write |
cluster * |
dws:cluster:updateOperationalTask |
Grants the permission to modify scheduling tasks of the scheduler. |
write |
cluster * |
dws:cluster:addPlanForWLM |
Grants the permission to add workload plans for workload management. |
write |
cluster * |
dws:cluster:addPlanStageForWLM |
Grants the permission to add workload plan stages for workload management. |
write |
cluster * |
dws:cluster:addQueueForWLM |
Grants the permission to add workload queues for workload management. |
write |
cluster * |
dws:cluster:addQueueUserForWLM |
Grants the permission to bind users to a workload queue for workload management. |
write |
cluster * |
dws:cluster:deletePlanForWLM |
Grants the permission to delete workload plans for workload management. |
write |
cluster * |
dws:cluster:deletePlanStageForWLM |
Grants the permission to delete workload plan stages for workload management. |
write |
cluster * |
dws:cluster:deleteQueueForWLM |
Grants the permission to delete workload queues for workload management. |
write |
cluster * |
dws:cluster:deleteQueueUserForWLM |
Grants the permission to unbind users from a workload queue for workload management. |
write |
cluster * |
dws:cluster:exportPlanForWLM |
Grants the permission to export workload plans for workload management. |
write |
cluster * |
dws:cluster:getPlanDetailForWLM |
Grants the permission to query details about a workload plan for workload management. |
read |
cluster * |
dws:cluster:getPlanLogForWLM |
Grants the permission to query workload plan logs for workload management. |
read |
cluster * |
dws:cluster:getPlanQueueForWLM |
Grants the permission to query whether a queue is in a workload plan for workload management. |
read |
cluster * |
dws:cluster:getPlanStageForWLM |
Grants the permission to query workload plan stages for workload management. |
read |
cluster * |
dws:cluster:listQueueForWLM |
Grants the permission to obtain the workload queue list for workload management. |
list |
cluster * |
dws:cluster:getQueueDetailForWLM |
Grants the permission to obtain workload queues for workload management. |
read |
cluster * |
dws:cluster:getQueueRuleForWLM |
Grants the permission to obtain the exception rules of a workload queue for workload management. |
write |
cluster * |
dws:cluster:importPlanForWLM |
Grants the permission to import workload plans for workload management. |
write |
cluster * |
dws:cluster:listPlanQueueForWLM |
Grants the permission to query available queues for all workload plans for workload management. |
list |
cluster * |
dws:cluster:listPlanForWLM |
Grants the permission to query workload plans for workload management. |
list |
cluster * |
dws:cluster:listQueueUserForWLM |
Grants the permission to obtain the bound users of a workload queue for workload management. |
list |
cluster * |
dws:cluster:listUserForWLM |
Grants the permission to obtain the list of users who are not bound to workload queues in the cluster for workload management. |
list |
cluster * |
dws:cluster:getClusterDBInfoForWLM |
Grants the permission to query database information in a cluster for workload management. |
read |
cluster * |
dws:cluster:listClusterPlanForWLM |
Grants the permission to query all workload plans in a cluster for workload management. |
list |
cluster * |
dws:cluster:getClusterSchemaInfoForWLM |
Grants the permission to query schema space information in a cluster for workload management. |
read |
cluster * |
dws:cluster:getClusterVersionForWLM |
Grants the permission to obtain the background database version in a cluster for workload management. |
read |
cluster * |
dws:cluster:getFunctionStatusForWLM |
Obtain the permission to enable or disable the workload function for workload management. |
read |
cluster * |
dws:cluster:setFunctionStatusForWLM |
Grants the permission to set the status of the workload function switch for workload management. |
write |
cluster * |
dws:cluster:startPlanForWLM |
Grants the permission to start a workload plan for workload management. |
write |
cluster * |
dws:cluster:stopPlanForWLM |
Grants the permission to stop a workload plan for workload management. |
write |
cluster * |
dws:cluster:switchPlanStageForWLM |
Grants the permission to switch workload stages for workload management. |
write |
cluster * |
dws:cluster:updatePlanStageForWLM |
Grants the permission to modify workload plan stages for workload management. |
write |
cluster * |
dws:cluster:updateQueueBaseForWLM |
Grants the permission to update workload queue basic information for workload management. |
write |
cluster * |
dws:cluster:updateQueueResourceForWLM |
Grants the permission to update workload queue resource configuration for workload management. |
write |
cluster * |
dws:cluster:updateQueueRuleForWLM |
Grants the permission to update workload queue exception rules for workload management. |
write |
cluster * |
dws:cluster:updateSchemaLimitForWLM |
Grants the permission to update schema space limit for workload management. |
write |
cluster * |
dws:cluster:getMonitorConfigForDMS |
Grants the permission to query collection configuration or storage configuration in DMS. |
read |
cluster * |
dws:monitor:listClusterOverview |
Grants the permission to check the cluster overview in DMS. |
list |
dws:cluster:listClusterInstanceForDMS |
Grants the permission to obtain the cluster instance list in DMS. |
read |
cluster * |
dws:cluster:getDDLExamineDetailForDMS |
Grants the permission to query review result details in DMS. |
read |
cluster * |
dws:cluster:getClusterDnStreamForDMS |
Grants the permission to query DN data flow monitoring information in DMS. |
read |
cluster * |
dws:cluster:listClusterAlarmRuleForDMS |
Grants the permission to query the alarm rule list on the DMS tenant side. |
list |
cluster * |
dws:cluster:getClusterInstanceForDMS |
Grants the permission to query instance information in DMS. |
read |
cluster * |
dws:cluster:getHostNetMetricsForDMS |
Grants the permission to query the network status in DMS. |
read |
cluster * |
dws:monitor:getHistoryMetrics |
Grants the permission to query historical monitoring data in DMS. |
read |
dws:cluster:getMonitoringInfoForDMS |
Grants the permission to query monitoring data in DMS. |
read |
cluster * |
dws:cluster:listAlarmRuleForDMS |
Grants the permission to query alarm rules by alarm ID on the DMS tenant side. |
list |
cluster * |
dws:cluster:updateCollectionItemForDMS |
Grants the permission to update collection configuration in DMS. |
write |
cluster * |
dws:cluster:doDDLExamineActionForDMS |
Grants the permission to manually trigger the review operation in DMS. |
write |
cluster * |
dws:cluster:downloadDDLExamineDetailForDMS |
Grants the permission to download DDL review details in DMS. |
write |
cluster * |
dws:cluster:listInstanceDiskIOForDMS |
Grants the permission to query disk I/Os in DMS. |
list |
cluster * |
dws:cluster:resetCollectionItemForDMS |
Grants the permission to reset collection configuration in DMS. |
write |
cluster * |
dws:cluster:getQueryRangeForDMS |
Grants the permission to query time handles in DMS. |
read |
cluster * |
dws:monitor:getAlarmConfig |
Grants the permission to query all clusters and alarm configurations on the DMS tenant side. |
read |
dws:cluster:switchoverCollectionItemForDMS |
Grants the permission to switch the collection switch in DMS. |
write |
cluster * |
dws:monitor:getOSMetrics |
Grants the permission to query GaussDB(DWS) hardware resource usage in DMS. |
read |
dws:cluster:listPerfDashboardForDMS |
Allows the current user to access and query all performance monitoring panels in DMS. |
list |
cluster * |
dws:cluster:disableCollectionItemForDMS |
Grants the permission to disable the collection function in DMS. |
write |
cluster * |
dws:monitor:getAggregationOSMetrics |
Grants the permission to query hardware resource usage of a GaussDB(DWS) cluster in DMS. |
read |
dws:cluster:terminateSessionForDMS |
Grants the permission to terminate sessions in DMS. |
write |
cluster * |
dws:cluster:getPerfDashboardDetailForDMS |
Grants the permission to obtain panel information based on the panel ID in DMS. |
read |
cluster * |
dws:monitor:createAlarmRule |
Grants the permission to add alarm rules on the DMS tenant side. |
write |
dws:cluster:enableCollectionItemForDMS |
Grants the permission to enable the collection function in DMS. |
write |
cluster * |
dws:cluster:listInstanceNetworkMetricsForDMS |
Grants the permission to query NIC traffic of GaussDB(DWS) cluster nodes in DMS. |
list |
cluster * |
dws:cluster:createPerfDashboardForDMS |
Grants the permission to create user panels in DMS. |
write |
cluster * |
dws:cluster:getMonitorMetricsForDMS |
Grants the permission to obtain monitoring items on the home page in DMS. |
read |
cluster * |
dws:cluster:createSQLProbeForDMS |
Grants the permission to add SQL probes in DMS. |
write |
cluster * |
dws:cluster:listInstanceIOStatusForDMS |
Grants the permission to query disk I/O usage of GaussDB(DWS) cluster nodes in DMS. |
list |
cluster * |
dws:cluster:getMonitorMetricsByDimensionForDMS |
Grants the permission to obtain metrics by dimension in DMS. |
read |
cluster * |
dws:cluster:updateStorageConfigForDMS |
Grants the permission to update storage configuration in DMS. |
write |
cluster * |
dws:monitor:updateAlarmRule |
Grants the permission to modify alarm rules on the DMS tenant side. |
write |
dws:cluster:getInstanceIOAggResultForDMS |
Grants the permission to query disk I/O aggregation usage of each node in a GaussDB(DWS) cluster in DMS. |
read |
cluster * |
dws:cluster:updatePerfDashboardForDMS |
Grants the permission to modify user panels in DMS. |
write |
cluster * |
dws:cluster:getMonitorHistoryMetricsCost |
Grants the permission to query historical queue consumption in DMS. |
read |
cluster * |
dws:monitor:deleteAlarmRule |
Grants the permission to delete rules on the DMS tenant side. |
write |
dws:cluster:updateSQLProbeForDMS |
Grants the permission to modify SQL probes in DMS. |
write |
cluster * |
dws:cluster:startMonitorMetricsCollectionForDMS |
Grants the permission to start the collection in DMS. |
write |
cluster * |
dws:cluster:listInstanceStorageForDMS |
Grants the permission to query the file system usage of each node in a GaussDB(DWS) cluster in DMS. |
list |
cluster * |
dws:cluster:deletePerfDashboardForDMS |
Grants the permission to delete the monitoring panels of a user in DMS. |
read |
cluster * |
dws:cluster:getMonitorMetricsDetailForDMS |
Grants the permission to query metric data in DMS. |
read |
cluster * |
dws:cluster:deleteSQLProbeForDMS |
Grants the permission to delete SQL probes in DMS. |
write |
cluster * |
dws:monitor:stopAlarmRule |
Grants the permission to disable rules on the DMS tenant side. |
write |
dws:cluster:stopMonitorMetricsCollectionForDMS |
Grants the permission to stop the collection in DMS. |
write |
cluster * |
dws:cluster:listExceptionTableForDMS |
Grants the permission to query the skew or dirty page rate of a table in DMS. |
list |
cluster * |
dws:cluster:getInstanceStorageAggForDMS |
read |
cluster * |
dws:cluster:getWDRSnapShotForDMS |
Grants the permission to obtain snapshot records in DMS. |
read |
cluster * |
dws:cluster:getPerfMetricsDataForDMS |
Grants the permission to obtain all monitoring metrics in DMS. |
read |
cluster * |
dws:cluster:listQueryForDMS |
Grants the permission to obtain all query permissions in DMS. |
list |
cluster * |
dws:cluster:getInstanceIOMetricsForDMS |
Grants the permission to query NIC I/O data in DMS. |
read |
cluster * |
dws:cluster:getSQLProbeDetailForDMS |
Grants the permission to query SQL probe details in DMS. |
read |
cluster * |
dws:cluster:switchoverMonitorMetricStatusForDMS |
write |
cluster * |
dws:monitor:startAlarmRule |
Grants the permission to enable rules on the DMS tenant side. |
write |
dws:monitor:getClusterStatus |
Grants the permission to query the status of a GaussDB(DWS) cluster in DMS. |
read |
dws:cluster:getPerfMetricsDetailForDMS |
Grants the permission to obtain monitoring items based on PMID in DMS. |
read |
cluster * |
dws:cluster:listSlowInstanceForDMS |
Grants the permission to query slow nodes in DMS. |
list |
cluster * |
dws:cluster:getDDLExamineConfigForDMS |
Grants the permission to query collection configurations in DMS. |
read |
cluster * |
dws:cluster:getMonitoringViewStatusForDMS |
Grants the permission to obtain the DMS view status. |
read |
cluster * |
dws:monitor:enableAlarm |
Grants the permission to enable the alarm function for a cluster on the DMS tenant side. |
write |
dws:cluster:createWDRSnapShotForDMS |
Grants the permission to add snapshots in DMS. |
write |
cluster * |
dws:cluster:listExecuteStatusForDMS |
Grants the permission to query the execution status of a GaussDB(DWS) cluster in DMS. |
list |
cluster * |
dws:cluster:getSlowInstanceDetailForDMS |
Grants the permission to query slow node details in DMS. |
read |
cluster * |
dws:cluster:enableSQLProbeForDMS |
Grants the permission to update the enabling status of a SQL probe in DMS. |
write |
cluster * |
dws:cluster:getWDRConfigForDMS |
Grants the permission to query cluster WDR configurations in DMS. |
read |
cluster * |
dws:monitor:disableAlarm |
Grants the permission to disable the cluster alarm function on the DMS tenant side. |
write |
dws:cluster:getMonitoringViewForDMS |
Grants the permission to obtain available menus in DMS. |
read |
cluster * |
dws:cluster:getDatabaseUsageForDMS |
Grants the permission to query the database usage in a GaussDB(DWS) cluster in DMS. |
read |
cluster * |
dws:cluster:listSQLProbeForDMS |
Grants the permission to query SQL probes in pagination mode in DMS. |
list |
cluster * |
dws:monitor:getAlarmMetrics |
Grants the permission to query alarm metrics on the DMS tenant side. |
read |
dws:monitor:listMetricStatus |
Grants the permission to obtain function statuses in DMS. |
list |
dws:cluster:listSessionStatusForDMS |
Grants the permission to query the session execution status of a GaussDB(DWS) cluster in DMS. |
list |
cluster * |
dws:cluster:downloadPerfHistoryForDMS |
Grants the permission to download historical monitoring trend data in DMS. |
write |
cluster * |
dws:cluster:addPerfItemForDMS |
Grants the permission to add monitoring items in DMS. |
write |
cluster * |
dws:cluster:listClusterSessionForDMS |
Grants the permission to obtain all current sessions in DMS. |
list |
cluster * |
dws:cluster:getSQLDiagnosticsForDMS |
Grants the permission to query SQL diagnosis details in DMS. |
read |
cluster * |
dws:cluster:updateWDRSnapShotForDMS |
Grants the permission to update the WDR configurations of a GaussDB(DWS) cluster in DMS. |
write |
cluster * |
dws:monitor:clearAlarm |
Grants the permission to clear alarms on the DMS tenant side. |
write |
dws:cluster:executeSQLProbeForDMS |
Grants the permission to perform SQL probes in DMS. |
write |
cluster * |
dws:cluster:listQueryStatusForDMS |
Grants the permission to obtain the current status of a query in DMS. |
list |
cluster * |
dws:cluster:getWDRReportForDMS |
Grants the permission to get report records in DMS. |
read |
cluster * |
dws:cluster:listWLMQueueForDMS |
Grants the permission to query the current workload queue in DMS. |
list |
cluster * |
dws:cluster:updatePerfItemForDMS |
Grants the permission to update monitoring items in DMS. |
write |
cluster * |
dws:cluster:getQueryCostForDMS |
Grants the permission to obtain historical resource consumption in DMS. |
read |
cluster * |
dws:cluster:createWDRReportForDMS |
Grants the permission to create WDR reports in DMS. |
write |
cluster * |
dws:cluster:downloadWDRReportForDMS |
Grants the permission to download WDR reports in DMS. |
read |
cluster * |
dws:cluster:listDatabaseForDMS |
Grants the permission to query all databases in the current cluster in DMS. |
list |
cluster * |
dws:cluster:listUserWLMQueueForDMS |
Grants the permission to query the workload queue of a user in DMS. |
list |
cluster * |
dws:cluster:deletePerfItemForDMS |
Grants the permission to delete monitoring items in DMS. |
write |
cluster * |
dws:monitor:getExceptionAlarmRule |
Grants the permission to query exception alarm rules in DMS. |
read |
cluster * |
dws:cluster:getWDRHostForDMS |
Grants the permission to query node information in DMS. |
read |
cluster * |
dws:cluster:getHistoryPerfDataForDMS |
read |
cluster * |
dws:cluster:deleteWDRReportForDMS |
Grants the permission to delete WDR reports in DMS. |
write |
cluster * |
dws:cluster:getPerfDetailByDimensionForDMS |
Grants the permission to obtain monitored objects based on the cluster ID and dimension in DMS. |
read |
cluster * |
dws:cluster:downloadPerfHistoryByIdForDMS |
read |
cluster * |
dws:cluster:listWaitingWLMForDMS |
Grants the permission to obtain queries that are currently waiting in DMS. |
list |
cluster * |
dws:cluster:getQueryPropertyForDMS |
Grants the permission to obtain query attributes in DMS. |
read |
cluster * |
dws:cluster:listBucketForDMS |
Grants the permission to obtain the OBS bucket list in DMS. |
list |
cluster * |
dws:cluster:getHistoryQueryPropertyForDMS |
Grants the permission to obtain historical query attributes in DMS. |
read |
cluster * |
dws:cluster:listExceptionWLMForDMS |
Grants the permission to query abnormal tasks in DMS. |
list |
cluster * |
dws:cluster:terminateQueryForDMS |
Grants the permission to terminate queries in DMS. |
write |
cluster * |
dws:cluster:updateTaskForDMS |
Grants the permission to update tasks in DMS. |
write |
cluster * |
dws:cluster:retryTaskForDMS |
Grants the permission to retry tasks in DMS. |
write |
cluster * |
dws:cluster:listTaskForDMS |
Grants the permission to query tasks in DMS. |
list |
cluster * |
dws:cluster:getDatabaseOmUserStatus |
Grants the permission to obtain the status of an O&M user. |
read |
cluster * |
dws:cluster:executeDatabaseOmUserAction |
Grants the permission to execute operations of an O&M user. |
write |
cluster * |
dws:cluster:getClusterInstancesInfo |
Grants the permission to query details about the logical cluster of a cluster instance. |
read |
cluster * |
dws:cluster:getMetadataSyncStatus |
Grants the permission to query the enabling status of DataArts metadata synchronization. |
read |
cluster * |
dws:cluster:startMetadataSync |
Grants the permission to enable DataArts metadata synchronization. |
write |
cluster * |
dws:cluster:stopMetadataSync |
Grants the permission to disable DataArts metadata synchronization. |
write |
cluster * |
dws:cluster:updatePeriodCluster |
Grants the permission to update yearly/monthly clusters. |
write |
cluster * |
dws:cluster:createPeriodCluster |
Grants the permission to create yearly/monthly clusters. |
write |
cluster * |
dws:cluster:deleteConfigTemplate |
Grants the permission to delete configuration templates. |
write |
cluster * |
dws:cluster:getCountDown |
Grants the permission to obtain countdown information. |
read |
cluster * |
dws:cluster:getObsHotStorage |
Grants the permission to query the OBS data usage of clusters with decoupled storage and compute. |
read |
cluster * |
dws:cluster:listConfigTemplate |
Grants the permission to query configuration parameter templates. |
list |
cluster * |
dws:cluster:listDwsResource |
Grants the permission to obtain the cluster instance resource list. |
list |
cluster * |
dws:cluster:listDiscountNode |
Grants the permission to query the nodes with discount packages. |
list |
cluster * |
dws:cluster:changeToPeriod |
Grants the permission to change the billing mode from pay-per-use to yearly/monthly. |
write |
cluster * |
dws:cluster:rotateKey |
Grants the key rotation permission. |
write |
cluster * |
dws:cluster:operateCluster |
Allows performing cluster operations, such as restoring and canceling read-only status. |
write |
cluster * |
dws:cluster:doUpgrade |
Grants the permission to upgrade clusters. |
write |
cluster * |
dws:cluster:listUpgradePath |
Grants the permission to obtain cluster upgrade paths. |
list |
cluster * |
dws:cluster:listUpgradeRecord |
Grants the permission to obtain cluster upgrade records. |
list |
cluster * |
dws:cluster:listLogicalClusterPlans |
Grants the permission to query scheduled addition and deletion plans. |
list |
cluster * |
dws:cluster:createLogicalClusterPlan |
Grants the permission to add scheduled addition and deletion plans. |
write |
cluster * |
dws:cluster:deleteLogicalClusterPlan |
Grants the permission to delete scheduled addition and deletion plans. |
write |
cluster * |
dws:cluster:listDatabaseUsers |
Grants the permission to query all database users. |
list |
cluster * |
dws:cluster:switchLogicalClusterPlan |
Grants the permission to enable or disable scheduled addition or deletion plans. |
write |
cluster * |
dws:cluster:updateLogicalClusterPlan |
Grants the permission to edit scheduled addition and deletion plans. |
write |
cluster * |
Each API of GaussDB(DWS) usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependency |
POST /v2/{project_id}/alarm-subs |
dws:alarm:createSubscription |
DELETE /v2/{project_id}/alarm-subs/{alarm_sub_id} |
dws:alarm:deleteSubscription |
POST /v1.0/{project_id}/clusters/{cluster_id}/cns/batch-create |
dws:cluster:addCN |
PUT /v2/{project_id}/clusters/{cluster_id}/workload/queues |
POST /v2/{project_id}/clusters/{cluster_id}/eips/{eip_id} |
POST /v2/{project_id}/clusters/{cluster_id}/elbs/{elb_id} |
POST /v1.0/{project_id}/clusters/{cluster_id}/cancel-readonly |
GET /v2/{project_id}/disaster-recovery/check-name |
POST /v1/{project_id}/clusters/{cluster_id}/check-instance-storage |
POST /v1.0/{project_id}/snapshots/{snapshot_id}/linked-copy |
POST /v1.0/{project_id}/clusters |
POST /v2/{project_id}/clusters |
POST /v2/{project_id}/cluster-precheck |
POST /v1.0/{project_id}/clusters/{cluster_id}/dns |
POST /v2/{project_id}/clusters/{cluster_id}/workload |
POST /v1.0/{project_id}/snapshots |
PUT /v2/{project_id}/clusters/{cluster_id}/snapshot-policies |
DELETE /v1.0/{project_id}/clusters/{cluster_id} |
POST /v1.0/{project_id}/clusters/{cluster_id}/cns/batch-delete |
DELETE /v1.0/{project_id}/clusters/{cluster_id}/dns |
DELETE /v1.0/{project_id}/clusters/{cluster_id}/ext-data-sources/{ext_data_source_id} |
POST /v2/{project_id}/clusters/{cluster_id}/nodes/delete |
DELETE /v1.0/{project_id}/snapshots/{snapshot_id} |
DELETE /v1.0/{project_id}/clusters/{cluster_id}/snapshot-policies/{id} |
DELETE /v2/{project_id}/clusters/{cluster_id}/workload/queues |
POST /v1.0/{project_id}/clusters/{cluster_id}/expand-instance-storage |
GET /v1.0/{project_id}/clusters/{cluster_id} |
GET /v2/{project_id}/disaster-recoveries |
dws:cluster:getDisasterRecovery |
GET /v2/{project_id}/disaster-recovery/{disaster_recovery_id} |
GET /v1.0/{project_id}/clusters |
dws:cluster:list |
GET /v1.0/{project_id}/clusters/{cluster_id}/audit-log-records |
GET /v1.0/{project_id}/clusters/{cluster_id}/cns |
GET /v1.0/{project_id}/clusters/{cluster_id}/configurations |
GET /v1.0/{project_id}/clusters/{cluster_id}/configurations/{configuration_id} |
GET /v1.0/{project_id}/clusters/{cluster_id}/ext-data-sources |
GET /v2/{project_id}/clusters/{cluster_id}/elbs |
GET /v1.0/{project_id}/clusters/{cluster_id}/shrink-numbers |
GET /v1.0/{project_id}/clusters/{cluster_id}/snapshots |
GET /v1.0/{project_id}/snapshots |
GET /v1.0/{project_id}/snapshots/{snapshot_id} |
GET /v2/{project_id}/clusters/{cluster_id}/snapshot-policies |
GET /v1.0/{project_id}/clusters/{cluster_id}/snapshots/statistics |
GET /v2/{project_id}/clusters/{cluster_id}/workload |
GET /v2/{project_id}/clusters/{cluster_id}/workload/queues |
POST /v2/{project_id}/disaster-recovery/{disaster_recovery_id}/pause |
dws:cluster:pauseDisasterRecovery |
POST /v2/{project_id}/clusters/{cluster_id}/redistribution |
POST /v1.0/{project_id}/clusters/{cluster_id}/reset-password |
POST /v1.0/{project_id}/clusters/{cluster_id}/resize |
POST /v1.0/{project_id}/clusters/{cluster_id}/restart |
POST /v2/{project_id}/disaster-recovery/{disaster_recovery_id}/recovery |
POST /v1.0/{project_id}/snapshots/{snapshot_id}/actions |
PUT /v1.0/{project_id}/clusters/{cluster_id}/maintenance-window |
POST /v1.0/{project_id}/clusters/{cluster_id}/cluster-shrink |
POST /v1/{project_id}/snapshots/{snapshot_id}/stop |
POST /v1.0/{project_id}/clusters/{cluster_id}/switchover |
DELETE /v2/{project_id}/clusters/{cluster_id}/eips/{eip_id} |
DELETE /v2/{project_id}/clusters/{cluster_id}/elbs/{elb_id} |
PUT /v2/{project_id}/clusters/{cluster_id}/configurations/{configuration_id} |
PUT /v1.0/{project_id}/clusters/{cluster_id}/dns |
PUT /v1.0/{project_id}/clusters/{cluster_id}/ext-data-sources/{ext_data_source_id} |
dws::updateTag |
POST /v2/{project_id}/event-subs |
dws::updateTag |
dws:event:createSubscription |
DELETE /v2/{project_id}/event-subs/{event_sub_id} |
dws:event:deleteSubscription |
GET /v2/{project_id}/event-subs |
dws:event:listSubscription |
dws:event:report |
PUT /v2/{project_id}/event-subs/{event_sub_id} |
dws:event:updateSubscription |
GET /v1.0/{project_id}/dss-pools |
GET /v2/{project_id}/node-types |
GET /v1.0/{project_id}/statistics |
GET /v1.0/{project_id}/tags |
POST /v2/{project_id}/clusters/{cluster_id}/logical-clusters |
DELETE /v2/{project_id}/clusters/{cluster_id}/logical-clusters/{logical_cluster_id} |
PUT /v2/{project_id}/clusters/{cluster_id}/logical-clusters/{logical_cluster_id} |
POST /v2/{project_id}/clusters/{cluster_id}/logical-clusters/{logical_cluster_id}/restart |
GET /v1/{project_id}/clusters/{cluster_id}/db-manager/om-user/status |
POST /v1/{project_id}/clusters/{cluster_id}/db-manager/om-user/action |
GET /v2/{project_id}/clusters/{cluster_id}/instances |
GET /v1/{project_id}/clusters/{cluster_id}/db-manager/objects |
dws:cluster:getDatabaseObjects |
dws:cluster:getAccessWhitelistStatus |
POST /v1/{project_id}/clusters/{cluster_id}/access-whitelist |
dws:cluster:addAccessWhitelist |
dws:cluster:getAccessWhitelist |
PUT /v1/{project_id}/clusters/{cluster_id}/access-whitelist/{whitelist_id} |
dws:cluster:getAccessWhitelistDetail |
dws:cluster:setAccessWhitelistDetail |
DELETE /v2/{project_id}/clusters/{cluster_id} |
Resource Type
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in the SCP statements for GaussDB(DWS).
Conditions
GaussDB(DWS) does not support service-specific condition keys in an SCP.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
