Updated on 2025-02-25 GMT+08:00
Enterprise Router (ER)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (list, read, or write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your policy statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by Enterprise Router, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by Enterprise Router, see Conditions.
The following table lists the actions that you can define in SCP statements for Enterprise Router.
Table 1 Actions supported by Enterprise Router
Action
Access Level
Resource Type (*: required)
Condition Key
Alias
er:instances:get
Grants permission to query the details of an enterprise router.
read
instances *
  • g:EnterpriseProjectId
  • g:ResourceTag/<tag-key>
er:instances:create
Grants permission to create an enterprise router.
write
instances *
  • g:RequestTag/<tag-key>
  • g:TagKeys
er:instances:list
Grants permission to list the enterprise routers.
list
instances *
er:instances:update
Grants permission to update an enterprise router.
write
instances *
er:instances:delete
Grants permission to delete an enterprise router.
write
instances *
er:instances:createVpcAttachment
Grants permission to create a VPC attachment.
write
instances *
er:attachments:create
er:instances:showVpcAttachment
Grants permission to query the details of a VPC attachment.
read
instances *
er:attachments:get
er:instances:listVpcAttachments
Grants permission to list the VPC attachments.
list
instances *
er:attachments:list
er:instances:updateVpcAttachment
Grants permission to update a VPC attachment.
write
instances *
er:attachments:update
er:instances:deleteVpcAttachment
Grants permission to delete a VPC attachment.
write
instances *
er:attachments:delete
er:commonAttachments:get
Grants permission to query the details of an attachment.
read
attachments *
er:attachments:get
er:commonAttachments:list
Grants permission to query the attachment list.
list
attachments *
er:attachments:list
er:commonAttachments:update
Grants permission to update an attachment.
write
attachments *
er:routeTables:get
Grants permission to query the details of a route table.
read
routeTables *
er:routeTables:create
Grants permission to create a route table.
write
routeTables *
instances *
  • g:TagKeys
er:routeTables:list
Grants permission to list the route tables.
list
routeTables *
er:routeTables:update
Grants permission to update a route table.
write
routeTables *
er:routeTables:delete
Grants permission to delete a route table.
write
routeTables *
er:routeTables:associate
Grants permission to associate an attachment with a route table.
write
routeTables *
er:associations:associate
attachments *
er:routeTables:disassociate
Grants permission to disassociate an attachment from a route table.
write
routeTables *
er:associations:disassociate
attachments *
er:routeTables:listAssociations
Grants permission to list the associations.
list
routeTables *
er:associations:list
er:routeTables:enablePropagation
Grants permission to allow an attachment to propagate routes to the specified propagation route table.
write
routeTables *
er:propagations:enable
attachments *
er:routeTables:disablePropagation
Grants permission to prohibit an attachment from propagating routes to the specified propagation route table.
write
routeTables *
er:propagations:disable
attachments *
er:routeTables:listPropagations
Grants permission to list the propagations.
list
routeTables *
er:propagations:list
er:staticRoutes:list
Grants permission to list the static routes.
list
routeTables *
er:routes:list
er:staticRoutes:create
Grants permission to create a static route.
write
routeTables *
er:routes:create
er:effectiveRoutes:list
Grants permission to list the effective routes.
list
routeTables *
er:routes:list
er:staticRoutes:delete
Grants permission to delete a static route.
write
routeTables *
er:routes:delete
er:staticRoutes:update
Grants permission to update a static route.
write
routeTables *
er:routes:update
er:staticRoutes:get
Grants permission to query a static route.
read
routeTables *
er:routes:get
er:tags:singleCreate
Grants permission to create a resource tag.
write
routeTables
er:tags:create
instances
er:tags:delete
Grants permission to delete a resource tag.
write
routeTables
instances
er:tags:batchOperation
Grants permission to add tags in batches.
write
routeTables
er:tags:create
instances
er:tags:get
Grants permission to query tags of a specific resource.
read
routeTables
instances
er:tags:list
Grants permission to list the tags.
list
er:quotas:list
Grants permission to query resource quotas.
list
er:flowLogs:create
Grants permission to create a flow log.
write
instances *
attachments *
flowLogs *
er:flowLogs:list
Grants permission to list the flow logs.
list
flowLogs *
er:flowLogs:get
Grants permission to query the details of a flow log.
read
flowLogs *
er:flowLogs:update
Grants permission to update a flow log.
write
flowLogs *
er:flowLogs:delete
Grants permission to delete a flow log.
write
flowLogs *
er:flowLogs:enable
Grants permission to enable flow logging.
write
flowLogs *
er:flowLogs:disable
Grants permission to disable flow logging.
write
flowLogs *
Each API of Enterprise Router usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by Enterprise Router APIs
API
Action
Dependency
POST /v3/{project_id}/enterprise-router/instances
er:instances:create
PUT /v3/{project_id}/enterprise-router/instances/{er_id}
er:instances:update
GET /v3/{project_id}/enterprise-router/instances/{er_id}
er:instances:get
er:instances:list
DELETE /v3/{project_id}/enterprise-router/instances/{er_id}
er:instances:delete
POST /v3/{project_id}/enterprise-router/{er_id}/vpc-attachments
PUT /v3/{project_id}/enterprise-router/{er_id}/vpc-attachments/{vpc_attachment_id}
GET /v3/{project_id}/enterprise-router/{er_id}/vpc-attachments/{vpc_attachment_id}
DELETE /v3/{project_id}/enterprise-router/{er_id}/vpc-attachments/{vpc_attachment_id}
PUT /v3/{project_id}/enterprise-router/{er_id}/attachments/{attachment_id}
GET /v3/{project_id}/enterprise-router/{er_id}/attachments/{attachment_id}
POST /v3/{project_id}/enterprise-router/{er_id}/route-tables
PUT /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}
GET /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}
er:routeTables:get
er:routeTables:list
DELETE /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}
POST /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}/associate
GET /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}/associations
POST /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}/disassociate
POST /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}/enable-propagations
GET /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}/propagations
POST /v3/{project_id}/enterprise-router/{er_id}/route-tables/{route_table_id}/disable-propagations
POST /v3/{project_id}/enterprise-router/route-tables/{route_table_id}/static-routes
PUT /v3/{project_id}/enterprise-router/route-tables/{route_table_id}/static-routes/{route_id}
GET /v3/{project_id}/enterprise-router/route-tables/{route_table_id}/static-routes/{route_id}
er:staticRoutes:get
GET /v3/{project_id}/enterprise-router/route-tables/{route_table_id}/routes
DELETE /v3/{project_id}/enterprise-router/route-tables/{route_table_id}/static-routes/{route_id}
GET /v3/{project_id}/{resource_type}/tags
er:tags:list
GET /v3/{project_id}/{resource_type}/{resource_id}/tags
er:tags:get
POST /v3/{project_id}/{resource_type}/{resource_id}/tags
POST /v3/{project_id}/{resource_type}/{resource_id}/tags/action
DELETE /v3/{project_id}/{resource_type}/{resource_id}/tags/{key}
er:tags:delete
GET /v3/{project_id}/enterprise-router/quotas
er:quotas:list
POST /v3/{project_id}/enterprise-router/{er_id}/flow-logs
er:flowLogs:create
GET /v3/{project_id}/enterprise-router/{er_id}/flow-logs
er:flowLogs:list
GET /v3/{project_id}/enterprise-router/{er_id}/flow-logs/{flow_log_id}
er:flowLogs:get
PUT /v3/{project_id}/enterprise-router/{er_id}/flow-logs/{flow_log_id}
er:flowLogs:update
DELETE /v3/{project_id}/enterprise-router/{er_id}/flow-logs/{flow_log_id}
er:flowLogs:delete
POST /v3/{project_id}/enterprise-router/{er_id}/flow-logs/{flow_log_id}/enable
er:flowLogs:enable
POST /v3/{project_id}/enterprise-router/{er_id}/flow-logs/{flow_log_id}/disable
er:flowLogs:disable
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP policy to define resource types.
The following table lists the resource types that you can define in SCP statements for Enterprise Router.
Table 3 Resource types supported by Enterprise Router
Resource Type
URN
instances
er:<region>:<account-id>:instances:<instance-id>
routeTables
er:<region>:<account-id>:routeTables:<route-table-id>
flowLogs
er:<region>:<account-id>:flowFlogs:<flow-log-id>
er:<region>:<account-id>:attachments:<attachment-id>
Conditions
Enterprise Router does not support service-specific condition keys in an SCP.
Enterprise Router can only use global condition keys applicable to all services. For details, see Global Condition Keys
